    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 01-08-2014, 07:51 PM   #9286
chillindrdude's Avatar
alittle RB6 porn.
new to me used RB6. mostly stock:
-ball diff
-30wt, pink springs fr / 25wt, red springs rr
-savox, spektrum rcvr, speed passion reventon pro, SP 3.0 MM 10.5T motor
-76/25 gearing
-shorty lipo with direct bullets
gearing seems alittle high. will try 22 or 23 pinion at my local indoor track if the temps get too hot.
I drive:
Tekno SCT410 | Kyosho RB6 | TLR 8-ight T 2.0 E-Truggy | Axial SCX10
chillindrdude is offline   Reply With Quote
Old 01-08-2014, 07:57 PM   #9287
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Roger H View Post
Just ordered my rb6.
Anything recommended out of the box?
Im switching from TLR and hoping this wont be a hard transition.
Check the first post. And you definitely won't be disappointed.
Wish I could have made it to the ROAR race this past weekend... You guys did a great job on the track. Looked awesome!
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 01-08-2014, 07:58 PM   #9288
rpboggs1's Avatar
Originally Posted by chillindrdude View Post
alittle RB6 porn.
Sexy! Sexy!
Old 01-08-2014, 10:31 PM   #9289
Trader Rating: 50 (100%+)
When installing the 521-1 arm I'm noticing no one mentions where to put the 2mm shim for the position? Am I missing something?
Edit add moment
Am I using the steel bushings or the law32 ones on the new holders with the inserts
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 01-09-2014, 02:31 AM   #9290
KalEl63's Avatar
I put my RB5 front axles in with the hexes tonight so now its testing time for the different wheels.
I must say I do like the RB5 axles over shimming the RB6 axles but hey no doubt really no difference I just like the look
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 01-09-2014, 06:34 AM   #9291
MikeXray's Avatar
Trader Rating: 73 (100%+)
Edit add moment
They are wider and there is no room for the shim, one of the small advantages of the rb6 arms is more wheelbase adjustment.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-09-2014, 07:03 AM   #9292
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Any one do anything to their gear covers to protect better? My home track can get pretty dusty and when I had my rb5 and now my rb6 I'm getting my gears all gunked up regularly. I always make sure my gear cover is newer and in good condition but it still happens. Wish it had a third screw spot on the bottom.
Was thinking maybe a thin layer of silicone adhesive to the edge of the cover to make a better seal?
Any thoughts or ideas?
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-09-2014, 07:13 AM   #9293
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I had the same problem. I put a thin line of double sided tape on the inside of the gear cover and kept the top protective plastic sheet on the exposed part of the tape. Works well. We have a clay track with some very small particles of sand that get in and ruin a spur occasionally. A third(lower) screw would be a great addition.....
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-09-2014, 07:51 AM   #9294
Bored at work so here's my rb6 porn shot..
iMarky is offline   Reply With Quote
Old 01-09-2014, 07:54 AM   #9295
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Default rb6
this is the old layout, i will post the new one when im done
ryanpatrickgore is offline   Reply With Quote
Old 01-09-2014, 08:05 AM   #9296
What about the bushings, do I use the plastic or steel ones with the new suspension holders with the fittings?
My Credit Card
Old 01-09-2014, 08:13 AM   #9297
Moderator
Posvar's Avatar
I was told steel/metal with the new v2 hangers.......
Old 01-09-2014, 08:14 AM   #9298
Moderator
Posvar's Avatar
What body is that?
Old 01-09-2014, 08:18 AM   #9299
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
PL phantom
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-09-2014, 08:26 AM   #9300
Originally Posted by Posvar View Post
What body is that?
Originally Posted by Trevor Williams View Post
PL phantom
Yup what Trevor said.. here's a closer shot of it
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
