    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-25-2013, 06:43 AM   #8746
carbons2k's Avatar
Trader Rating: 21 (92%+)
Does anyone know how long the screws are that hold the transmission case together? theyre the real long ones that hold the motor plate to the tranny. Thanks!
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 11-25-2013, 08:23 AM   #8747
Trader Rating: 48 (100%+)
They are 3 x 35
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 11-25-2013, 04:01 PM   #8748
1967rs's Avatar
Trader Rating: 55 (100%+)
Originally Posted by K_King View Post
Hey guys, been really working on my car in MM and weight distribution. I finally found something that is pretty easy to drive, but can turn on a dime if needed as well.
Our track is smooth right now, but can get bumpy, dusty and loose out of the groove.
Here's what I have done to the car to get the battery back as much as possible.
The only thing you need to do is modify the battery braces and shoe goo the RT6 part in place (it fits perfect) unless you want to drill 2 holes for it.
Also here is my current setup.
https://dl.dropboxusercontent.com/u/...Nov%202013.pdf
I did something similar, but I did drill the holes.
Here is something else I am working on.
Thank you, Pemberton Raceworks, Team Tekin, Team Trinity and Sweep Racing USA for your outstanding support to the Military.
www.facebook.com/DoakWorksDesign
D-W-D@comcast.net
1967rs is offline   Reply With Quote
Old 11-25-2013, 04:36 PM   #8749
StupidHead's Avatar
I did the following so I could use a shorty both ways without needing to change anything in the car. The side pods are cut with a couple of foam spacers glued on either side, the motor cover is raised a few mm and I drilled new holes for the battery holder. With foam tape on only one side of the battery strap, changing battery positions is as simple as flipping the strap over and moving the battery.
Please excuse the wiring, I quickly ripped the electrics out of another car to test this out.
--Scott
Kyosho Ultima RB6 & RB6.6 Car Thread-rb61.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rb62.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-rb63.jpg
StupidHead is offline   Reply With Quote
Old 11-25-2013, 05:04 PM   #8750
function>form's Avatar
Trader Rating: 43 (100%+)
Anybody know the part number for the shock cap o ring? It's listed as 162 in the exploded view
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 11-25-2013, 06:13 PM   #8751
yodace's Avatar
R/C Tech Charter Subscriber
I just ordered a rb6. Gonna start with mm. I was wondering what parts and setup to start with ?
yodace is offline   Reply With Quote
Old 11-26-2013, 10:10 AM   #8752
MikeXray's Avatar
Trader Rating: 73 (100%+)
Check out the first post in this thread.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-26-2013, 11:16 AM   #8753
yodace's Avatar
Ok
Old 11-27-2013, 02:23 PM   #8754
biggerT's Avatar
Just an alloy steering rack the main thing yaiba one the cheepest I think and zx5 rear arms some good set ups on petit rc and maybe drop rodgerm a pm he's got a sweet base setup we use on low grip astro and it travels well with small changes most of us use shortys with rudebits holder
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 11-28-2013, 03:51 AM   #8755
Hello
I'm just building the RB6 and have an issue with the small place for the servo (normal size) and the steering arm touch the the front "upper plate"
I know from earlier read that there is a trick to do there something but cannot find in the long thread. Could you please explain me what should I do there?
klimag is offline   Reply With Quote
Old 11-28-2013, 04:21 AM   #8756
So yesterday was the first time I broke a part on my rb6. The ball stud popped out of the c hub, any help in making this not happen again
My Credit Card
Old 11-28-2013, 07:48 AM   #8757
Gayosaka's Avatar
I use a longer ball stud and a bolt on the other side of the hub. Easy!
You can also use a pinion screw (sorry, I don't remember the exact name) to close the unused holes so the hub is stronger.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 11-28-2013, 08:00 AM   #8758
nickdawg18's Avatar
Trader Rating: 33 (100%+)
Originally Posted by klimag View Post
Hello
so your saying that if you wanna use a hitec 7955 servo you have to mod something?
Nick Carroll
Mugen Mbx7-reds r5t team edition 2 [] Mugen Mbx7 Eco-Tekin rx8 gen 2 1900kv [] Losi 8ight T 2.0-fusion x7 [] Losi 8ight T E 2.0-Tekin 2000kv [] Kyosho RB6-Tekin RS gen 2 8.5t [] Losi 22sct
VP Pro USA [] Up-Grade RC
nickdawg18 is offline   Reply With Quote
Old 11-28-2013, 09:03 AM   #8759
Mxer59's Avatar
Trader Rating: 114 (100%+)
Hello
In the kit there should be some little papers with extra updated building separate then what the manual shows. It shows that you have to dermal the right and left side of the top bulk head in two little spots. So that the servo arms clear.
Hope this helps
Mxer59 is offline   Reply With Quote
Old 11-28-2013, 09:37 AM   #8760
E73
E73's Avatar
Hello
I think you're talking about the two "ribs" that run length-wise under the front "upper plate"? My Yaiba steering arms also hit them. Just use a Dremel tool and grind them flush. No harm no foul.
E73 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
