    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-20-2013, 07:41 PM   #9076
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
New chassis.
http://www.flickr.com/x/t/0099009/ph...7638867362856/
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-20-2013, 07:54 PM   #9077
omarsez's Avatar
Trader Rating: 37 (100%+)
Default Little help here...
So let me see if i understand you....
More angle... (more slip angle) means more side bite?
Kyosho RB5 SP2
Kyosho RT5
Kyosho DB
Kyosho ZX5 FS
Kyosho RB6
omarsez is offline   Reply With Quote
Old 12-20-2013, 09:41 PM   #9078
spdrac430's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to spdrac430 Send a message via Yahoo to spdrac430
chassis looks like something that will be an option maybe help the stock guys but man i want it
Tekno, Kyosho, SMC-racing.com, AKA, Avidrc.com, Futaba
Trick Graphics
Heart of a Hustler Racing Team
spdrac430 is offline   Reply With Quote
Old 12-20-2013, 09:57 PM   #9079
gelshocker's Avatar
Originally Posted by K_King View Post
Hi Kevin, for your old chassis, was it a replacement one? I notice at under the gearbox its hasn't caved in. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 12-20-2013, 10:17 PM   #9080
yeah thats what i was thinking more for stock... mods will need a bit more beef due to big jumps and hauling butt
iMarky is offline   Reply With Quote
Old 12-21-2013, 12:31 AM   #9081
K_King's Avatar
Less side bite in the corners.
Yeah this car was bought a few months after. The initial batch had issues but it was fixed rather shortly.
Here is my car now. Stupid light!
I put the gear diff in. Aluminum idler and moved my ESC to the rear to try that and I'm at 61.5% with a shorty pack vs 1630 and saddles with a stiffer car.
My theory is that a stiffer car relies on weight distribution a bit more than a flexible one. I should be able to get away with a lighter car that flexes more at that weight than a stiffer one. That's my hope anyway.
Old 12-21-2013, 12:33 AM   #9082
K_King's Avatar
Here's my layout.
Old 12-21-2013, 01:08 AM   #9083
Is that 61.5% weight on the rear wheels with the shorty?
Your layout is the same as mine but I was thinking going back to saddles but I'm not sure.
Tom87 is offline   Reply With Quote
Old 12-21-2013, 07:10 AM   #9084
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Here's my layout.
After I ditch my tekin and go Orion, I'm doing the exact same layout. Only thing is, I run an m11x and I don't think my receiver is small enough to mount on the chassis guards.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-21-2013, 07:45 AM   #9085
Other option is to stick the reciever next to the speedo. I have put a couple of pieces of brass sheet under the reciver to balance the chassis side to side.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-21-2013, 08:35 AM   #9086
K_King's Avatar
Yup. With saddles the car was good but always felt a little lazy. I think that the extra weight doesn't always add grip. I think that it helps for high speed stuff but low speed exits it could get looser since the car was just heavier.
Old 12-21-2013, 08:53 AM   #9087
K_King's Avatar
Here's the gear diff
Heres what my Saddle Packs weighed in as
Here's what I am with all the new parts and shorty with the ESC in the rear.
Old 12-21-2013, 09:38 AM   #9088
nice.. what wt oil you using on the diff? going to give a gear diff a try once my ball diffs starts to go bad
Old 12-21-2013, 10:02 AM   #9089
CanyonCarverR1's Avatar
Wondering if someone can explain a few things to me.
First question... in the manual don't know what "Skid Angle" is and what it affects>.. if someone can clarify that for me that would be great.
Second question is about the kyosho rear suspension holders. In the picture you see that i have the aluminum "RF" and the Rear holders. (forgot to say im running midmotor) and ive seen the instruction sheet but im having a hard time understanding? Is the RF supposed to have the adjustable inserts like the rear or not? And if i have the right ones do i only adjust the rear? HELP>>>
Looks to me like you have the old version RF, and the new version RR(with inserts for width). There is a new version RF(with inserts for width):
http://www.amainhobbies.com/product_...pension-Holder
CanyonCarverR1 is offline   Reply With Quote
Old 12-21-2013, 10:12 AM   #9090
K_King's Avatar
5k to start. It feels similar to my diff right now. If it's too much I have 3k to try. I run my diff pretty locked in mod.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22981 Yesterday 04:29 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
