    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 01-15-2014, 12:16 PM   #9391
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Speedychris22 View Post
Which pistons?
whats your track conditions
trcr. avid machined taper pistone. 3x1.4 front 32wt / 2x1.6 rear 27.5 ae oil
indoor clay, medium-high traction, a big tripple, whoops, doubledoubles, sweeper, off camber turns. wet in the morning, tire squeeling traction at night.
ryanpatrickgore is offline   Reply With Quote
Old 01-15-2014, 12:27 PM   #9392
E73
E73's Avatar
Ryan, does Scott sell those pistons or did you order them online? Might try them Friday if he stocks them.
E73 is offline   Reply With Quote
Old 01-15-2014, 12:36 PM   #9393
BB20RC's Avatar
Originally Posted by skrichter View Post
Have a link to the 5 hole piston?
they are the stock pistons that come with the kit
Speed Passion - speedpassion.net
Team BBR - Paper or plastic?
Kyosho SC-R, Kyosho RB6, Tamiya Durga
Timewarp Raceway - You have to think about what I didn`t say
BB20RC is offline   Reply With Quote
Old 01-15-2014, 01:19 PM   #9394
skrichter's Avatar
Send a message via AIM to skrichter
These??
http://www.amainhobbies.com/product_...k-Piston-Set-2
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 01-15-2014, 01:54 PM   #9395
BB20RC's Avatar
yes those are them
Old 01-15-2014, 06:47 PM   #9396
Yeah I get most of my stuff through him, I have him order if he dosent have it most stuff takes 3-5 days to arrive, same as amain or speedtech. I rather give him the business.
The 3 hole pistons are the associated and the 2 hole are the avid. They are both machined and have the same exact fit.
Old 01-16-2014, 12:07 AM   #9397
morgoth's Avatar
Hi guys,
I bought a RB6 yesterday from a friend, brand new with a gear diff still in the package. I build the geardiff yesterday to try it on a smooth indoor carpet track.
I've build a lot of diffs (for 1/10 and 1/8 cars) and this is the first diff that isn't smooth. I can feel the gear moving when I turn the outdrive with my hand because the gearmesh is so tight.
I didn't add any extra shims. Just the 2 that cover the O rings.
Do I need to add an extra gasket to make it free? Or does it free up after a few runs?
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-16-2014, 12:18 AM   #9398
B00t13g's Avatar
Originally Posted by morgoth View Post
Hi guys,
Mine felt the same way. It will break in and feel buttery smooth.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-16-2014, 02:09 AM   #9399
Originally Posted by gocoogs View Post
jason, i saw your blog... very helpful...how are you holding down your battery w/o the holder?
are all the carbon parts like shock towers, arms and knuckles necessary? does that affect the peformance greatly or would the stock parts suffice?
I am making a trip out to CA at the end of the month and plan to visit OCRC for a wed night club race.
thanks in advance...
Justin
Battery held down with 3M automotive double sided tape (grey color).
The carbon parts are much lighter, so if you're trying to cut weight then yes they're necessary.
I am usually at OCRC on Wednesday, feel free to stop by and say hi, I'll go over your car with you as well.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 01-16-2014, 03:03 AM   #9400
FallenAllDay's Avatar
Got a front tyre question, do many of use aka inserts with proline tyres, the proline inserts are huge and i gathered you just cut them in half?? I run on a pretty blown out loose track and would like your guys opinion. Ive got a set of aka 3 rib and a set of holeshots for the front. What handling characteristics will the buggy have? Not real familiar with 1/10th tyre setups. Thanks for help.
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 01-16-2014, 05:36 AM   #9401
xrayrc's Avatar
Trader Rating: 61 (100%+)
3 ribs tend to be smooth and not turn in so tight. I run on loose dirt but hard packed weekly and they work great. The holeshot front normally too aggressive and can never find traction. If your looking for an in between tire then the 2 you have try a barcode or handlebar front tire....
Thanks to my sponsors Team Associated, Reedy, Jconcepts, Venom Group
Cruizin With RC's & Raceway
xrayrc is offline   Reply With Quote
Old 01-16-2014, 07:39 AM   #9402
whitrzac's Avatar
Trader Rating: 95 (100%+)
What's the best mid motor body?
whitrzac is offline   Reply With Quote
Old 01-16-2014, 07:57 AM   #9403
Anyone know where I can get a aluminum shock tool ? This cheap shock tool stripped out on me and now I can get it off to change my oil this has to be the cheapest crap I ever seen on a high end kit.. my losi came with a nice tool but the shock on the rb6 is nice
Anyone have any tips to remove it without using the shock tool?
iMarky is offline   Reply With Quote
Old 01-16-2014, 07:59 AM   #9404
1fastdude's Avatar
Trader Rating: 15 (100%+)
Default Shock tool
AVID
www.avidrc.com
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 01-16-2014, 08:21 AM   #9405
whitrzac's Avatar
Your putting them on to tight... (unless the bigbore tool is worst than the small shock tool)
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
dmcguire
