    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-16-2013, 10:26 PM   #8986
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Looks ok to me. Are you running your kick plate at 25???
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-16-2013, 10:50 PM   #8987
cool..... yeah 25 degree.. is that good for indoor clay set up? have not ran this puppy yet
iMarky is offline   Reply With Quote
Old 12-16-2013, 11:39 PM   #8988
VenturaDC's Avatar
Trader Rating: 32 (100%+)
I did not have to trim anything on mine.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-17-2013, 12:06 AM   #8989
nickdawg18's Avatar
you might feel like the buggy has too much steering. I started with 25 as well. I flipped it to 30 this weekend and it toned it down a little bit. you can go all the way up to 34 degrees of total caster if you feel like you need to tone it down even more. I also took out the shim underneath the caster block, but I havnt ran it with it out yet.
Nick Carroll
Old 12-17-2013, 05:27 AM   #8990
whitrzac's Avatar
Trader Rating: 95 (100%+)
Does anyone have a list of differences between the RTR and the kit?
It looks like the only difference is the shocks and dogbones VS CVs...
whitrzac is offline   Reply With Quote
Old 12-17-2013, 06:45 AM   #8991
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Molded wheel hexes, rear dogbones, molded shocks, non milled / non hard coated 7075 chassis, will the transmission be the same? I tossed around the idea of getting one to start racing again, talked myself out of it.....Id have a grand into by the time it was all said and done with upgrades and replacing elecreonics as they die etc..or get the pro kit and do it right.....
I found a used artr setup for $600 Im getting locally, nice roller, tekin rs, reedy 8.5, racers edge shorty and futaba bls servo, cant wait to get back on the track...havent touched a transmitter since this time last year, lol
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 12-17-2013, 08:09 AM   #8992
skengines's Avatar
Trader Rating: 226 (100%+)
Anyone running Protek servos in their RB6?
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 12-17-2013, 08:40 AM   #8993
I think the way that i have the two wires zip tied together is gonna solve that problem. The positive wire was the one hitting the mode button and that was before i zip tied them together. The way i have it now, there's no way it can hit the button. But I like your idea of taking out the buttons. I might just do that. Will it void the warranty if I open it up though?
I don't believe it would void your warranty. They sell replacement cases for the all of the tekin units. Many people I know with the Gen2 change their case to black. I changed one of mine due to the soldering iron...
Arcain41 is offline   Reply With Quote
Old 12-17-2013, 08:48 AM   #8994
whitrzac's Avatar
I have piles of RB5 stuff, and electronics.
I have hexs
The CVs are the same size
Shocks are too
IDK about the tranny, does it use the same diff/idelers/top shaft as the Rb5?
Old 12-17-2013, 09:15 AM   #8995
Everything minus the case itself is the same, IF I remember correctly that is.
SmacTrac
Old 12-17-2013, 09:19 AM   #8996
nickdawg18's Avatar
You should have kept the one you sold a couple months ago lol
Nick Carroll
Old 12-17-2013, 09:28 AM   #8997
Ya...it was a really good car....my schedule looked slammed to the point of no return then I got pullled off some dates that is giving me some time to get active again.....been a long time and Smac is a TOUGH crowd, when you gonna race there........place is off the hook!
SmacTrac
Old 12-17-2013, 02:59 PM   #8998
gear diff - 2,000 weight oil a good start point? thanks.
glenng is offline   Reply With Quote
Old 12-17-2013, 03:06 PM   #8999
chillindrdude's Avatar
Originally Posted by Gitsum View Post
To keep dirt from getting under the ballcups so they move freely.
where do you buy those foam thingies?
I drive:
Tekno SCT410 | Kyosho RB6 | TLR 8-ight T 2.0 E-Truggy | Axial SCX10
chillindrdude is offline   Reply With Quote
Old 12-17-2013, 03:36 PM   #9000
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
http://www.amainhobbies.com/product_...End-Sheet-ZX-5
Noah Mattocks
ovalracer1m is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
