    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-19-2013, 04:06 PM   #9046
Suspended
Hey guys. New to Kyosho. Have a RB5 sp2 with the big bores. Not much for around me. Running blinky 2wd. It's a in door track. Hard pack dirt. A little bumpy . It's not clay but I think a basic dirt. Bar codeV2 seems to be the tire at moment. Car has pink springs all the way around. White 5 hole pistons. All I know. 35 Losi oil front and 30 Losi in rear. Car is not bad. But I'm sure could be better. Track has a decent straight with a sweeper and a triple and table top and some elevation changes. Any set up tips would be great. Thanks...
drgrcrp301 is offline   Reply With Quote
Old 12-19-2013, 04:43 PM   #9047
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by K_King View Post
They're velvet coated alum. I would think it's ok. I haven't had any issues but I want to try them anyway. I was looking at the metal to metal issue but it should be ok.
Thanks,
I will probably try at lest one here at some point. My tranny is sounding like it's getting close to being time for a rebuild. Figured I'd go the metal/plastic/metal/plastic setup and see how it goes. Thinking that might help take a little stress off the idler gears in MM.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-19-2013, 04:48 PM   #9048
gelshocker's Avatar
Originally Posted by Teufel Racing View Post
Thanks,
Let us know how it goes, I have the new parts coming in from Japan. No mention of the new lightweight chassis on Kyosho Japan otherwise I would've included it in my order
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 12-19-2013, 05:50 PM   #9049
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Very similar to my rb5 setup,
Pink front assoc 32.5wt
White rear assoc 30wt
Middle front camber link
Middle rear camber link
25deg caster
.05 aluminum rear hubs
23mm front and 22mm rear ride height
M3 holeshots front and rear
14g weight upfront and 7g in each rear corner pocket
As long as I kept the diff fresh and working perfect the car was absolutely dialed on hard packet dirt.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-19-2013, 06:55 PM   #9050
Trader Rating: 91 (100%+)
Metal/plastic/metal/plastic is tha way to go. That velvet coating will last about 2 laps between two metal gears. Then it will sound like an 1/8th scale. Lol
plus Im pretty sure the second idler is under a lot more stress than the first
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 12-19-2013, 07:38 PM   #9051
Optional parts with their own part numbers
Ok cool... I hope sdrc will carry the parts soon..
iMarky is offline   Reply With Quote
Old 12-19-2013, 11:58 PM   #9052
Originally Posted by nickdawg18 View Post
Id love to have that body. Best one ive seen yet.
I believe that is the same body as Tamiya's TRF201 XR/XM stock body.
**Speed Tech RC**LRH Hobbies**
pwrslider is offline   Reply With Quote
Old 12-20-2013, 01:06 AM   #9053
According to the instructions of the new metal idle gear only one gear from the mid motor diff case is to be replaced with the option odle gear...he one that is in contact with the topshaft.
Makes sense I quess...same thing is proposed for the Yokomo 2wd
nitroargi is offline   Reply With Quote
Old 12-20-2013, 01:08 AM   #9054
Trader Rating: 22 (100%+)
pwrslider is right. Mine is sitting in front of me and it looks the same.
http://www.tamiyausa.com/product/ite...oduct-id=84368
littleZEN is offline   Reply With Quote
Old 12-20-2013, 06:55 AM   #9055
No its the new Muchmore Wonder body
http://www.muchmoreracing.net/us/detail/xgb001.htm
zzztech is offline   Reply With Quote
Old 12-20-2013, 07:47 AM   #9056
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
How do you tell them apart? They look almost identical if not the same to me.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-20-2013, 07:49 AM   #9057
If they're not the same body they are awfully close....
at $57 they're not giving them away
Kyosho Ultima RB6 & RB6.6 Car Thread-tamiya-trf210x_xrxm.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-muchmore-wonder-body.jpg
kineteks is offline   Reply With Quote
Old 12-20-2013, 09:10 AM   #9058
Rudebits will be doing a similar body: http://www.rudebits.co.uk/product_in...roducts_id=437
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-20-2013, 09:15 AM   #9059
Old 12-20-2013, 10:35 AM   #9060
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Interesting. I wonder why metal to metal is preferred.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
