    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 12-14-2013, 04:06 PM   #8956
nickdawg18's Avatar
Trader Rating: 33 (100%+)
i had a problem today that cost me the A main. I came down from a jump and kinda overshot the landing so there was a little chassis slap. The positive battery wire slapped the damn mode button on my esc. I was like WTF. It happened twice. but the buggy ran awesome. TQ'd and led the majority of the race until that crap happened. but you live and you learn. I think I'm gonna ditch tekin in 1/10th scale and and go orion.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-14-2013, 04:09 PM   #8957
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by VenturaDC View Post
Haven't had any issues yet, been a few months on the 6 and never really had any leakages for the last few years with my 5. Did you miss the oring that goes in the small screw cap for the shock seal orings?
Not where it's leaking from..it leaking from the O ring shock shaft area..it could be "operater error"..but I doubt it..over the last year I've built 3 full sets of Durango shocks..2 full sets of Losi 22 shocks..2 sets of Associated 12mm shocks and NONE of them have leaked..and none of the above cars were as expensive as the RB6. .so I'm a bit dissapointed to have to buy a shock rebuild kit for a brand new car..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 12-14-2013, 04:28 PM   #8958
Razathorn's Avatar
I've built quite a few k shocks and I never had any leaks. That's pretty strange.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-14-2013, 05:01 PM   #8959
Tekin makes nice stuff.... Orion is really good too. I'm sure you won't regret making the switch. I don't even have a program box...once its set up, you just run the thing and it rocks.
Glad you got your RB6 working good .
sir_thomas is offline   Reply With Quote
Old 12-14-2013, 05:08 PM   #8960
Originally Posted by Oasis View Post
Anyone having issues with their shocks leaking ? My front bottom seals leak..not just a little..I built them per kit instructions..green slime..I have never had so many problems with shocks..put new O rings in also and they still leak...
Sometimes the o-rings get pinched and it sounds like the shock shaft o-rings are fine since you replaced them and still have the issue. I'd replace the outer shock cartridge o ring. If it's not that....then last thing to do is check plastic internal spacers and replace those...perhaps a bad mold.
I believe it's this....without looking it up in a manual.
http://www.amainhobbies.com/product_...ock-Seal-Set-4
Just to make sure........where is it leaking? Down the shaft or by the threads where it screws into the body?
Old 12-14-2013, 05:09 PM   #8961
Can I use the losi 22 topshaft for the rb6?
I'm using avid slippers on my 22 and I took it off and didn't fit the stock rb6 due to the shaft is fatter..
I just don't want to take my 22 apart and not knowing it will fit lol.. aka lazy
iMarky is offline   Reply With Quote
Old 12-14-2013, 05:51 PM   #8962
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Isn't there an oring that goes inside the little cap the helps push the white piece against the orange orings? I missed it on one of mine when building, caught it before I filled them cause it was the one left over piece I had, I did notice it made the little cap fit much looser.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-14-2013, 06:06 PM   #8963
nickdawg18's Avatar
yea, I've had time to sit here and think about it. I like the way I have my electronics setup, so I'll give the tekin stuff another shot. I think those pistons I bought from sk is going to really help out with the chassis slap issue.
Nick Carroll
Old 12-14-2013, 07:27 PM   #8964
Do you guys use the shim for the kick plate for indoor clay track ?
Old 12-14-2013, 07:35 PM   #8965
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default No Shim
No I do not use the shim ...
Johnn27 is offline   Reply With Quote
Old 12-14-2013, 07:38 PM   #8966
Oasis's Avatar
It's leaking from the O ring area..the O rings are fine..it's the bushings that I think are the problem..one of the guys at my track had the same problem..
Old 12-15-2013, 06:42 AM   #8967
nickdawg18's Avatar
Is everyone running saddles? Or are shorties the way to go?
Nick Carroll
Old 12-15-2013, 07:05 AM   #8968
Trader Rating: 82 (100%+)
Most people don't run the shim.
Check out the "spacer" field right next to the caster.
http://www.petitrc.com/setup/kyosho/...UltimaRB6.html
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 12-15-2013, 09:18 AM   #8969
Shorties are lighter and smaller which gives you more options with the weight distribution.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-15-2013, 09:54 AM   #8970
Razathorn's Avatar
I run saddles all the way back with the motor brace shaved since our track can become quite slick. Whatever I miss in performance when it's high bite (watered well), I make up for when its slick. Depends on your track conditions.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
