    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-10-2013, 11:11 AM   #8911
B00t13g's Avatar
Originally Posted by K_King View Post
Yeah pretty close
Thank you.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-10-2013, 04:35 PM   #8912
biggerT's Avatar
Originally Posted by kes7u View Post
Please correct me if I'm wrong, but doesn't that chart indicate that B-out is RF2?
B-out kit setting rf2 as I see it
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 12-10-2013, 05:34 PM   #8913
gelshocker's Avatar
Ok this is confusing.
Aren't 'RF2', 'RR2' essentially 'wide'?
UMW514 and UMW515 are 'aluminum wide RF/RR suspension holders'. But according to the chart one uses out-Cs for 'wide'.
UM508C is the gear box set tree, which comes with both narrow and wide plastic hangers.
So which is 'wide' as we know it, out-Bs or out-Cs?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 12-10-2013, 05:52 PM   #8914
Trader Rating: 91 (100%+)
Wide as we know it from the RB5 is c-out.
The the wide hangers in the rb6 kit are not as wide as the previous rf2.
To duplicate the wide kit hangers run b-out.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 12-10-2013, 06:25 PM   #8915
Originally Posted by iMarky View Post
so im build my shocks and i notice that the ball shocks dont fit tight/snug is this normal ?
also comes with that crappy plastic nut to hold the shocks..
my losi 22 had a nice snap/tight snug fit but still moved around with no binding ...
exotek makes some really nice delrin shock ball mounts for the rb6. they make em in red alloy too, but i prefer the black delrin ones:
http://www.exotekracing.com/rb6-shock-post-set/
glenng is offline   Reply With Quote
Old 12-10-2013, 06:32 PM   #8916
nickdawg18's Avatar
Trader Rating: 33 (100%+)
yea, all that talk about the rear hangers has me confused as well. I think i'll just go with the exotek set.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-10-2013, 06:34 PM   #8917
Miller2's Avatar
Default Kyosho Sell Out
KYOSHO SELL OUT RB6 MID AND REAR MOTOR SCR-SP + PARTS LOT
Miller2 is offline   Reply With Quote
Old 12-10-2013, 06:55 PM   #8918
gelshocker's Avatar
I think changes have been made with the RT6 kit.
Kyosho RT5 | RB6
Old 12-10-2013, 06:59 PM   #8919
gelshocker's Avatar
Thanks!
Kyosho RT5 | RB6
Old 12-10-2013, 10:11 PM   #8920
nice thanks for the advices guys..
also i did my shocks now that the ball holder on the top is flatten down i still have play back and forth is that normal ? some guy at the track said its suppose to have back and forth play so the shocks work better
might put and O ring rubber so it wont slide back and forth
iMarky is offline   Reply With Quote
Old 12-10-2013, 10:17 PM   #8921
VenturaDC's Avatar
Trader Rating: 32 (100%+)
After using a metal washer and metal nut my shocks maybe have 1-2mm of play to slide front to rear, anything less then that I could see causing some slight binding, if its just a little bit of movement and the shocks still rotate around the ball then you'll be fine. Taking out all the play will give you issues.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-10-2013, 10:50 PM   #8922
i see.. yeah im getting about 1/2mm of play.. i dont want it too tight/bind.. ill fix that.. seems like 1/2mm of play is a lot.. for me that is..
Old 12-10-2013, 11:15 PM   #8923
gelshocker's Avatar
To each their own but I only use metal ball at the bottom of the front shock only, where it goes through the a-arm. To minimize wear and tear.
I prefer to use plastic nut at the end of the top tower screw, so when I crash I'll rather the nut give way than broken shock top (happened before). I wouldn't recommend nylocks at all. JC makes a tree of 3mm plastic lock nuts. Cheers,
Kyosho RT5 | RB6
Old 12-11-2013, 09:54 AM   #8924
Trader Rating: 24 (100%+)
Last night I decided to fix one of my RB6s as a part broke. Instead I decided to switch one out to mid motor. I do OK with rear motor, but I am not consistent and loop out a lot. Im sure a lot of it is practice. I figured it couldn't hurt to check it out though and it may suit me. I'm running a Tekin RS with 13.5 turn Tekin Gen 1.
First test is going to be Roar regionals this weekend.
jamesbernatchez is offline   Reply With Quote
Old 12-12-2013, 04:50 AM   #8925
nickdawg18's Avatar
I have my tekin esc mounted exactly like you do. Do you have a problem with the stock body rubbing the capacitor?
Nick Carroll
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
