    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-31-2013, 08:47 AM   #9196
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by skhadka17 View Post
Yeah, that's the front plate which I've been buying, I think it also comes stock cause that was the same part number in the manual, I tried bending them back but it's very difficult, has anyone tried reinforcing them or has an idea as to how to?
They actually revised the part and the new part number has a "b" at the end of it, KYOUM720B. I believe they discontinued the old one as it was bending but there maybe some still out there that are available to purchase.
You can tell if you have the new one as it has a mark on the top of it whereas the original piece does not.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-31-2013, 04:10 PM   #9197
Are there any aluminum or steel pivot balls for the shock mounts available? I find it pretty disappointing the amount of slop in the shock mount bushings. I thought this was Kyosho?
There is noticeable play when you lift the kit from the wheels and place it back down on the top and bottom of the shocks. I have been able to find threaded bushings for the upper links that connect to the shock tower, but nothing for the lower plastic shock arms.
Kyosho MP9 TKI3 || FX Royal 5K w/2108 || Futaba 4PLS || Futaba S9352HV servos
Yokomo B-MAX4 III || Orion VST2 6.5T || Orion R10 Pro || Futaba 4PLS || Savox servos
codeman is offline   Reply With Quote
Old 12-31-2013, 04:10 PM   #9198
Double post.
Old 12-31-2013, 04:24 PM   #9199
nickdawg18's Avatar
Trader Rating: 33 (100%+)
here's some aluminum shock mounts for the caps.
http://www.exotekracing.com/rb6-shock-post-set/
i dont know how your getting so much slop in your lower eyelets.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-31-2013, 10:46 PM   #9200
do you guys use close cell foam on front tires on MM set up?
iMarky is offline   Reply With Quote
Old 12-31-2013, 11:24 PM   #9201
Trader Rating: 74 (100%+)
Any reviews on the mip puck kit for the rb6? Wanna pimp mine out for 17.5 and this looks like a great kit.
b121774 is offline   Reply With Quote
Old 12-31-2013, 11:35 PM   #9202
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
I almost always do. Red AKA foams. Outdoor, I've played with open cell foams some. Indoor, 99% closed cells for me.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-31-2013, 11:42 PM   #9203
i see.. ill be indoors only..i have a red aka and i didnt like it on my losi 22 RM its still new im going to yank it out and put it on my RB6 MM set up.. just had so much push on that set up.
Old 01-01-2014, 12:32 AM   #9204
You need to run the red AKA closed cell foams in a little for them to be at optimal operating condition. They really come in after about 5 or 6 run cycles. The first few runs on the new foams feel like the tire is not "in" the track, but after you break them in, they are money. They are the best foams on the market. Just stick with them until they get good.
Hollywood_26 is offline   Reply With Quote
Old 01-01-2014, 12:56 AM   #9205
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I updated my previous set. Just noticed I had reversed the steering rack.
https://www.dropbox.com/s/1fnhs8sq6f...Dec%202013.pdf
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 01-01-2014, 05:31 AM   #9206
Trader Rating: 15 (100%+)
Hi guys, I'm looking to buy a NIB RB5 WC. PM if you have one....thanks
Harry Sachs is offline   Reply With Quote
Old 01-01-2014, 05:59 AM   #9207
Trader Rating: 55 (100%+)
Kevin what's the difference with the 97050 ball studs in the rear vs the stock ones?
Speedychris22 is offline   Reply With Quote
Old 01-01-2014, 07:14 AM   #9208
Moderator
Posvar's Avatar
Trader Rating: 463 (100%+)
Still loving my car! Made a few set up changes for high bite indoor tomorrow and its ready! Will start working on an mm set up soon for the first time!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-01-2014, 07:31 AM   #9209
chillindrdude's Avatar
just purchased an used RB6. compared to my dex210 (which is newer), the RB6 has a fair amount of slop. i notice slop at the knuckle/hub carrier, suspension arm hinge, and steering rack.
what amount of slop, if any, is present in a newly built kit? right now, i'm planning on replacing the entire front end (plus pins). but wondering i should start with the steering rack and knuckle/hub carrier first.
I drive:
Tekno SCT410 | Kyosho RB6 | TLR 8-ight T 2.0 E-Truggy | Axial SCX10
chillindrdude is offline   Reply With Quote
Old 01-01-2014, 07:57 AM   #9210
I've built a few new RB6's recently and the slop when new is the same as my car which is over a year old. I wouldn't worry at all.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
