    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-01-2012, 12:14 PM   #886
fastestwon's Avatar
Trader Rating: 15 (94%+)
Originally Posted by savageboy69 View Post
looks like you had a little on power push?
yeah some still looking for the right tire to run up front . car is nice and smooth on the track . was TQ and won the main so all in all not bad first run . got to the track late so only got about two packs through it . it will only get better thou
fastestwon is offline   Reply With Quote
Old 10-01-2012, 12:16 PM   #887
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Gitsum View Post
Might help to point out which car is yours....
he posted pics a page or two back.. he's the gray car in the #1 spot
Sfida
t8rtot is offline   Reply With Quote
Old 10-01-2012, 12:28 PM   #888
t8rtot's Avatar
would the kit springs be a good starting point for mid motor?
Sfida
Old 10-01-2012, 12:51 PM   #889
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It would work yes... but certainly wouldn't be ideal. If I had to guess, I would say white fronts, and gold rears. Without a spring balance test it would be hard to say for sure.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-01-2012, 12:59 PM   #890
savageboy69's Avatar
Trader Rating: 88 (100%+)
ur main issue with the stock red springs would be they would be too stiff IMO, due to the fact you no longer have the weight of the motor and tranny hanging off the rear end so forward bite would suffer, you would have to go to a lighter spring in the rear to compensate, and now with the motor and tranny sitting forward that means more weight to the front so you would want a stiffer spring there as was stated by CPT america. you could try to drive it with stock springs but i think you would have a ton of steering and your rear wouldnt stay behind ya lol
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 10-01-2012, 01:01 PM   #891
t8rtot's Avatar
sir, you don't even have the car and are already giving advice? i love it. i can't wait until you get your car up and going. i doubt there i will be any running in my area so help here is fantastic.
p.s. there is no sarcasm in this post, i really do appreciate it.
Sfida
Old 10-01-2012, 01:09 PM   #892
t8rtot's Avatar
thank you
Sfida
Old 10-01-2012, 01:51 PM   #893
fastestwon's Avatar
the stock springs on this car are very nice and should work just fine for the mid motor . when i built my car i used the 6 hole pistons with losi 25 wt front and rear . my next change will be to use the shorty packs i think it will benefit the handling and balance i have two packs coming this week . we run a very tight clay track .
Old 10-01-2012, 01:51 PM   #894
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Rfury View Post
You ran the Tebo setup with the stock RB6 arms?
Also, are you saying your RB6 hero lap was 0.3 faster than your RB5+10 hero lap?
Yes. That was stock arms w/.5 hubs . Rear shock position was inside on the arm. High bite indoor clay running worn beams rear and scrubs front
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 10-01-2012, 01:53 PM   #895
Originally Posted by Brad S. View Post
What size shock ends did you use by chance for the front and rear? When I looked at Tebo's setup, I could not achieve 27mm in between the bottom of the shock and the rod end on the rear. The rod end could not screw on far enough. Any help???
Thanks,
Brad
I ran the Tebo set up and got the distance in his set up. I do not have it handy. Having said that the team drivers had the longer ones on in the rear. Not sure what that difference would be
goin2drt is offline   Reply With Quote
Old 10-01-2012, 02:06 PM   #896
fastestwon's Avatar
FYI guys you are definitely going to want the aluminum rear arm mounts the stock plastic ones are fat and limit ur motor adjustments also they seem to pull out during racing so make sure you check them after every run . i found one of my older aluminum arm mounts and put it on. so next time the car will be more consistent during the race . and with the aluminum arm mount i can run the pinon i want to . i am able to go from a 22 tooth to a 31 where as with the plastic i was only able to use the 29 tooth as my smallest .
Old 10-01-2012, 02:08 PM   #897
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Posvar View Post
Are the longer eyelets stock in the kit or the shorter?
Thanks,
Brad
Are the kit shock ends the "short" ones? Part number KYOW5015?
thanks
The kit comes with M for the front and L for the rear. I believe Tebo ran S in the front and M in the rear at the Nats but I'd have to double-check.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 10-01-2012, 02:08 PM   #898
Super Moderator
Thanks,
Brad
USUALLY...(i can't say for sure in this instance), tebo measures from the bottom of the bottom shock cap, to the TOP of the rod end. Basically, the overall length of shock shaft that shows when its fully extended. If you combine THAT number, while using the same shock ends... you have your setup. It's all in efforts to achieve a certain amount of droop. If you have a link to the setup sheet you're reading, I'd be happy to look at it to confirm... (its of course possible he measured it a different way.. just going on past tebo setups iv looked at)
- RCSpecialties -
Old 10-01-2012, 02:14 PM   #899
Super Moderator
Are you referring to the suspension hangers? If so, do you know if the ones from the RB5 are a direct swap onto the RB6?
- RCSpecialties -
Old 10-01-2012, 02:21 PM   #900
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
If they are a direct drop on....which ones are they? The Amain web site has several choices under the rb6 parts pages....rr, rf, wide etc. I only want to buy one set of rear inner and outer if possible....
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
