    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 01-12-2014, 05:51 AM   #9346
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Mid motor or rear?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 01-12-2014, 06:49 AM   #9347
gelshocker's Avatar
Originally Posted by nickdawg18 View Post
Mid motor or rear?
Rear. I previously used the older RB5 wide alum hangers. Switched to the new ones with plastic inserts and it's binding (out-B). Any ideas?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 01-12-2014, 06:55 AM   #9348
Though I'm using these mounts in mid configuration (707 not 706) I used the steel bushings and the rear arms are completely free. Are you sure the plastic bushings aren't deforming?
kineteks is offline   Reply With Quote
Old 01-12-2014, 07:38 AM   #9349
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by Tom87 View Post
Well a hobby shop in japan told me yesterday that they are not released yet and they can't order them, but should be out be the end of the month.
Seems some people got lucky and scored some from kyosho america. I say they will be everywhere by February.
They're released, but sold out quickly.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-12-2014, 05:07 PM   #9350
gelshocker's Avatar
Thanks. The delrins are new so no deforming. I will try the steel bushings.
I am using the 521-1 arms so I'll also try removing the 0.3mm hinge pin shim and see if they loosen up. Cheers,
Kyosho RT5 | RB6
Old 01-12-2014, 05:50 PM   #9351
nickdawg18's Avatar
i know that with the stock hangers, the 521-1 arms dont use any hinge pin shims.
Nick Carroll
Old 01-12-2014, 07:48 PM   #9352
yodace's Avatar
R/C Tech Charter Subscriber
Originally Posted by Speedychris22 View Post
Kevin, I'm using ur setup for my mid motor car (the one with rt6 mod for the battery) nd the only thing I'm lacking is corner exit traction. What can I due to help rear end traction. The front end is great! Thanks
I also would like to know how to gain more rear traction?
yodace is offline   Reply With Quote
Old 01-12-2014, 08:42 PM   #9353
Trader Rating: 48 (100%+)
One thing I did today that helped was go to 3.5 toe in. Also went pink front springs. I know sounds crazy but it worked
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-12-2014, 09:19 PM   #9354
K_King's Avatar
Try adding .5 deg toe.
Old 01-12-2014, 09:21 PM   #9355
K_King's Avatar
Try my latest one here.
https://dl.dropboxusercontent.com/u/...Dec%202013.pdf
Old 01-12-2014, 09:43 PM   #9356
Originally Posted by K_King View Post
Looks good. Waiting on that new chassis to come out. Got to put that in.
My Credit Card
Old 01-13-2014, 03:39 AM   #9357
KalEl63's Avatar
+1 on the 3.5 rear toe.
It was one of the first things I did with mine and liked the feel
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 01-13-2014, 07:15 AM   #9358
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Just wanna say that my buggy was absolutely dialed today. I turned an impossible 16 laps today on a track that hardly gives up 15's! Second place turned 14
Strap a 17.5 in it and come run stock buggy with us @ SMACtrac!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-13-2014, 08:18 AM   #9359
Anyone know where to get Kyosho parts "on the cheap" in Canada?
Kyosho MP9 TKI3 || FX Royal 5K w/2108 || Futaba 4PLS || Futaba S9352HV servos
Yokomo B-MAX4 III || Orion VST2 6.5T || Orion R10 Pro || Futaba 4PLS || Savox servos
Last edited by codeman; 01-13-2014 at 08:56 AM. Reason: orig. post just asking about springs; but parts in general would be nice :)
codeman is offline   Reply With Quote
Old 01-13-2014, 08:24 AM   #9360
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Shoot me a pm. I think I have and don't mind shipping to you.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
