Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-17-2013, 10:08 PM
  #8686
K_King's Avatar
Trader Rating: 47 (100%+)
Originally Posted by cnelson3
Without filling out a whole set up sheet, the significant changes were:
1. Running c-in/c-in on the new toe blocks
2. 1.5 mm shims under the rear toe block
3. Servo/speedo/shorty battery/[3/4 ounce weight]/motor
4. White rear springs.
The rest of your set up is really personal preference and based on tuning for the tires you use. Keep in mind, to put the 1.5mm under the rear toe blocks, you will need to loosen the 2 transmission screws prior to putting the rear bulkhead back. Also do not run any shims on top of the toe block, your already past the 1 mm the designers allowed for spacing.
I run C-in right now and white rears, have since July or so.
.5mm is 1 degree of Anti Squat right? So you're at like 5 now?
What front end setup, oil, and piston did you run?
K_King is offline
Old 11-17-2013, 10:18 PM
  #8687
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Got the rb6 converted to mm. Can wait to try it out this wknd. Starting setup should have plenty of rear traction on our med traction track, very tight also. We shall see
From how I read the post above, he added 1.5mm to the rear toe block. So he should be at .5 of pro squat
ovalracer1m is offline
Old 11-17-2013, 10:35 PM
  #8688
KalEl63's Avatar
I thought 2.5mm of shimming would give you .5 pro squat
KalEl63 is offline
Old 11-17-2013, 10:39 PM
  #8689
K_King's Avatar
Isn't Pro Squat when you add it to the front block?
K_King is offline
Old 11-17-2013, 10:53 PM
  #8690
If you add to the front block that is anti squat. If you add to the rear, you take away anti squat.
Old 11-17-2013, 10:55 PM
  #8691
Most accurate answer I could find without measuring myself.
From Oople
"Definitely 2deg with no spacers under either RF or RR blocks.
Shims are 0.5mm thick which equates to 0.75deg per shim (1.5deg per mm) - if you want to get really accurate it's actually moves between 0.71 & 0.78deg due to the swept angle changing too but most people use 0.75 without issue"
So I have read where some people say 1mm gives 1 deg and where most say .5mm gives 1 deg.
Old 11-17-2013, 11:01 PM
  #8692
K_King's Avatar
I've always thought of .5 = 1degree as well.
K_King is offline
Old 11-17-2013, 11:08 PM
  #8693
KalEl63's Avatar
From Oople
Well that throws my 2.5mm out and means 1.5mm would give about .25 pro squat
K King Anti squat is where the front hanger is higher than the rear hanger and Pro is where the rear hanger is higher than the front hanger
KalEl63 is offline
Old 11-17-2013, 11:15 PM
  #8694
But, if the rear pin is already angled up, that is preventing squat, hence anti-squat.
If you make that even higher, you're raising that pin angle even more creating more anti-squat, right? So he went from 2, to like 5 (I use the .5mm = 1degree method).
PS AS always confuses me, so any help would be awesome :P
To keep it simple, picture the rear of the car on power/squating and the angle of the hinge pins. When the front pin block (RF) angle up, this is resisting squat. Watch the rear squat on your pit board from a side view and you will see why this is. When you add shims to the back hinge pin block (RR) this is leveling out the hinge pins thus creating less squat resistance creating more rear traction, less on power steering.
Old 11-17-2013, 11:30 PM
  #8695
Edit: I just seen the post at the top of the page talking about this also....
Old 11-17-2013, 11:41 PM
  #8696
K_King's Avatar
Gotcha. Thanks I will try that
Can use a little more grip on my car at my track for sure.
K_King is offline
Old 11-18-2013, 05:05 PM
  #8697
KalEl63's Avatar
Originally Posted by gelshocker
Loads of RB6 parts on the horizon:
http://www.kyosho.com/eng/products/rc/np1310.html
http://www.kyosho.com/eng/products/rc/newparts.html
Hopefully the pistons won't cost a GHEA!
I did notice this No.UMW604 Diff Gear Set (ULTIMA SC/DB/RB/RT)
KalEl63 is offline
Old 11-19-2013, 04:14 AM
  #8698
Trader Rating: 37 (100%+)
if anybody has an extra avid top shaft they would like to sell shoot me a pm. Thanks.
chrisjohns is offline
Old 11-19-2013, 06:21 AM
  #8699
Jochim_18's Avatar
I measure the height of the hinge pin from the chassis when I shim the rear 2mm it gave me an equal measurement front to rear of the hinge pin giving you 0 degree anti-squat..
I have been fine tuning my TC and the degree of the squat is = to the thickness of the shims..
Jochim_18 is offline
Old 11-19-2013, 10:35 AM
  #8700
K_King's Avatar
So .5 is just a small adjustment then. That's pretty cool to know
K_King is offline
