    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 12-26-2013, 09:14 PM   #9151
Originally Posted by Razathorn View Post
The pack layout and weight depends on your track requirements. Our track is bumpy and tends to get low traction at times, so I have always run saddles all the way back against the motor plate (like tebo at cactus).
I tend to prefer a heavier car as it isn't as easily upset by bumps, and running the battery back for a little more rear weight distribution really locks the rear in when it gets slick. Having said that, I also run some very aggressive front tires, custom ground down to ghosted in some cases--I keep a little higher tread depth around for when the dust or crumbs come out on a drier night. My operating theory is that I can't re-arrange the car's weight distribution through the night reliably, so I just always setup the rear for the slickest possible conditions, and then meeter steering out based on how aggressive of a tire I run.
If I were running on something consistently high grip and smooth, I would be running a shorty forward as well.
Yeah Raza,
I've adopted a near identical approach to yours. At my home track it can definitely feel hooked up in one heat and then loose in the next...I've basically created the weight distribution i like and tune with tires and sometimes even the same tire with different inserts......almost always fronts.
Originally Posted by spdrac430 View Post
in mm my ride is chassis slapping front and rear anything i can do beside try harder to down side jumps
It's not completely ideal but I put longer shock ends on........WARNING: playing with the droop isn't usually the best way to accomplish what you're going for....but we had a triple that had to be double singled that was literally 1ft from a corner....so i was seat bouncing...."landing in the face" of last jump and the car was slapping like something fierce in MM config.....added longer shock eyelets and BAM...insta-DIALED!
Originally Posted by mblgjr View Post
Has anyone here come from a b4.2?
Anyone care to compare ea in rear motor form?
I've always been an AE guy. Losi just doesn't work for me. The RB6 seems to offer it all. I'm just struggling with the price point.
I still have and love my B4.2 but the RB6 is flat out faster on most surfaces that are groomed well and higher traction....when it gets loose or bumpy i feel that my B4.2 is easier to compete with.......
Both are AWESOME cars......kyosho plastics are light years better!
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 12-27-2013, 04:13 AM   #9152
Trader Rating: 50 (100%+)
Originally Posted by K_King View Post
Honestly it comes down to how you drive. Some guys simply cant do MM based on how they drive.
If you:
Slide your car into and through a turn
Wait to the last moment to slam on the brakes
Have a heavy finger
Are not particularly smooth
Then MM may not fit you. It really is more of a finesse style that is required. Now you can get a little gritty with them, but not in the same way you can with a RM car. There is no weight back there to help you go really hard at times. That's what gets a lot of drivers to switch back.
Thanks guys for all the responses. Kevin I'm going to start with your mid motor setup to see how it goes. One questions I'm always confused by on the hole on the rear hubs looks like in the pic you have a different hole used then what's on the sheet? Or am I just reading it wrong? Thanks
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 12-27-2013, 07:53 AM   #9153
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I go back and forth between the middle holes depending on the track conditions. Insude is a little softer vs the outer one.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-27-2013, 07:56 AM   #9154
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Stoked! Getting another rb6 tomorrow so I can start racing again! Gonna eventually swap out the Tekin/Reedy combo thats in it soon for a HW V3.1esc / HW V10 8.5 motor.....anyone running a HW V3 esc in their rb6 in RM form?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 12-27-2013, 08:54 AM   #9155
anyone here running the avid slipper? going to get it and i was wondering if the stock cover will work fine or i have to get a new cover ?
iMarky is offline   Reply With Quote
Old 12-27-2013, 09:12 AM   #9156
If your talking about the plastic piece that covers the slipper then yes. it covers it.
My Credit Card
Old 12-27-2013, 09:17 AM   #9157
yeah that flimsy cover lol... any chance theres a nice one? i glued that little cap you can take off if you want to adjust the spring tensions.. i just unscrew it when i need to adjust so i can see it better..
thanks
Old 12-27-2013, 09:25 AM   #9158
I found some pics in the thread......all good!
SmacTrac
Old 12-27-2013, 06:58 PM   #9159
nickdawg18's Avatar
Trader Rating: 33 (100%+)
They always come back!!!
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-28-2013, 12:31 AM   #9160
Trader Rating: 82 (100%+)
Stock plastic cover works but you need to buy the avid gear shaft along with the avid slipper system. Great buy though!!
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 12-28-2013, 12:29 PM   #9161
hello
We have done 2 races with RB6 in 13,5T stock cat. (high traction carpet with big jumps) and the car perform well without break or issues it is realy impressive.
I have two questions if someone has any experience a feedback appreciated.
- accelerating from zero with full throttle a strange noise coming out during 1-2 sec - could it be a diff? or slipper? anywey I will take out the diff to see what is inside.
- on the next race there is a mod class - the standard ball diff can handle lower turn motors like 8,5t ? Or in case of powerfull motors the gear diff conversiona must?
klimag is offline   Reply With Quote
Old 12-28-2013, 02:02 PM   #9162
biggerT's Avatar
Originally Posted by klimag View Post
hello
6.5/7.5 I run the 6.5 on high grip and the 7.5 everywhere else the ball diffs fine but the gear is fit an forget almost I just check the grease is still there every few months
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 12-28-2013, 02:14 PM   #9163
hello
no i get that strange noise w gear diff too. avid slipper and it still makes that noise too. so not really sure what it is
glenng is offline   Reply With Quote
Old 12-28-2013, 03:16 PM   #9164
U might have the slipper set to loose
My Credit Card
Old 12-28-2013, 03:18 PM   #9165
I need help with gearing, for my mid motor setup I want to out a 9.5t motor. What do u guys suggest I should run?
My Credit Card
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
