    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 01-01-2014, 09:09 PM   #9226
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Originally Posted by nickdawg18 View Post
I have the stock front rb6 axles on mine still. No problems running aka rims on them. The rear is where you will most likely find problems. Stock rear axles are a little short for any other rim other then kyosho. Avid makes a longer axle conversion which is really nice, I have one on my car.
Or just get serrated wheel nuts, I've been using serrated wheel nuts for the last few years with my rb5 and now my rb6 with proline wheels without issue
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 01-01-2014, 11:50 PM   #9227
do you also change pins at the same time
No the pins will never wear. But check the front inner hinge pins as they can bend over time. Also the underside of the front arm near the bumper scrapes on the ground and could wear through eventually.
After running my car for 12 months I rebuilt it with my nib spares and kept the worn parts as spares. I replaced the front arms for the above issue, the caster block to remove slop and new rear drive shafts and diff hubs. The car is now like brand new again. I had new ball cups for the turnbuckles but had no slop so left the old ones on.
Tom87 is offline   Reply With Quote
Old 01-01-2014, 11:59 PM   #9228
Brilliant that makes life much easier. I already bought the avid long axle conversion so the rears not a problem anymore. So now my question is where do i need to put the spacer? In front of the hex or between the hub and hex, or both like mikexray said??
On the kit axle you have 1mm spacer between the hex and the bearing, and a 2mm spacer on the inside of the hub. To run other wheels run the 2mm between the hex and bearing and the 1mm on the inside. Yes your track width is now wider but still under legal width. To correct track width problem you flip the caster block inset to the narrow position. I actually ran this setup for awhile with the kit wheels as it has a slightly different feel.
Old 01-02-2014, 01:07 AM   #9229
KalEl63's Avatar
Originally Posted by FallenAllDay View Post
Hey guys ive been searching the forum and im wanting to put on the front rb5 axles on the front. That means i can run aka and proline rims then from what ive gathered?? Ive found a set with part number umw507 and wanted to know if they fit? Or do i have to go the umw506 route and buty the shaft separate like explained in the forum??
I did see them too but not sure about them so I played it safe & I have on the way (& hope to be here soon) RB5 Front Wheel Shaft (UM506) & Clamping Wheel Hub Set (LAW30GM)
Will be trying JC, AKA and eventually Proline wheels.
Decided to shimmed the RB6 axles on my MM and will try the Wheel Hubs and RB5 axles on my RM RB6 I figured not an expensive exercise to try to what its like.
I have ordered the narrow wheel nuts for the rear
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 01-02-2014, 03:58 AM   #9230
FallenAllDay's Avatar
Thanks for all the clarification and help guys
Let us know what you prefer in the long run KalE163
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 01-02-2014, 04:06 AM   #9231
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I used to just use the serrated nuts and I never had a wheel come off. It was always in the back of my mind though that the axle was never into the nylon of the locknut. So for the added security, I bought the avid kit.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 01-02-2014, 07:27 AM   #9232
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Why not run Kyosho wheels?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 01-02-2014, 08:31 AM   #9233
Razathorn's Avatar
I run these: http://www.amainhobbies.com/product_...Locknut-Set-10
Cheap and enough for 2 cars with 2 spares. At $3 for 10 nuts, and being super cool looking low profile black nuts, I don't understand why everyone who wants to run something other than kyo wheels doesn't have these.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 01-02-2014, 10:35 AM   #9234
chillindrdude's Avatar
anyone recommend an east coast or central US online retailer who stocks kyosho parts?
thanks
I drive:
Tekno SCT410 | Kyosho RB6 | TLR 8-ight T 2.0 E-Truggy | Axial SCX10
chillindrdude is offline   Reply With Quote
Old 01-02-2014, 11:03 AM   #9235
http://www.speedtechrc.com/
thats your best bet...great people and fast shipping!
SmacTrac
Old 01-02-2014, 11:04 AM   #9236
Double....
SmacTrac
Old 01-02-2014, 11:18 AM   #9237
MikeXray's Avatar
Trader Rating: 73 (100%+)
thanks
absolute hobbies.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-02-2014, 01:21 PM   #9238
305M3's Avatar
Trader Rating: 40 (100%+)
+1000... Jeff is great people.
But I think they are West Coast... Also on the WC is LosiPartsHouse and of course Amain...
On the East Coast/Mid, Absolute and InfernosOnly...
305M3 is offline   Reply With Quote
Old 01-02-2014, 01:38 PM   #9239
KalEl63's Avatar
Because over 50% of my K wheels have cracked and not due to bad driving.
1.21 GIGAWATTS!!!
Old 01-02-2014, 01:48 PM   #9240
Because where i live nobody stocks kyosho wheels at all. Plus they probably cost more.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
bonzo915
