    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 12-05-2013, 08:21 PM   #8836
Originally Posted by ovalracer1m View Post
Yes, I personally run this same servo. Been running the same servo for 2 yrs and is still going strong in 2wd buggy
ok thanks...
also guys what the benefit of using the straight rear arm and not the stock gull wing arm? might just add it to my cart but it says it requires to use a rear hub for it.. will the stock hubs work or i have to get that rear hub ?
thanks
iMarky is offline   Reply With Quote
Old 12-05-2013, 09:11 PM   #8837
fullout's Avatar
Send a message via MSN to fullout
Originally Posted by DJGray17 View Post
yeah I was talking about the rear rear suspension hangers. The new ones with the inserts. I will be getting both wide and narrow.
there is one front and two rear susp. blocks depending on mid or rear motor. There is no wide and narrow ones with inserts. The inserts are used to adjust if you want wide or narrow plus toe can be adjusted also
Daniel Weinstein
Xray T4 15, Xray XB8 14, Xray XB4 14, Kyosho TKI 3, Kyosho RB6, Sanwa M12
rcamerica.com
performancehobbies.ca
orcarc.com
fullout is offline   Reply With Quote
Old 12-05-2013, 09:19 PM   #8838
DJGray17's Avatar
Ok I just realize that. lol This is what happens when you have to study for all these exams. Thanks fellas! my brain needs a rest
// Xray // Reds // Proline Racing // Boca Bearings //Ogio // BDB Designs// ByronFuel// Futaba //
DJGray17 is offline   Reply With Quote
Old 12-05-2013, 09:56 PM   #8839
ben73's Avatar
Trader Rating: 40 (100%+)
Originally Posted by KalEl63 View Post
Chees for that and I am guessing they are a direct fit and I won't need to do anything else?
if you want to use the JC wheels and remain legal to IFMAR standards and also keep the same width as the standard rims here is what you need to do
Front
- with the standard RB6 axle you need to bevel at 45 deg the plastic spindle so the wheel does not rub. 30 seconds with the dremel and a sanding drum on the outside edge of the spindle.
you need to run the plastic cone shim inside and also another .3mm shim between it and the bearing inside also. on the outside I have a .2mm shim. this keeps you legal and allows the JC wheel to run without interference
Rear
- with JC wheel that rear track is 2mm narrower. use either a TC wheel hex spacer of 1mm each side before you put the wheel on or use UMW523GM wide hub
ben73 is offline   Reply With Quote
Old 12-06-2013, 03:36 AM   #8840
KalEl63's Avatar
Ok thanks for that.
So I am now guessing after Goggling and also searching this thread there isn’t a front and rear wheel that is a direct fit without some messing around?
Not even AKA or DE Racing wheels?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 12-06-2013, 05:34 AM   #8841
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Ok thanks for that.
So I am now guessing after Goggling and also searching this thread there isnít a front and rear wheel that is a direct fit without some messing around?
Aside from the stock wheels, no not really.
The aka fronts for Kyosho are pretty close to a direct fit, but it's the rears that aren't. Need to used a low profile wheel nut instead of the stock one, and then you're pretty much good to go.
I heard that on the new AKA wheels, they made some changes, but I haven't got them yet to be sure.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-06-2013, 06:36 AM   #8842
Trader Rating: 48 (100%+)
Just get the Avid axles and be done with it.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 12-06-2013, 06:47 AM   #8843
That'll work too. Know a few guys that have done that.
Me, I'd just go with the LP wheels nuts and use the cash I just saved my self for more wheels and tires. LOL.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 12-06-2013, 10:10 AM   #8844
MikaR's Avatar
Less than a month for the rtr, what do you think?
MikaR is offline   Reply With Quote
Old 12-06-2013, 12:24 PM   #8845
jk3
Hey guys I know this has been said a hundred times but what is the diff in handling in the stock rear arms and the flat rear arms thanks Jimmy..
jk3 is offline   Reply With Quote
Old 12-06-2013, 12:42 PM   #8846
I was wondering the same thing. I got a rb6 on order for my son for xmas
purple rides is offline   Reply With Quote
Old 12-06-2013, 01:04 PM   #8847
Razathorn's Avatar
Flat arms are "firmer" than the kit gull wing arms. The biggest difference is how they roll less in the corners and allow you to corner harder. If you are on a track that has anything resembling traction, you want the flat arms. IF you are constantly on low traction, the kit arms may be better.
On our track, most of us use flat arms. I've tried both and honestly it just feels like you're running a much lower roll center if you run the kit arms. It's just a tuning aid.
The reason the arms do this (in my view) is the difference in progression. Gull wing arms are like laying the shocks down, flat arms are like standing them up.
If you want to run the flat arms (UM521-1), you will need to run the short shock eyelet end and ream out the 'hinge pin capture' on the outside of the arm with a reamer. Takes like just a few twists and it's done. Then use 2mm spacers on each side of the outer hinge pins before the nuts. Alternatively you can purchase the right hinge pins for those arms and get some 1.5 head capture screws, but that requires you buy stuff, so nobody I know does that.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-06-2013, 01:18 PM   #8848
Barney's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to Barney
Originally Posted by K_King View Post
Tebo is back with Kyosho for another 5 years
WOOHOO
CANTRELL's RAIDER Family Racing '65 Ford Falcon 347 '64 Ford Falcon 412w SST BELLGATE
AE B5,B5M,B44.2,B44.2.5,B44.3,RC8,RC81.5,RC8.2. KYOSHO RB6,RT6,ZX5 FS2 SP,ZX6,TKI3. ZXfactor2, 3.
MUGEN MBX5,MBX7,MTX4,MTX5. TEAMC TQ8,TQ8E. JCP BJ4. YOK YZ10. JAKES PRO-AM RC Topeka,KS
Barney is offline   Reply With Quote
Old 12-06-2013, 01:26 PM   #8849
jk3
Default Short V.S. Long
So since I run on a slick track with no traction the kit arm should work better, And seeing how I ran them back to back the night before last I did like the stock arms better,seemed like it was more consistant since the track is preety slick..
Old 12-06-2013, 01:35 PM   #8850
Razathorn's Avatar
You might try going up to 24mm in the rear if the track is that slick.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
