    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-28-2013, 10:40 AM   #8761
Johnn27's Avatar
Trader Rating: 72 (100%+)
Originally Posted by klimag View Post
Hello
I'm just building the RB6 and have an issue with the small place for the servo (normal size) and the steering arm touch the the front "upper plate"
I know from earlier read that there is a trick to do there something but cannot find in the long thread. Could you please explain me what should I do there?
I had to dremel that part out really good!
Johnn27 is offline   Reply With Quote
Old 11-28-2013, 11:14 AM   #8762
Originally Posted by Mxer59 View Post
In the kit there should be some little papers with extra updated building separate then what the manual shows. It shows that you have to dermal the right and left side of the top bulk head in two little spots. So that the servo arms clear.
Hope this helps
I got my kit in august and didnt recall the extra paperwork. Did they do a running change to update the top piece? Because i dont think i bind. But maybe i should check it out
glenng is offline   Reply With Quote
Old 11-28-2013, 01:17 PM   #8763
nickdawg18's Avatar
Trader Rating: 33 (100%+)
also, what are some pinion numbers i need to buy when i buy the rb6? 30-35???
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 11-28-2013, 02:34 PM   #8764
Thanks to all of you for the answers - I made enough clearance for the steering with removing some material from the upper plate
sorry I would have other question joing to the previous post - which pinion to start?
On Saturday my daughter will run the RB6 in stock class (13,5) race and we will have no time to try anything before as I will be just ready. The track is high grip carpet and very techical with several jumps. The biggest pinion I have is 26. I have experience with ZX5 where tipically 19-21 OK. Should we start here with higher touth numbers?
Thanks for your help.
(The pressure is big on me from may daughter to have tecnhically OK buggy .)
klimag is offline   Reply With Quote
Old 11-28-2013, 05:25 PM   #8765
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Blinky 17.5?
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 11-28-2013, 06:25 PM   #8766
gelshocker's Avatar
Hope this helps
This is a known issue and Kyosho have since updated their download PDF manual showing you need to cut off those areas. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-28-2013, 06:28 PM   #8767
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
The last kit I built that area was already changed to clear the steering.
There was a note added in the box about cutting it. Maybe new stock verses old stock.
Cameron Kellogg is offline   Reply With Quote
Old 11-29-2013, 10:11 AM   #8768
The RB6 fired up finally. Is it normal to have free play (free movement) at spur axle? In axial direction about 0.8mm in radial direction around 0,1-02mm.
Old 11-30-2013, 10:17 AM   #8769
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Did you out the .3mm shim in?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-30-2013, 11:51 AM   #8770
Derry's Avatar
Trader Rating: 27 (100%+)
Do you still use the spacer in between the bearings in the new hubs? I notice with the spacer in it seems a little to fat.. The bearings will not seat fully but its close.
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 11-30-2013, 03:31 PM   #8771
Holmberg418's Avatar
You want a little play other wise the bearings might get crushed when you tighten the wheel down
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 11-30-2013, 05:29 PM   #8772
nickdawg18's Avatar
Originally Posted by VenturaDC View Post
Blinky 17.5?
yes. sometimes i run boost too.
i'm making an order at amain and I have no idea what pinions and spur gears i should get.
Nick Carroll
Old 12-01-2013, 12:30 AM   #8773
FallenAllDay's Avatar
+1
Ill be running my new rb6 in 17.5 stock class
Ill be running the tekin rs gen 2 motor an esc and would like to know what gearing i need to run.
Thanks in advance
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 12-01-2013, 12:33 AM   #8774
Originally Posted by FallenAllDay View Post
+1
Thanks in advance
if ur not running avid setup then you get the losi 22 70tooth spur with matching slipper pads and then i like robinson aluminum pro 29-35 pinions
Old 12-01-2013, 01:11 AM   #8775
VenturaDC's Avatar
For boosted 17.5 I run 28\76 on a decently high traction outdoor track. With that gearing I run max boost with a lot of end bell timing as well, and my car is ballistic fast.
For blinky I run 28-34 with the avid slipper and 69 spur.
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bj4racer25
