    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-09-2013, 01:41 PM   #8881
Razathorn's Avatar
Originally Posted by codeman View Post
Hey guys looking to get one of these RB6 kits.
Are there any immediate upgrades and spares that you would recommend? I'm looking for a relatively low maintenance kit to run (read: high quality, durable) and I like the layout and shocks etc. of this kit and of course... it's a Kyosho so it will perform.
Would like to buy the kit plus any upgrades and a few spares right off the bat.
The only thing I've broken is a rear hub and a rear shock shaft (from a hard hit from another car). As for worn out, the rear outdrives are the first part I had to replace for wear outside of shock o-rings.
Get the clear grooved o-rings btw, the stock ones are beyond horrible.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-09-2013, 02:23 PM   #8882
Holmberg418's Avatar
The stock ones are not horrible. Just make sure you use some good grease when building the shocks.
Kyosho America, Lunsford, Stickit1racing, Jconcepts, JTP
Full Throttle R/C Raceway www.ftrcr.com
510 Raceway
Holmberg418 is offline   Reply With Quote
Old 12-09-2013, 02:35 PM   #8883
...or if you read this thread from beginning to end, note all of the recommended upgrades, skip a couple of car payments & can't drive your way out of a paper bag you could order:
1x KYO30068B Kyosho Ultima RB6 1/10 2WD Competition Electric Buggy Kit
1x KYOUMW703 Kyosho Titanium Screw Set (RB6)
1x MIP12141 MIP C-CVD Kit (RB5/RB6)
1x PRO3398-00 Pro-Line 2012 BullDog 1/10 Buggy Body (Clear) (RB6)
1x PRO3416-00 Pro-Line Phantom Clear Body Tamiya 201XR/XM/Kyosho RB6
1x JCI0132 JConcepts High Clearance Kyosho RB6 Wing (6.5" Wide) (2)
1x KYO96641 Kyosho 3x5mm Shim Set
1x KYOLA206-76 Kyosho 48P Spur Gear (76T)
1x KYOUMW707 Kyosho Aluminum Rear Suspension Holder (Mid Motor)
1x KYOUMW702 Kyosho RB6 Aluminum Steering Crank Arm Set (Gunmetal) (2)
1x GHEA8114 GHEA RB5 12mm Delrin Tapered Shock Pistons (4) (4x1.3 Hole)
1x KYOORG03XR Kyosho P3 Grooved Low Friction Shock O-Ring (8)
1x KYOUMW701 Kyosho Aluminum Steering Plate (Gunmetal)
1x KYOUM720B Kyosho High Strength SP Front Suspension Plate (Type-B)
4x KYOW0145GM Kyosho 3x7x1mm Aluminum Washer (Gun Metal) (6)
2x KYOW0143GM Kyosho 3x7x3mm Aluminum Washer (Gun Metal) (6)
1x KYOW0142GM Kyosho 3x6x2mm Aluminum Washer (Gun Metal) (6)
1x KYOLAW32 Kyosho Special Suspension Bushing (8)
2x KYOW0144GM Kyosho 3x7x2mm Aluminum Washer (Gun Metal) (6)
1x KYOUMW708 Kyosho Rear Stabilizer Set (Mid Motor)
1x KYOLA253 Kyosho Rear Axle Spacers
1x JCI2251 JConcepts RB6 Precut Chassis Protective Sheet
1x LNS36102 Lunsford "Super Duty" Kyosho Ultima RB6 Titanium Turnbuckle Kit w/Ball Cups
1x MIP12158 MIP Kyosho Super Diff Ball Differential Kit
1x KYOUMW509GM Kyosho SP Motor Plate (Gunmetal)
1x KYOUMW705 Kyosho Aluminum Rear/Front Rear Suspension Holder
1x KYOUMW704-0 Kyosho V2 0° Aluminum Rear Hub Carrier Set (Gunmetal)
2x KYOUM712 Kyosho Front Suspension Arm Set
2x KYOUM710 Kyosho Front Bumper
1x KYOUM721 Kyosho Front Suspension Mount Block (Type-B)
2x AKA23202W AKA Racing "HEXlite" 2.2 Front Wheel (White) (2) (B4.2/RB6)
2x AKA23101W AKA Racing "HEXlite" 2.2 Rear Wheel w/12mm Hex (White) (2) (B4.2/RB6/22)
1x TSR Kyosho Ultima RB6 / RT6 / SC-R Series Gear Diff Conversion with Shims
1x KYOVZW424 Kyosho Steel Differential Bevel Gear Set
1x KYOLAW42 Kyosho Aluminum Servo Horn (Gunmetal)
2x KYOUM521-1 Kyosho SP "Type B" Middle Suspension Arm Set
1x KYOXGS013 Kyosho Big Bore Rear Shock Spring Set (Gold/Medium) (2)
1x KYOW5015 Kyosho Short Big Bore Shock End Set (4)
1x KYO97038 Kyosho Medium Big Bore Shock End Set (4)
1x 1261 Exotek RB6 ALLOY DIFF NUT
1x 1263 Exotek RB6 CARBON FRONT TOWER
1x 1262 Exotek RB6 REAR MID MOTOR CARBON TOWER (M)
1x YRG084 Yaiba Racing Front Bulkhead Team Kyosho RB6 Buggy
2x Rude Bits RB6 Acetal Idler gear
1x AVD1020-TOP-KYO Avid RC Triad Kyosho Aluminum Topshaft
1x AVD1020-STK Avid RC "Stock" Triad Slipper Clutch (72T/76T)
kineteks is offline   Reply With Quote
Old 12-09-2013, 03:01 PM   #8884
lol holy crap kineteks, nice list! I definitely won't be buying everything from that list :P But an awesome resource for good hop-ups though, dang!
Kyosho MP9 TKI3 || FX Royal 5K w/2108 || Futaba 4PLS || Futaba S9352HV servos
Yokomo B-MAX4 III || Orion VST2 6.5T || Orion R10 Pro || Futaba 4PLS || Savox servos
codeman is offline   Reply With Quote
Old 12-09-2013, 03:05 PM   #8885
Trader Rating: 48 (100%+)
your going to have a hard time mounting those rims on the car. get the avid longer axles and make it easier.
Great list also why yalba front bulkhead and not Exotek?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-09-2013, 03:43 PM   #8886
Razathorn's Avatar
I beg to differ, they're the worst o-ring / shock setup I've ever felt—hands down. I went to rebuild my shocks and replace some month old clear grooved ones with the stock ones that originally came with my kit that I never used and the brand new stock ones were WAY more sticky than my old clear ones. I just put my old clear grooved ones back in and bought some new ones.
Grease doesn't last. Those stock o-rings are fertilizer grade poop in my opinion.
Wayne
Old 12-09-2013, 03:51 PM   #8887
Low profile nuts from Fastener Express seem to work pretty well, I haven't tried the JC lo-pro flanged nuts yet. The Yaiba part is actually a lower "front suspension mount block" and, as far as I could see, not offered by Exotek. It's like the Ghea GHEA8008AL... but red!
Old 12-09-2013, 03:55 PM   #8888
...are the orange grooved O-rings poop-grade too? They're not leaking yet but I'll change to the clear ones next rebuild if that's the way to go.
Old 12-09-2013, 04:08 PM   #8889
Thanks guys!
What's everyone using for servo's in the kit? I'm looking to run it in mid-motor configuration, and make use of my stash of 3x 2S LiPO saddle packs. I've seen from pictures guys are mounting the ESC at the very back behind the battery, and using a low profile servo up front with the receiver tucked in right behind it.
With my current 1/10 buggy I'm using a standard size servo, but it's a 4WD kit. Any of you using a standard size servo and running a Futaba 4PLS have any pictures of electronics placement? Makes it easier to plan out what you want to buy in one go
Old 12-09-2013, 04:43 PM   #8890
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
The clear are the smoothest and more prone to leaks, swelling and faster rebuilds. The orange versions last longer and are less smooth.
The stock ones are simply made so that people don't have to worry about their shocks all the time.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-09-2013, 04:54 PM   #8891
Afun's Avatar
Trader Rating: 19 (95%+)
Whats wrong with Yaiba?
Afun is offline   Reply With Quote
Old 12-09-2013, 05:15 PM   #8892
Default gear diff
...for those who have built the gear diff with steel gears.... with the outdrives shimmed so that the cross pins just slide into the holes but do not bind the outdrive (cross pin snug against the large diameter backing shim)... very little if any free play, and the backing shims on all four satellite gears... using the sealing gasket... the diff binds up when the screws are just snug. Leaving out the satellite gear shims is a little better but feels tight & really "notchy"... ditto leaving out one of the large diameter backing shims (which I know you would not want to do, but just to get some idea of how bound up it is). It's acting like it needs two gaskets to get enough clearance to run free. Any suggestions?
The gear diff is just to mess around with as I'll probably always run a ball diff but having never run one in a 2wd buggy I thought it'd be interesting. Assuming I can get it set up right.
Old 12-09-2013, 05:17 PM   #8893
"What's everyone using for servo's in the kit?"
I'm using a Futaba Lo-pro S9551.
Old 12-09-2013, 06:48 PM   #8894
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Thanks guys!
hitec 7955tg at 7.4 volts
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-09-2013, 07:16 PM   #8895
MikeXray's Avatar
Trader Rating: 73 (100%+)
I don't remember exactly what shims I left out, but I agree with your findings, the diff smoothed out after running it.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
