    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 01-13-2014, 09:26 AM   #9361
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Trevor Williams View Post
Strap a 17.5 in it and come run stock buggy with us @ SMACtrac!
I actually have a 17.5. Its not a schurrspeed or whatever its called. Just a Gen 2 tekin. But smac is a super long day and when I get home at 5 is when me and my son get to rebuild our toys together! He's 3 and can already keep his losi 22 short course truck between the pipes! Next year I might take him up there and make a day out of it, but right now his attention span is a little short hahaha
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 01-13-2014, 09:30 AM   #9362
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Gotcha, it is a long day @ SMAC but I love being at the track so I dont mind....hope to get to meet you sometime Nick!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-13-2014, 10:47 AM   #9363
Trader Rating: 55 (100%+)
Im sure this was covered but can I use the old Alum holders UMw511 Umw512 and umw514 and umw515 on the mid motor?
Speedychris22 is offline   Reply With Quote
Old 01-13-2014, 01:54 PM   #9364
nickdawg18's Avatar
Likewise. Our paths will cross soon! I wont be able to make the jconcepts race this year, but Ill come up there one saturday before outdoor starts.
Nick Carroll
Old 01-13-2014, 02:07 PM   #9365
Originally Posted by nickdawg18 View Post
Just wanna say that my buggy was absolutely dialed today. I turned an impossible 16 laps today on a track that hardly gives up 15's! Second place turned 14
Got the car working good huh?! Nice!
sir_thomas is offline   Reply With Quote
Old 01-13-2014, 02:12 PM   #9366
share the setup bro. what kind of track conditions are you running on.
Old 01-13-2014, 02:14 PM   #9367
Johnn27's Avatar
Trader Rating: 72 (100%+)
Thumbs up old holders on midmotor
You can probably use the front / rear aluminum holder but it is a snug fit. In the rear / rear you will need to use the kit supplied plastic mid rear holder until you get the new aluminum holders f/r & R/r.
The old rear/rear holders will not work with mid-motor configuration and if you go to rear / rear new aluminum holder you will have to get the f/r aluminum holder as well to adjust the toe properly.
Johnn27 is offline   Reply With Quote
Old 01-13-2014, 02:56 PM   #9368
yodace's Avatar
R/C Tech Charter Subscriber
Is there anyplace online that as the umw 705 and 707 both in stock?
yodace is offline   Reply With Quote
Old 01-13-2014, 03:56 PM   #9369
Ok thanks. I actually have the new holders, but a very good friend might be getting an rb6 and wants run mid motor so I want to help him the parts needed
Old 01-13-2014, 04:05 PM   #9370
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Broadcasting changing my car from rear motor to Mid motor right now
http://www/justin.tv/greenleytv
Nolimit208
nolimit208 is offline   Reply With Quote
Old 01-13-2014, 04:50 PM   #9371
In theory if I reverse the Ackerman plate will that give be better drive off the corners?
Old 01-13-2014, 05:12 PM   #9372
nickdawg18's Avatar
I am at work currently, but I run on high bite carpet. Pretty much andy dibrino's setup but with 35wt losi oil/yellow springs 4x1.3 pistons in the front, 30wt losi oil/red springs 4x1.3 pistons in the rear. The rb6 rear arms/long shock eyelets (only because my rb5 arm broke the week prior). Mid motor. 1/2 oz of weight on rear bulkhead. 8.5 tekin. Schumacher mini pins blue compound. Ill just make a setup sheet and post it here.
Nick Carroll
Old 01-13-2014, 05:19 PM   #9373
Thanks Nick
Old 01-13-2014, 06:39 PM   #9374
E73
E73's Avatar
RE: Kyosho V2 0 Aluminum Rear Hub Carrier Set KYOUMW704-0
I'm having a difficult time understanding which bearing combination to use. Is the "5x13/5x11mm axle bearing configuration" saying that the outside bearing is 5x13x4 and the inside is 5x11x4? Looking at the plastic inserts, there only appears to be one insert small enough to fit on the inside of the hub. The other three look like they only fit on the outside. Please explain so I can purchase the correct size bearings. Thanks.
E73 is offline   Reply With Quote
Old 01-13-2014, 07:19 PM   #9375
On inside 5x10 on outside u can use 5x10 5x11 or 5x13
I went with 5x13 but have 5x11 as backup
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
