    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-28-2014, 11:14 PM   #9571
Originally Posted by MikeXray View Post
No but you can convert to either of the B4 style ones with it.
Can you pls elaborate? you mean I need B4 slippers?
zzztech is offline   Reply With Quote
Old 01-29-2014, 02:08 AM   #9572
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Yes you do, i think you can still use pad and spur from kyosho but you definitely need the slippers disc from the B4.
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 01-29-2014, 06:39 AM   #9573
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Originally Posted by JaredN View Post
What springs are everyone running In mm configuration
I run pink front and gold rear. also have tried red, white, and pick. depends on the track but the gold seem the best all around. I also have been trying different pistons and like the stock 5 holes. the others I liked a lot also was the 4x1.3
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 01-29-2014, 06:52 AM   #9574
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
White front 3x1.4 piston 32.5 ae oil
Gold rear 2x1.6 piston 27.5 ae oil
ryanpatrickgore is offline   Reply With Quote
Old 01-29-2014, 08:09 AM   #9575
mog ruith's Avatar
no love for a readyset? i just bought one....
mog ruith is offline   Reply With Quote
Old 01-29-2014, 08:29 AM   #9576
whitrzac's Avatar
Trader Rating: 94 (100%+)
They're out? I want a few parts from it... IE, the chassis and steel top shaft.
whitrzac is offline   Reply With Quote
Old 01-29-2014, 08:48 AM   #9577
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Have fun with the shocks, kyosho is known for the best kit shocks and the worst ready set shocks, there gonna leak and blow the tops off, hopefully you can find a used set cause I think there about $160 for all 4 new
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-29-2014, 08:53 AM   #9578
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Actually the design on the ready set shocks isn't like the Short Course truck (similar to velvets) so it should work better. Unless I looked at the wrong picture. I guess we will find out.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-29-2014, 08:56 AM   #9579
whitrzac's Avatar
The plastic big bore shocks look 1/2way decent. They go together like traxxas shocks...
I would pick up a cheap set of alloy caps for them.
Old 01-29-2014, 09:02 AM   #9580
Holmberg418's Avatar
Why the chassis?
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 01-29-2014, 09:04 AM   #9581
whitrzac's Avatar
Originally Posted by Holmberg418 View Post
Why the chassis?
Because it's black
I wish kyosho made the adjustable arm mounts in blue...
Old 01-29-2014, 10:09 AM   #9582
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Because it's black
you sure its not stamped? might be better to get the stocker anodized to black.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 01-29-2014, 10:20 AM   #9583
teeforb's Avatar
Send a message via Yahoo to teeforb
what rb6 upgrade made the most significant laptime improvements in the 17.5 blinky stock class?
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-29-2014, 10:22 AM   #9584
whitrzac's Avatar
Handing your radio to someone else
Tires...
Then better motor...
Old 01-29-2014, 10:23 AM   #9585
whitrzac's Avatar
It's not even available yet... I can't imaging it being <$30 anyway.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
