    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-20-2013, 11:02 AM   #8716
Originally Posted by KalEl63 View Post
Well that throws my 2.5mm out and means 1.5mm would give about .25 pro squat
K King Anti squat is where the front hanger is higher than the rear hanger and Pro is where the rear hanger is higher than the front hanger
Where are these images to see?
motor home is offline   Reply With Quote
Old 11-20-2013, 11:47 AM   #8717
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
In this post, Kyosho Ultima RB6 & RB6.6 Car Thread
or click here.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-20-2013, 01:18 PM   #8718
KalEl63's Avatar
Originally Posted by FallenAllDay View Post
Hey guys, ive bought an rb6 and have almost finished the build. Do you guys actually grease the cvd end into the diff outdrive? Wouldnt that just attract dirt and promote wear?? And also in the kits instructions it doesnt say what shock oils run front or rear!? Do you have a base line starting point for me?? The info is much appreciated, im a nitro dude and this is my first electric kit im just wanting to do it right.
I started with 30Wt in the front and 27.5Wt in the rear but I'm now running 32.5Wt in the front with the GHEA 4x1.3mm pistons and like it.
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 11-20-2013, 03:55 PM   #8719
Trader Rating: 24 (100%+)
My two. Just got the new blue one tonight as setup currently:
Blue:
RS Pro
17.5 Tekin Gen 1
Protek 230T servo
Shorty setup
MyLaps
Black:
RS Gen 1
Tekin 7.5 Gen 2
STRC aluminum rear hubs
Jconcepts front hinge pin brace
Exotek steering rack
Savox 1257
MyLaps
jamesbernatchez is offline   Reply With Quote
Old 11-20-2013, 04:27 PM   #8720
skengines's Avatar
Trader Rating: 226 (100%+)
Do I sense a RB6 WC coming soon?
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 11-20-2013, 04:46 PM   #8721
Holmberg418's Avatar
No you don't. Why would they come out with one. There is nothing different besides some aluminum option parts
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 11-20-2013, 05:35 PM   #8722
E73
E73's Avatar
I'm thinking a SCT is next in line….…which is no good because I will have to buy it.
E73 is offline   Reply With Quote
Old 11-20-2013, 05:52 PM   #8723
Hello!
I wish to try running my RB6 in stock class. It was suggested to run an AVID 69 tooth spur and 33 tooth pinion. So upon install, the gears ( I think the pinion) rub on the gear cover. Is there a different gear cover available? Run without (yikes), or change to a different gear ratio setup?
Sorry noob beginner stock racer here.
Mark
mlinder is offline   Reply With Quote
Old 11-20-2013, 06:03 PM   #8724
E73
E73's Avatar
Originally Posted by mlinder View Post
Hello!
Mark
I run 69/31 and it has enough speed and torque for stock 17.5 class and does not rub the cover. Gearing such as you are increases top speed but reduces acceleration (torque) for the infield. Since only a small amount of time is spent on the straight, I suggest you gear down. Doing so will also reduce the temperature of the motor. My .02.
Old 11-20-2013, 06:30 PM   #8725
Thanks for your reply. Makes a lot of sense. I will change the gearing first.
Mark
Old 11-20-2013, 08:18 PM   #8726
Super Moderator
Kraig's Avatar
Hello!
Mark
There is one spot on the gear cover that rubs the gear if I remember correctly. What I did is I took a silver sharpie and colored where the gear cover would cover the pinion gear. I then installed it, turned on the car and gave the throttle a couple of short blips. I then removed the gear cover and I could see where the gear wore the silver sharpie away. I then to a sanding drum on the dremel and lightly went over that area of the cover. I repeated that process a couple of times until the gear didn't rub the cover anymore.
Old 11-20-2013, 10:31 PM   #8727
Trader Rating: 49 (100%+)
Quick question, on a low grip bumpy track should I stick the regular rear arms or try the 521-1 arms? I'm running rear motor
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 11-21-2013, 12:15 AM   #8728
Trader Rating: 6 (88%+)
I've got the same question except I'm running mid-ship...What do the arms do exactly? and do you have to have anything for them to be compatible?
Rcdudes3475 is offline   Reply With Quote
Old 11-21-2013, 07:46 AM   #8729
Jochim_18's Avatar
Originally Posted by MikeXray View Post
Thanks for the list, I have to do more testing with the rear link. In onroad I would do like you said and lengthen, raise it, but so far it seems that lower/shorter has produced more rotation on my car. I do feel that the weight might be transferring too fast, or possibly not enough right now which is why the car gets into the corner well, but then struggles.
Longer link = lower roll center (It will give you more traction overall but you will loose some steering)
Shorter link = Higher roll center (cars is more reactive and rotates better)
Roll center has big impact on how you want the buggy to react in certain section of the track. "You add some you loose some" when changing your roll center. Rule of thumb you want your front and rear roll center as close as possible to have a good balance car...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-21-2013, 07:51 AM   #8730
carbons2k's Avatar
Trader Rating: 21 (92%+)
How do you guys add some weight to the back of your midmotor rb6's?
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
