    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-19-2014, 07:44 AM   #9436
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I have the red exotek bell cranks. Love em
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 01-19-2014, 08:07 AM   #9437
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Get the Kyosho one, it fits better than the Exotek one which gets pretty sloppy quick for some reason.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-19-2014, 08:18 AM   #9438
1967rs's Avatar
Trader Rating: 55 (100%+)
Originally Posted by glenng View Post
hi guys. i race (or at least trying to race) 17.5. im putting an amain order together and was contemplating the steel gear set for the gear diff. i already have the regular gear diff w 2k kyosho fluid in it and used that red kyosho gear diff seal grease and it leaks like mad still. i think i needed to put the grease in the screw holes perhaps, but havent opened the tranny back up to see, but notice a lot of fluid leaks out the cracks in the tranny case. when i had assembled the gear diff, the red grease did a great job sealing up the diff with exception of the screw holes, which had no grease sealant. anyhow, gear diff runs great despite being messy and i like the fact that it doesnt need constant re-tightening. so was thinking of upgrading to steel gears to bulletproof the thing but am having second thoughts and thinking the 70 bucks or so might better be spent on the mip pucks kit. so steel gear diff or pucks kit? or steal gear diff with mip aluminum cvd kit is another option too however concerned about aluminum cvd wear on steel outdrives. hence thinking pucks kit might be way to go although back to a ball diff. any thoughts? thanks.
glenn
I just installed the mip puck system on my 17.5 car and I am very happy with it. I also went with the carbon arms, towers and a ti screw set. I did them all at the same time so I can't say what had the greatest effect, thou I can say the car is far more nimble then it was before and I had to add weight to get to 1499.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 01-19-2014, 09:08 AM   #9439
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Anyone have a part # for the red 1mm, 2mm bump steer washers? Thanks!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-19-2014, 09:14 AM   #9440
4WDriver's Avatar
these?
http://www.kyoshoamerica.com/Aluminu...cs_p_9931.html
http://www.kyoshoamerica.com/Aluminu...pc_p_9861.html
4WDriver is offline   Reply With Quote
Old 01-19-2014, 09:20 AM   #9441
Thank you
SmacTrac
Old 01-19-2014, 09:59 AM   #9442
Default Battery Placement
I have a battery placement question I was hoping i could get some info on. I have been runing with the esc back by the motor and the shorty right in front. I see some of you run the short all the way back with the esc up in the front. My wires on my esc are to short at the moment to try it like that.
So with the shorty all the way back does it add slight bit more traction or is it allot more. Thanks.
Watkins is offline   Reply With Quote
Old 01-19-2014, 11:04 AM   #9443
1967rs's Avatar
Mid or rear motor?
D-W-D@comcast.net
Old 01-19-2014, 11:48 AM   #9444
Mid.
Old 01-19-2014, 12:05 PM   #9445
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
I have a pack of red washers you can have em when I'm at the track next. I'm slowly taking all the red off my car.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 01-19-2014, 12:36 PM   #9446
Thanks a lot Wayne!
SmacTrac
Old 01-19-2014, 12:37 PM   #9447
1967rs's Avatar
Mid.
I had the best luck with the short battery all the way back and the esc above the battery using the battery stop and esc shelf that come with the rt6. Having the esc up higher helps put more load on the outside rear tire in a corner for more side bite.
Problem I ran into is most bodies don't have clearance for the esc. Stock and J-concepts bodies will work if the esc is not too tall, proline gen3 and phantom bodies DON'T have clearance. I have a TRF201X-XR/XM body on the way it looks like it should have a lot of clearance.
D-W-D@comcast.net
Old 01-19-2014, 08:27 PM   #9448
Thanks for the help
I couldnt get the esc to fit on the shelf and have clearance under the body well enough, so i just put it flat on the chassis up front by the servo with the shorty back. Looking forward to trying it out soon.
Old 01-19-2014, 09:15 PM   #9449
Hello everyone,
Please correct me if I am wrong...the wider the rear and of the car is the better can cope with bumps in the track...right?
nitroargi is offline   Reply With Quote
Old 01-20-2014, 06:12 AM   #9450
Trader Rating: 48 (100%+)
What is the purpose of the rear skid angle? I see most use .5 shim but I did see one setup that used the 1mm shim.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
albertv78
