    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 12-03-2013, 10:53 AM   #8806
biggerT's Avatar
Originally Posted by nickdawg18 View Post
My plan with the buggy is to start with the box setup but I figured since i'm going to be running on a smooth carpet track that right off the bat I'm going to put in yellow front springs and red rear springs 30wt losi in the front and 25 losi wt in the rear. Mid motor setup. with the avid slipper setup. I havnt got an aluminum steering setup yet, what do you guys reccommend?
Have a look at the chris slevin Silverstone set up on petit dude I use it with a bit less weight in the car and red rear springs instead of yellow you'll need lazer fs rear arms though with an extra inner hole put in
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 12-03-2013, 11:54 AM   #8807
Razathorn's Avatar
I've never ran on carpet with my rb6 mid motor, but on medium grip dirt, I run losi 30 front and 25 rear with pink fronts and gold rears. I am going to wager an educated guess that the increased grip of carpet and (OR!) stiffer springs is going to demand thicker oil than I run. I bet you'll be on 35/30 when you're done.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 12-03-2013, 12:50 PM   #8808
biggerT's Avatar
Bit thicker 40/30 seems the sweet spot 4/1.3 ghea pistons gonna try +10% pistons in the rear next time out with 27.5 see if the balance is still there
Old 12-03-2013, 01:12 PM   #8809
Trader Rating: 20 (100%+)
Originally Posted by krawlingxj View Post
There's a reason it's your 6th car. Love my kyosho 10 x more than my b4.
6th car? All my 2wd 4wd 1/8 have been k cars!! A b4 and a yokomo were my first 2 cars!! So idk where your gettin ur info from at all if you do know me then take it up with me at the track everyone knows I know how to tune/drive/and maintain my cars down to the last bolt!! The 6 is not a consistent car!! I was the last one standing when all the others sold theirs!! If your not on a hooked up track. It's not consistent!! Just stating the facts on my side. I can't speak for everyone else on here. Just not my type of 2wd
toyota 2jz is offline   Reply With Quote
Old 12-03-2013, 02:02 PM   #8810
1967rs's Avatar
Trader Rating: 55 (100%+)
Originally Posted by aloksatoor View Post
I ordered it and cancelled it soon after. Can you post pics once you have yours. Its good for a mid motor car but I run mine RM so wanted to see a racers rig rather than the factory pics .
I have one, it looks like it should work just fine for both rear and mid motor. The body looks a lot like a stealth aircraft (have not decided if that is a good or bad thing) the dorcial fin is just odd looking.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
[email protected]
1967rs is offline   Reply With Quote
Old 12-03-2013, 04:05 PM   #8811
aloksatoor's Avatar
Trader Rating: 42 (100%+)
hahah I would like it I think, I like the FTW one for the b4.1 it looks kick ass so this seems the closest.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 12-03-2013, 04:10 PM   #8812
KalEl63's Avatar
Originally Posted by Chris-s View Post
Strange that you are cracking the wheels. I have wheels that are over a year old now and have been used multiple items. What glue are you using and if you are removing the tyres, how are you doing it?
I remove the tyres with acetone and use muchmore tyre glue. Nothing different from when I had my TLR cars.
Not that I am super annoyed at it. Just would be nice to get more than one run out of a wheel though as Kyosho parts are not the easiest to get in a hurry in Australia
It is perfectly normal to crack the inside bead of a wheel--its the weakest part. Wheels don't last forever. When I go to soak tires off wheels to reuse wheels, it's normal that fronts sometimes are not reusable. Its less common on rears. I've had this happen on every brand of wheel.
Yeah it is mainly the front ones for me too but I stripped 3 sets of rear wheels yesterday and 3 out of the 6 wheels have cracks in them
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 12-04-2013, 10:29 AM   #8813
ecpete's Avatar
Trader Rating: 39 (100%+)
Originally Posted by ecpete View Post
I run MM and I just ordered the RF and RR Rear Suspension Holders. What letter bushings should I use to gain more rear traction? Thanks
Should I run Narrow or Wide? What Bushing should I use?
Team Mugen Seiki - www.Mugenracing.com
Mugen Seiki MBX7R
Pierre Kiti
ecpete is offline   Reply With Quote
Old 12-04-2013, 10:38 AM   #8814
Razathorn's Avatar
It will come with a set of instructions to tell you what pills are the stock RF2 mounts. Work from there going more narrow for more low speed grip in corners, or leave the track width relatively the same and just add a half degree of toe-in for a little more on power traction.
Old 12-04-2013, 10:41 AM   #8815
ecpete's Avatar
Thanks for the advice!
Mugen Seiki MBX7R
Pierre Kiti
Old 12-04-2013, 11:27 AM   #8816
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Ha ha,
Your post just made go and look at that sheet as I just recently switched to the adjustable blocks. Never paid attention to what their reference was for. Always learning something. Though their chart had me stumped for a bit and now taking another look at the sheet after your post, it makes a lot more sense.
Just for fun I set mine up with the A pill in the RF and in-C for the RR in MM, with .5 hubs. Seems pretty good so far. Was going to go with the A pills in both the RF and RR just to be middle of the road so to say.
There's no lack of adjustments with the adjustable mounts. Almost too many. LOL.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 12-04-2013, 11:28 AM   #8817
aloksatoor's Avatar
Run the jconcepts mono wheels thenbit cheaper for the Aussie guys from tower hobbies with intl discounts. The rears are a bit wider but the fronts line up correct. Never broken a front fro m that brand.
Old 12-04-2013, 01:44 PM   #8818
KalEl63's Avatar
Chees for that and I am guessing they are a direct fit and I won't need to do anything else?
1.21 GIGAWATTS!!!
Old 12-04-2013, 02:37 PM   #8819
biggerT's Avatar
Just a shorter wheel nut or avid axels
Old 12-04-2013, 02:57 PM   #8820
KalEl63's Avatar
So that would be the Avid RC Kyosho HD Long Rear Axle Conversion?
Also do you know what the part number for the wheel nuts would be if I went that route?
Would Proline Velocity front and rears be a direct fit or will they need the longer axle?
cheers for the help guys
1.21 GIGAWATTS!!!
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
