    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-04-2013, 03:09 PM   #8821
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by KalEl63 View Post
So that would be the Avid RC Kyosho HD Long Rear Axle Conversion?
Also do you know what the part number for the wheel nuts would be if I went that route?
Would Proline Velocity front and rears be a direct fit or will they need the longer axle?
cheers for the help guys
http://www.amainhobbies.com/product_...eel-Nut-Blue-4
Those or something like those would be what you'd need. If you go with the avid axles, you can use the stock nuts
Proline rears need either of the above to work,
the Proline fronts need to either be used with the RB5 front Hex/axles or have a little bit of material remover around the wheel hex to clear the RB6 axle hexes, as the RB6 front hex is shallow and the Proline wheel is deeper. Doesn't take too long to get the clearance needed of you don't want to go the RB5 front hex/axle route.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-04-2013, 03:10 PM   #8822
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I use these for all of my wheels, KYO1-N4045F. Low profile nut that is serrated on the backside to grip the wheel.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-04-2013, 04:41 PM   #8823
Trader Rating: 22 (100%+)
Originally Posted by Teufel Racing View Post
[url]
Actually, the stock RB6 axle can be adjusted using the axle spacers. I just moved the thicker inside spacer to the outside and the thinner one to the inside. This does increase the track width a tad.
+1 on serrated nuts. Locknuts will loosen over time. I have never ever had a serrated nut come loose. Ever.
littleZEN is offline   Reply With Quote
Old 12-04-2013, 04:49 PM   #8824
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www3.towerhobbies.com/cgi-bin...?&I=LXCCUU&P=7
These work great on every 4mm axle car I got ( sct410, xb4, rb6, touring car, vta car). Got like 3 bags of them and I am set for life. Use an impact driver on the stock kyosho axles. If you got aluminums or titaniums would avoid impacts but for the stock steel works great! No need for that long axle.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-04-2013, 05:21 PM   #8825
KalEl63's Avatar
lots of good info and help which is appreciated.
I think I will go the JC wheels and just try the KYO1-N4045F nuts (black ones)
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 12-05-2013, 08:59 AM   #8826
CanyonCarverR1's Avatar
Default MIP Pucks syste
Anybody using the MIP Pucks system? Are you liking it?
CanyonCarverR1 is offline   Reply With Quote
Old 12-05-2013, 10:04 AM   #8827
aloksatoor's Avatar
I put it in. Definately lighter. Haven't gotten a chance to race it yet since the indoors not open yet and outdoors shut down cos of rain. Shaves around 10 grams I believe from stock drivetrain. So I spend my time lightening my rigs haha.
My stock RM rtr car is around 1477grams with shorty, 14GA wire, HW Jusstock, Ti screws, MIP Pucks, slipper eliminator, aluminum rack, aluminum front holder, aluminum bulkheads , and a trinity motor which shaves a few more grams off!
Old 12-05-2013, 10:09 AM   #8828
this servo will fit/work fine?http://www.rcplanet.com/Savox_Digita...avsc1251mg.htm
iMarky is offline   Reply With Quote
Old 12-05-2013, 12:48 PM   #8829
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Originally Posted by iMarky View Post
Yes, I personally run this same servo. Been running the same servo for 2 yrs and is still going strong in 2wd buggy
Noah Mattocks
ovalracer1m is offline   Reply With Quote
Old 12-05-2013, 06:28 PM   #8830
DJGray17's Avatar
Did some testing last night at my local hobby shop last night. I was running the narrow plastic suspension plate and it was money on my last layout. I put the wide suspension plastic plate on and my rear end was kinda swinging like mike tyson. My car was faster though. I am buying the aluminum rear plates. What bushing are you fellas using in the aluminum plates?
// Xray // Reds // Proline Racing // Boca Bearings //Ogio // BDB Designs// ByronFuel// Futaba //
DJGray17 is offline   Reply With Quote
Old 12-05-2013, 06:42 PM   #8831
Super Moderator
Kraig's Avatar
Do you mean aluminum rear suspension hangers? If so which ones are you getting? The newer ones with the inserts that can be changed or the older ones? If it is the older ones you will want the white delrin bushings, check the first post for part numbers. If it is the newer ones then the steel ones that came with the kit will work.
Old 12-05-2013, 07:10 PM   #8832
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Tebo is back with Kyosho for another 5 years
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 12-05-2013, 07:16 PM   #8833
DJGray17's Avatar
yeah I was talking about the rear rear suspension hangers. The new ones with the inserts. I will be getting both wide and narrow.
Old 12-05-2013, 07:39 PM   #8834
nickdawg18's Avatar
Trader Rating: 33 (100%+)
What kind of track are you running on?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 12-05-2013, 08:11 PM   #8835
DJGray17's Avatar
hard packed dirt. Bumpy Track.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
