    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 11-19-2013, 10:38 AM   #8701
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by KalEl63 View Post
I did notice this No.UMW604 Diff Gear Set (ULTIMA SC/DB/RB/RT)
Blade body as well. Also whatever the VVC thing is
Looks like it's a lightweight version body. .06" thick maybe?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-19-2013, 01:42 PM   #8702
UMW718 will be a new aluminum idle gear for mid
nitroargi is offline   Reply With Quote
Old 11-19-2013, 02:08 PM   #8703
K_King's Avatar
What's the benefit to that?
Old 11-19-2013, 03:23 PM   #8704
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Jochim_18 View Post
I measure the height of the hinge pin from the chassis when I shim the rear 2mm it gave me an equal measurement front to rear of the hinge pin giving you 0 degree anti-squat..
I have been fine tuning my TC and the degree of the squat is = to the thickness of the shims..
good to know from someone that has actually measured it. So on your MM setup, you are raising the rear block 2.5mm and also raising the rear bulkhead tower 1mm with the skid shim? So how much spacers are you using between the transcase and the chassis to equal out the height of the assembly?
Noah Mattocks
ovalracer1m is offline   Reply With Quote
Old 11-19-2013, 03:46 PM   #8705
KalEl63's Avatar
From what Iíve been told in MM set ups the extra idler gear adds weakness to the transmission so it would be to strengthen that I would say but could be way off
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 11-19-2013, 07:25 PM   #8706
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Ciao,
KalEl63 is right. I have been running MM since RB6 was out and i snap at least 4 of them.
Best regards,
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 11-19-2013, 08:17 PM   #8707
MikeXray's Avatar
Trader Rating: 73 (100%+)
Any of you who run on carpet or real high grip have tips on freeing up the rear? I'm on the 2nd shortest link in the rear already, turn in is good, but not mid corner.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-19-2013, 11:03 PM   #8708
I don't run carpet but, if you run kyosho wheels with a low profile wheel nut you can add a spacer between the hex and the wheel. Touring cars use them or try wider hex. Try 1mm per side. Big increase in mid corner steer.
Second option would be add a shim under the front lower bulkhead.
Tom87 is offline   Reply With Quote
Old 11-20-2013, 01:04 AM   #8709
Originally Posted by ovalracer1m View Post
Most accurate answer I could find without measuring myself.
From Oople
"Definitely 2deg with no spacers under either RF or RR blocks.
Shims are 0.5mm thick which equates to 0.75deg per shim (1.5deg per mm) - if you want to get really accurate it's actually moves between 0.71 & 0.78deg due to the swept angle changing too but most people use 0.75 without issue"
So I have read where some people say 1mm gives 1 deg and where most say .5mm gives 1 deg.
The statement from oOple is from myself.
How I got to those numbers when I was designing the Scorpion MM RB5 converstion....
Wishbone 32
ball 4
(edge-centre
of ball)
Total width 40
So therefore;
Height Pin angle
difference
-0.5 -0.716
0.0 0.000
0.5 0.716
1.0 1.433
1.5 2.149
2.0 2.866
Hope that helps.
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 11-20-2013, 01:11 AM   #8710
gelshocker's Avatar
Wishbone 32
ball 4
(edge-centre
of ball)
Total width 40
So therefore;
Height Pin angle
difference
-0.5 -0.716
0.0 0.000
0.5 0.716
1.0 1.433
1.5 2.149
2.0 2.866
Hope that helps.
Wow. That's news. So each 0.5mm shim is +/- 0.7 deg? IIRC, Tebo's setup sheets had 0.5mm as +/- 1 deg. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-20-2013, 01:14 AM   #8711
gelshocker's Avatar
Originally Posted by lore View Post
Ciao,
Best regards,
Cheers mate. So I can put off the MM conversion until K releases the steels.
Kyosho RT5 | RB6
Old 11-20-2013, 01:15 AM   #8712
To free up rear on very high side bite surfaces;
Less rear toe (especially useful if done from inboard as also slightly lengthens wheelbase),
Longer wheelbase from rear and/or move centre of mass forward depending on how tight the layout is,
Increase rear oil by 50cst (or 50cst additional over any increase in front oil),
Longer rear link (so rolls slower thus can change direction faster),
Raise inner ball studs BOTH ends of the car (gives the effect of more on power steering which makes the rear feel freer),
Stiffer rear spring (or move lower shock out on rear arm as this gives added benefit of reducing rear droop too),
Reduce overall droop but slightly more reduction in the rear (less roll over all but relatively less in the rear helps rotation),
Take weight out of the car (less force from mass loading the same width tires = less overall grip),
Increase antisquat (less rearward weight transfer under power keeps the front working harder),
Increase rear track width (again best done from inside end as that helps with roll centre placement too),
That is the list of what I do between my normal MM setup and going somewhere like Silverstone which is velcro grippy!!
Old 11-20-2013, 02:21 AM   #8713
FallenAllDay's Avatar
Hey guys, ive bought an rb6 and have almost finished the build. Do you guys actually grease the cvd end into the diff outdrive? Wouldnt that just attract dirt and promote wear?? And also in the kits instructions it doesnt say what shock oils run front or rear!? Do you have a base line starting point for me?? The info is much appreciated, im a nitro dude and this is my first electric kit im just wanting to do it right.
TLR 8IGHT 4.0, OS Speed, Sanwa M12s/Ko servos
KYOSHO RB6, Orion, Sanwa M12s/Ko servo
Powered by my wallet.
FallenAllDay is offline   Reply With Quote
Old 11-20-2013, 05:21 AM   #8714
carbons2k's Avatar
Trader Rating: 21 (92%+)
Does anyone know if a company makes a weight that bolts onto the back of the rear bulkhead for a mid motor setup? Something like the Losi 22
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 11-20-2013, 06:57 AM   #8715
MikeXray's Avatar
Thanks for the list, I have to do more testing with the rear link. In onroad I would do like you said and lengthen, raise it, but so far it seems that lower/shorter has produced more rotation on my car. I do feel that the weight might be transferring too fast, or possibly not enough right now which is why the car gets into the corner well, but then struggles.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
