    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-01-2012, 10:59 AM   #871
Energyzer's Avatar
Thanks for the replies guys! Guess i'll get mine this week, so i can test it on weekend.
Cheers
Energyzer is offline   Reply With Quote
Old 10-01-2012, 10:59 AM   #872
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Right, the stock plastic hubs are 0*.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-01-2012, 10:59 AM   #873
Originally Posted by Rfury View Post
I have always ran 0* on my RB5 and the car is amazing.
MY primary concern is rear side bite and transitioning of the car through tight sections. I hope it is nothing like the 22 and has rear side bite and isn't lazy on its transitions.
Same here I have the 0* on my rb5 and it's is planted and feels great...and so far I have not found a problem getting the car (rb6) to transition and navigate through tight sections.
I saw that tebo ran the rb6 with the 0* before the super nats.
Bluehills315 is offline   Reply With Quote
Old 10-01-2012, 11:12 AM   #874
Trader Rating: 23 (100%+)
How does this car drive compared to the 22? Any 22 drivers try one yet? I think im going to get one but I dont see myself getting rid of the 22. I think I just want two buggy's is that ok lol?
chevmaro is offline   Reply With Quote
Old 10-01-2012, 11:15 AM   #875
Rfury's Avatar
My 22 always felt lazy. My hope is the RB6 does not feel that way.
Yes, Tebo ran the stock hubs (0*) at the Hot Rod Shootout before the Nats.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 10-01-2012, 11:23 AM   #876
That being said, are you going to try the 0* first or jump straight to the .5*?
Old 10-01-2012, 11:29 AM   #877
Rfury's Avatar
My plan when I get one is to build it straight out of the box and change only the shock oils to what I think might work locally(32.5F/27.5R).
I will also try whatever setup Tebo is running at the time as well. I will adjust off of which ever setup feels the best and get it right for me and my local tracks.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 10-01-2012, 11:30 AM   #878
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Originally Posted by goin2drt View Post
Well first time out and car was awesome. Got lucky all the Kyosho guys were at the track so I got some help. Started with the Tebo WCRC set up. Car was dialed.
Issues. Didn't have the long ball studs and grub screws. Bad move. 2 laps stripped. Replaced that, put in long ball studs and good to go.
Also couldn't ge the slipper adjusted right. Needed to compress the spring more, scrub up the slippers with scotch brite and good to go.
Had a blast and was running faster than my old B4.1. Car is very durable. Plenty of short bus poundings and no issues.
Next time out just need to solve for a little more steering and I will be golden.
Enjoy and don't forget those long ball studs.
What size shock ends did you use by chance for the front and rear? When I looked at Tebo's setup, I could not achieve 27mm in between the bottom of the shock and the rod end on the rear. The rod end could not screw on far enough. Any help???
Thanks,
Brad
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 10-01-2012, 11:31 AM   #879
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default RB6 race video
first race
http://www.youtube.com/watch?v=_CyC1...ature=youtu.be
fastestwon is offline   Reply With Quote
Old 10-01-2012, 11:44 AM   #880
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Posvar View Post
Iv'e been waiting for this post for days............
Originally Posted by aloksatoor View Post
Cool looking fwd to your reviews
X100!
Brandon is very comprehensive.
Thanks guys, I do my best to pass on anything I learn or figure out about the cars and/or gear I run. The RB6 will be no different.
Originally Posted by Derry View Post
Ryan says it's life changing.
Building mine when I get home from work today. Longest day of work EVER!!!
I talked to Ryan last night, and the details about his first runs were enough to get me to pull the trigger. I'm excited
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-01-2012, 11:46 AM   #881
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Are the kit shock ends the "short" ones? Part number KYOW5015?
thanks
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-01-2012, 11:54 AM   #882
Originally Posted by fastestwon View Post
Might help to point out which car is yours....
Gitsum is offline   Reply With Quote
Old 10-01-2012, 11:57 AM   #883
Super Moderator
What is the benefit of running the .5* rear hubs? Is there a specific purpose for this?
The .5 rear hubs take the car from 3 degrees of rear toe-in, to a total of 3.5. The more rear toe-in you run, the more resistance is applied to the car being able to rotate through a corner. It locks the rear end to the track because the right rear tire is trying to push the car to the left, while the left rear tire is trying to push the car to the right. In general, when you increase your rear toe-in, you get the following:
1. More rear traction everywhere (corner entrance, mid, and exit, and forward traction)
2. Less steering everywhere (corner entrance, mid, and exit, and forward traction)
3. Slightly less acceleration and top speed as you now have a larger slip angle with your rear tires
4. Slightly less corner speed
Use more rear toe-in (.5s) on looser tracks where the rear end might be too loose, or too unpredictable
Use less rear toe-in (0s) on higher traction tracks where the rear end feels too locked
- RCSpecialties -
Old 10-01-2012, 11:58 AM   #884
savageboy69's Avatar
Trader Rating: 88 (100%+)
looks like you had a little on power push?
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 10-01-2012, 11:59 AM   #885
Moderator
Posvar's Avatar
It's the car in the front with the weird looking cab forward body.
Still getting used to the stock body.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
