    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 12-09-2013, 09:30 PM   #8896
E73
E73's Avatar
Originally Posted by codeman View Post
Thanks guys!
What's everyone using for servo's in the kit? I'm looking to run it in mid-motor configuration, and make use of my stash of 3x 2S LiPO saddle packs. I've seen from pictures guys are mounting the ESC at the very back behind the battery, and using a low profile servo up front with the receiver tucked in right behind it.
With my current 1/10 buggy I'm using a standard size servo, but it's a 4WD kit. Any of you using a standard size servo and running a Futaba 4PLS have any pictures of electronics placement? Makes it easier to plan out what you want to buy in one go
Just switched over to mid-motor 17.5 blinky with the following components:
servo: XP DS1015 (full size)
receiver: Sanwa RX471
ESC: Orion R10 Pro
Layout is very similar to Tebo's with a shorty battery in front of the ESC. MM is much faster/responsive than RM for me. Only problem I have to figure out is how to correct some vicious oversteer/twitchiness.
E73 is offline   Reply With Quote
Old 12-09-2013, 10:47 PM   #8897
Nice, thanks for the pic E73. I'll be carrying over the Orion R10 Pro, Orion VST2 6.5T and perhaps this Savox full sized servo, but I'm toying with getting rid of all the Savox stuff I have.
Kyosho MP9 TKI3 || FX Royal 5K w/2108 || Futaba 4PLS || Futaba S9352HV servos
Yokomo B-MAX4 III || Orion VST2 6.5T || Orion R10 Pro || Futaba 4PLS || Savox servos
codeman is offline   Reply With Quote
Old 12-10-2013, 01:24 AM   #8898
B00t13g's Avatar
Originally Posted by Johnn27 View Post
You can use the rear blocks to change the track width of the car as well as the toe.
For example you can run 3.5 but run a narrower or wider rear track width.
Using track width you can widen the rear of your car and it increases rear grip and high speed steering.
Narrowing it is increases rear grip on tighter turns. It also induces a bit of high-speed understeer.
I have tried both and run Tebo's set up which is in the middle of the adjustment spectrum.
I appreciate your answer, but that wasn't exactly what I was asking. What are the narrow and wide equivalents with the standard 3 degrees of toe when using the adjustable hinge pin mounts?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-10-2013, 01:31 AM   #8899
KalEl63's Avatar
I think this may answer your question.
I hope it does for you
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 12-10-2013, 04:54 AM   #8900
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Does the exotek rear hangers use the adjustable bushings or the delrin suspension balls?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-10-2013, 06:51 AM   #8901
rpboggs1's Avatar
Trader Rating: 19 (100%+)
The ones I have use the delrin balls. But I might have an older version though.
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 12-10-2013, 07:06 AM   #8902
nickdawg18's Avatar
Hmm. I'd rather have the adjustable inserts. I guess I'll just go with the kyosho ones.
Nick Carroll
Old 12-10-2013, 07:08 AM   #8903
MikeXray's Avatar
Trader Rating: 73 (100%+)
No the extoek ones use the delrin inserts only, you have to buy the set of hangers you wish to run, ie narrow front/rear or wide front/rear. They are really solid though and fit perfect.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-10-2013, 08:00 AM   #8904
nickdawg18's Avatar
Thanks mike, which ones do you think would be better suited for high bite carpet and clay? Midmotor.
Nick Carroll
Old 12-10-2013, 08:03 AM   #8905
MikeXray's Avatar
I prefer the wide mounts on our high bite clay track, it gives more on power steering, I would get the UM521 or 521-1 arms as well.
Old 12-10-2013, 08:20 AM   #8906
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
RF is C-in
RF2 is C-out
The new hangers for the RB6 are B-out
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-10-2013, 09:33 AM   #8907
B00t13g's Avatar
Originally Posted by K_King View Post
RF is C-in
RF2 is C-out
New meaning right in the middle or what? Thanks man!
Mackenzie Meyercord
Old 12-10-2013, 10:02 AM   #8908
MikeXray's Avatar
See the attachment
Old 12-10-2013, 10:07 AM   #8909
K_King's Avatar
Yeah pretty close
Old 12-10-2013, 12:06 PM   #8910
Please correct me if I'm wrong, but doesn't that chart indicate that B-out is RF2?
kes7u is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22981 Today 04:29 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
