    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-21-2013, 11:00 AM   #9091
Default Cody Turner - Mid Motor RB6
A quick vid for all the RB6 guys!
+ YouTube Video
In HD here: http://youtu.be/Woxowr4JtZQ
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 12-21-2013, 12:03 PM   #9092
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Chris-s View Post
Other option is to stick the reciever next to the speedo. I have put a couple of pieces of brass sheet under the reciver to balance the chassis side to side.
Where can you get brass sheets?
ryanpatrickgore is offline   Reply With Quote
Old 12-21-2013, 01:55 PM   #9093
Ebay
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-21-2013, 04:43 PM   #9094
biggerT's Avatar
.5mm thick on the brass and a shorty sized peice weighs a dime under 3/4 oz an a peice the size of the lipo trey in chris's car comes in at an ounce keepin it as low as possible too made 2 1oz under trey and 4 under shorty bits 2 full size an 2 at 3/4 length for $10ish
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 12-21-2013, 04:52 PM   #9095
nickdawg18's Avatar
Trader Rating: 33 (100%+)
what?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-21-2013, 05:06 PM   #9096
B00t13g's Avatar
Originally Posted by K_King View Post
5k to start. It feels similar to my diff right now. If it's too much I have 3k to try. I run my diff pretty locked in mod.
How do you think the gear diff will handle a medium bite track?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-21-2013, 05:06 PM   #9097
My head hurts reading that !
Old 12-22-2013, 07:45 AM   #9098
biggerT's Avatar
Oops had a bottle a 21 year old malt last night my bad
I'll show ya the brass kit next time at Silverstone chris it'll make sense then
Old 12-22-2013, 08:17 AM   #9099
There is a 50g brass sheet under my lipo as well. Also have the weight blocks if I want to add even more weight. TBH, since I've been running the DB2, I havent run the RB6, its set up for low grip now.
Old 12-22-2013, 08:39 AM   #9100
Trader Rating: 54 (100%+)
Are u guys getting the kyosho diff balls for rebuilds or purchasing other brands
Speedychris22 is offline   Reply With Quote
Old 12-22-2013, 08:46 AM   #9101
The ones which come with the rb6 kit are carbide, so should last a while before you need to replace them. I've been using a mix of avid and RudeBits carbide balls in my lazer/rb6 diffs.
Old 12-22-2013, 09:08 AM   #9102
VenturaDC's Avatar
Trader Rating: 32 (100%+)
So at what point does adding weight negate the mid motor effect? I mean this buggy is already fairly heavy, at some point it would seem better to drop the weights and go back to rear motor, I run on both clay and hard packed blue groove and after spending some time on the setup I've got plenty of steering, at least in 17.5 I can see how much more pull I have on corner exit then some of the heavily weighted MM's.
I'm only asking cause I've toyed with the idea of going MM but not a big fan of adding a bunch of weight
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-22-2013, 09:11 AM   #9103
biggerT's Avatar
i got a half a mill thick peice under the whole trey chris 28g and 18g for under the shorty if needed
Old 12-22-2013, 09:39 AM   #9104
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
It can work. Just need to find the right oil. I think it will be anywhere between 1k and 5k but on the lower end.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-22-2013, 05:53 PM   #9105
Kevin I was looking at your latest setup on petit Rc nd noticed your using different pistons, which brand are they?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22980 Today 04:37 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
