    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-18-2013, 09:02 AM   #9016
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Kraig View Post
um521-1 is the part number. No need to change anything else. Keep in mind that this arm does not require shims on the inner suspension pins like the stock arm does.
Just to be clear, your talking about the um713 shim and not the um508c shim right?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-18-2013, 09:08 AM   #9017
The UM521-1 also requires a set of outer hinge pins or you can ream the outer hole on the arm where it captures the hinge pin and use the RB6 outer hinge pin with 2 2mm spacers. Really easy mod.
sir_thomas is offline   Reply With Quote
Old 12-18-2013, 09:09 AM   #9018
Originally Posted by glenng View Post
gear diff - 2,000 weight oil a good start point? thanks.
Would this be for mod or stock? What kind of grip are you running on? Tires and sauce?
Old 12-18-2013, 09:10 AM   #9019
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I was lucky enough to get to drive my first RB6 last night at the local club race. It was a stock buggy in mid motor layout. Only got to run one pack before racing and was very impressed with the performance. TQ and won last night with 18 guys running stock. Needless to say I will running a RB6 next year in mod. We are lucky enough to have Team Kyosho at our home track and pretty much everyone runs Andy Dibrio set-up. So planted and turns awesome.
Set-up is on our site here. http://www.thebigrc.com/?p=5070
Cameron Kellogg is online now   Reply With Quote
Old 12-18-2013, 09:54 AM   #9020
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
cameron, were all the guys in p-town running the saddles as well too? or shorties as well?
ryanpatrickgore is offline   Reply With Quote
Old 12-18-2013, 10:06 AM   #9021
My loaner had a short pack in place with everything else the same. Most everyone runs the saddles though. The saddles add some weight in the center of the chassis to help give the more plated feel. I will be going with saddles. Personal preference but Andy was top ten at the Spectrum race too and all he changed was tires. Its a real good starting set-up for the regular racer guy.
Old 12-18-2013, 02:13 PM   #9022
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I'm looking forward to trying out the new chassis. Should be here Friday.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-18-2013, 02:22 PM   #9023
Didn't know they came out with a new one.. I'll check it out when I see you at sdrc
iMarky is offline   Reply With Quote
Old 12-18-2013, 02:39 PM   #9024
K_King's Avatar
It's a lighter chassis by 25g. More milling so it flexes more for more traction.
Old 12-18-2013, 02:51 PM   #9025
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Oh you are such a tease. New part number?
So if you wanted to go with the 521-1 arm with no modifications you would need to get the following
UM521-1 Kyosho SP "Type B" Middle Suspension Arm Set, 2 of them
la229 Kyosho Rear Outer Suspension Shaft
KYO1-S12605H Kyosho 2.6x5mm Button Head Screw
OW5015 Kyosho Short Big Bore Shock End Set (4)
If you wanted to use the RB6 rear suspension shaft then you would have to drill out the arm like sir_thomas explained.
I think I got it right now.
Or you could just use the stock arms and see how that feels.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-18-2013, 02:57 PM   #9026
K_King's Avatar
UMW720
Old 12-18-2013, 03:06 PM   #9027
maybe thread owner can stick this to post #1
Old 12-18-2013, 05:57 PM   #9028
Derry's Avatar
Trader Rating: 27 (100%+)
UMW720
Looks nice!
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 12-18-2013, 06:21 PM   #9029
Super Moderator
Kraig's Avatar
I have added it.
Old 12-18-2013, 06:23 PM   #9030
nickdawg18's Avatar
Originally Posted by Derry View Post
Looks nice!
Looks like theyve added an extra set of holes for the rear battery brace!
Nick Carroll
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
