    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-20-2014, 06:33 AM   #9451
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Speedychris22 View Post
What is the purpose of the rear skid angle? I see most use .5 shim but I did see one setup that used the 1mm shim.
If you raise the front arm mount relative to the rear its anti-squat, this tends to free the car up on power.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-20-2014, 07:18 AM   #9452
Trader Rating: 48 (100%+)
Thanks Mike, so if I'm running on a low traction track no need for the 1mm shim right?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-20-2014, 07:31 AM   #9453
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
If you are talking about the section for the manual:
They show that if you take the shim out in between the tower and the mount, that you are running more anti-squat. You will get a lot more side bite with the shim in there.
For MM you have to run a total of 1mm with the shims for the tower to remain at the correct height and angle.
1mm between the holder and bumper = 0 between tower and holder
.5mm is .5mm between tower and holder
0mm is 1mm between tower and holer
For RM you just run the shim between the holder and bumper since the tower height is unaffected with the adjustment.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-20-2014, 07:49 AM   #9454
MikeXray's Avatar
Are you running rear or mid motor? Kevins explanation is very good as how to setup the 2 different mounts, but in low traction you will likely want to get the arms close to level, or even have the rear higher than the front.
Are you running at Cruzin? I plan to check it out once its warm.
Old 01-20-2014, 07:50 AM   #9455
Currently I have the .5mm shim between bumper and holder, so If I want more side bite do I just add the 1m shim between the holder and tower? or do I remove the .5 mm shim and then add the 1mm between the holder and tower.? Im running MM
Thanks Kevin
My Credit Card
Old 01-20-2014, 08:00 AM   #9456
CanyonCarverR1's Avatar
What are you guys using/doing to seal the gear diff?
CanyonCarverR1 is offline   Reply With Quote
Old 01-20-2014, 08:34 AM   #9457
Yeah Mike we run at Cruzin. Im also going to SJRC this Sunday for the trophy race. Im running MM. When you say arms close to level, is that with the shocks mounted?
My Credit Card
Old 01-20-2014, 08:50 AM   #9458
Razathorn's Avatar
Originally Posted by nitroargi View Post
Hello everyone,
Please correct me if I am wrong...the wider the rear and of the car is the better can cope with bumps in the track...right?
Yes and no. It will give you more stability and lower traction in the rear, which will make the bumps less of a big deal. Be careful though -- you may go outside the legal track width for the car, and generally, you don't do something like this because of how much it affects the roll profile of the rear. It really changes a lot.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 01-20-2014, 08:56 AM   #9459
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Rtv black gasket sealer from auto parts stores. Comes out like toothpaste and hardens into a soft rubber. And you can cut through it easy with a blade after its hardened.
ryanpatrickgore is offline   Reply With Quote
Old 01-20-2014, 09:09 AM   #9460
K_King's Avatar
Thanks Kevin
Remember the total sum of both shims needs to be 1mm. If you want more side bite, put a 1mm between the bumper and holder and none between the tower and holder.
Old 01-20-2014, 09:12 AM   #9461
K_King's Avatar
Have you messed with the rear hangers and how they affect roll vs a shorter link? For example D-in/D-in should provide the narrowest pivot, I'm guessing that locks the rear end down a bit too much, but what if you ran that plus the longest link?
Old 01-20-2014, 09:42 AM   #9462
Ok Now i understand. I made a mistake and never put the other .5 mm shim in. Im getting the new chassis this week so Im putting in your setup. My track conditions are very similar to yours except we are low traction. Should I start with the 1MM shim or 2 .5mm shims
My Credit Card
Old 01-20-2014, 10:00 AM   #9463
MikeXray's Avatar
You're thinking of ride height, what I mean is, if you look at the hingepin, say with no arm mounted, is it level, or tilted up or down? if the front is up, that is anti-squat, if it's down, it's pro-squat, it sounds like you do not want anti squat based on the conditions.
Old 01-20-2014, 10:23 AM   #9464
Got it totally makes sense now. Thanks Mike and Kevin.
My Credit Card
Old 01-20-2014, 05:12 PM   #9465
justpoet's Avatar
Trader Rating: 16 (100%+)
Regarding battery placement. I had the esc right in front of the motor, and then the shorty ran up to the low profile servo up front. This was AWESOME on super high bite like the worlds track...but undrivable on low-med bite indoor dirt.
Last week I took some out of the side guards and put the shorty sideways near the back (fits just right between the two side screws) and put the esc just in front of it. On the lower bite track it still isn't easy to drive, but it got me 3rd instead of not being able to make a lap cleanly at all, and responded really well to using very little brake anywhere, just scrub a tiny bit of speed and carve the corner from letting off. I'm running it with an 8.5. It still wants to step out a bit easier when getting on empower after a turn though, as compared to other cars on the track...but now I've got something I can actually work with.
Next time out I'm going to try an extra .5 toe to get the on power back a bit, and see what happens...probably soften up the esc punch setting a tad too.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
