    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-08-2013, 04:05 PM   #8866
trickedyfz450's Avatar
nickdawg18 " I think im gonna try 29° of caster this weekend to tame the steering. Has anyone tried 34° of caster? Is it way too much?"
When you say you have too much steering is it more entering a turn or mid to exit? I found a better balance with my rb6 is to lengthen the front camber link to the middle hole with 1mm inside and outside. It took a little away from initial but gave me more mid to exit.
I have tried 30 degrees of caster before and thought the car got lazy up front. I haven't tried 27 degrees yet but have been wanting too.
Bumps And Jumps Rc
trickedyfz450 is offline   Reply With Quote
Old 12-08-2013, 04:06 PM   #8867
so im build my shocks and i notice that the ball shocks dont fit tight/snug is this normal ?
also comes with that crappy plastic nut to hold the shocks..
my losi 22 had a nice snap/tight snug fit but still moved around with no binding ...
iMarky is offline   Reply With Quote
Old 12-08-2013, 04:31 PM   #8868
VenturaDC's Avatar
Trader Rating: 32 (100%+)
I had to use metal nuts with small washer, it squeezes to ball to a perfect fit
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-08-2013, 06:13 PM   #8869
Originally Posted by Razathorn View Post
Flat arms are "firmer" than the kit gull wing arms. The biggest difference is how they roll less in the corners and allow you to corner harder. If you are on a track that has anything resembling traction, you want the flat arms. IF you are constantly on low traction, the kit arms may be better.
On our track, most of us use flat arms. I've tried both and honestly it just feels like you're running a much lower roll center if you run the kit arms. It's just a tuning aid.
The reason the arms do this (in my view) is the difference in progression. Gull wing arms are like laying the shocks down, flat arms are like standing them up.
If you want to run the flat arms (UM521-1), you will need to run the short shock eyelet end and ream out the 'hinge pin capture' on the outside of the arm with a reamer. Takes like just a few twists and it's done. Then use 2mm spacers on each side of the outer hinge pins before the nuts. Alternatively you can purchase the right hinge pins for those arms and get some 1.5 head capture screws, but that requires you buy stuff, so nobody I know does that.
Wayne
You might try going up to 24mm in the rear if the track is that slick.
Good info thanks, changing brands gotta learn all the ins and outs of the Kyosho
purple rides is offline   Reply With Quote
Old 12-08-2013, 06:40 PM   #8870
Razathorn's Avatar
I'm of the opinion that you should use caster to tune high speed or "total" steering only. "Tameness" is really more of a "initial turn in" type of thing, and that is best adjusted via front camber and front roll center in my opinion.
A lower front roll center will smooth out the responsiveness and aggressiveness of the steering. It will also add some low speed steering mid corner (while you're already deep in the turn and want as much steering as possible to prevent pushing).
Zero front camber gives the most responsive steering. More negative camber makes the car far more plush and smooth up front. -2 is about the most I run ever. In most cases, I run -1 and go up or down a half or whole degree to fine tune initial steering.
I would suggest picking the caster that gives you the most net steering for your layout. From there, add negative camber or lower the front RC (lower link 1mm on spindles or raise 1mm at inside brace) to smooth things out. It's a very reliable way to get a good balance of the best of both worlds.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-08-2013, 06:55 PM   #8871
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I already have the camber link on the front bulkhead in the middle hole. I'm gonna try 29* and see what happens. If it doesn't change I'll go to 2mm under the bulkhead ball stud.
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-08-2013, 06:57 PM   #8872
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Would lowering the roll center with dropping the front hinge pin holder work as well? I have it in the car now but cannot run it until tuesday. Gonna have a tune day and this is one thing I wanted to try (dropped it 1 mm from stock setup with no shim).
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-08-2013, 07:00 PM   #8873
nickdawg18's Avatar
I'm running on a carpet track, mid motor, shorty. When I would go into a fast turn the body would roll hard. I never lost traction but I'm sure the inside wheels were close to coming off the track. A lower roll center would help fight this?
Nick Carroll
Old 12-08-2013, 08:28 PM   #8874
Razathorn's Avatar
No. Roll center adjustments are most effective when your car is starting to roll and least effective when it is already rolled. Roll center is basically the leverage the outside wheel has to pull the chassis over via the camber link and acquire more weight on the outside wheel. If your inside shock is already fully extended, your car is done rolling until it traction rolls. A lower roll center will only cause it to arrive there sooner. Now, a HIGHER roll center, which will produce less roll, MAY keep the car from fully rolling till later, but generally speaking, total roll at the extreme is a function of shock limiters (or sway bars, which are obviously not applicable here).
Wayne
Old 12-08-2013, 10:15 PM   #8875
Mxpdx's Avatar
[QUOTE=iMarky;12795642]so im build my shocks and i notice that the ball shocks dont fit tight/snug is this normal ?
Yes. You want the shocks to have a little play in them. This way they don't bind. Also don't replace the plastic nut with metal.
Kyosho RB6~Orion
Yokomo B-MAX2 Ver3
Mxpdx is offline   Reply With Quote
Old 12-08-2013, 11:39 PM   #8876
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Any rumors about an updated rb6,anytime soon?
lagcisco is offline   Reply With Quote
Old 12-09-2013, 12:39 AM   #8877
B00t13g's Avatar
What are the wide and narrow equivalents when using the mounting blocks with the plastic inserts? For instance, tebos worlds setup calls for a/ b outside what is that besides 3.5 toe?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-09-2013, 03:54 AM   #8878
Johnn27's Avatar
Trader Rating: 69 (100%+)
Thumbs up Track Width
You can use the rear blocks to change the track width of the car as well as the toe.
For example you can run 3.5 but run a narrower or wider rear track width.
Using track width you can widen the rear of your car and it increases rear grip and high speed steering.
Narrowing it is increases rear grip on tighter turns. It also induces a bit of high-speed understeer.
I have tried both and run Tebo's set up which is in the middle of the adjustment spectrum.
Johnn27 is offline   Reply With Quote
Old 12-09-2013, 06:53 AM   #8879
VenturaDC's Avatar
[QUOTE=Mxpdx;12796759]
Why do you say that? I've been using metal nuts on the shocks for 2yrs with my rb5 and now the last few months with the 6, it lets me tighten up the top enough to get rid of the excessive slop, the still move like butter and feels way more consistent.
Old 12-09-2013, 01:18 PM   #8880
Hey guys looking to get one of these RB6 kits.
Are there any immediate upgrades and spares that you would recommend? I'm looking for a relatively low maintenance kit to run (read: high quality, durable) and I like the layout and shocks etc. of this kit and of course... it's a Kyosho so it will perform.
Would like to buy the kit plus any upgrades and a few spares right off the bat.
Kyosho MP9 TKI3 || FX Royal 5K w/2108 || Futaba 4PLS || Futaba S9352HV servos
Yokomo B-MAX4 III || Orion VST2 6.5T || Orion R10 Pro || Futaba 4PLS || Savox servos
codeman is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Tom87
