    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 11-14-2013, 06:51 PM   #8641
Originally Posted by bigemike View Post
I see he is running a saddle pack, would the setup work with a shorty or are saddle packs better for mid motor?
You can try a shorty or saddle. I know Joe Pillars likes the shorty but he's running 2.5wt lower shock oil to make up for the weight difference in packs. Shorty feels faster and saddles is a bit more sluggish but easy to drive. You also have to factor in the amount of traction u have as saddles would be better for looser tracks but also good for high grip. Shorty for high grip.
sir_thomas is offline   Reply With Quote
Old 11-14-2013, 07:15 PM   #8642
Jochim_18's Avatar
Originally Posted by rpboggs1 View Post
I was wondering this too... Any suggestions?
Raise the tranny 1mm.. And if you shim the RR hanger 2mm you'll get zero anti-squat..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-14-2013, 07:22 PM   #8643
Jochim_18's Avatar
Originally Posted by K_King View Post
Did he think the gull's provided too much grip then and made him slide around?
I tried the gull wing on mid motor but cars just continues to roll and it doesnt square up fast enough to get in throttle early.. Having a straight arm cars square up faster and levels the car quicker so you can get on the throttle early without the rear getting a little twitchy..
Old 11-14-2013, 09:14 PM   #8644
the big rc's Avatar
Trader Rating: 39 (100%+)
Originally Posted by sir_thomas View Post
Hey fellas, I just wanted to post a setup on 2wdMod.com that was ran by Kyosho/ Team Orion driver, Andy Dibrino. His car was absolutely dialed all weekend. Give it a try and see if you like it. Of course...get the right tires on and adjust ballstud height accordingly.
http://2wdmod.com/2013/11/14/2wd-clo...winning-setup/
Dude I already posted his set up a few days ago on here.
the big rc is offline   Reply With Quote
Old 11-14-2013, 09:22 PM   #8645
gelshocker's Avatar
Loads of RB6 parts on the horizon:
http://www.kyosho.com/eng/products/rc/np1310.html
http://www.kyosho.com/eng/products/rc/newparts.html
Hopefully the pistons won't cost a GHEA!
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-14-2013, 11:34 PM   #8646
All about the love bro
Old 11-15-2013, 05:54 AM   #8647
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
I will guess that those pistons are 2x1.6, 3x1.4 and 4x1.3 since they don't list the size of the holes.
I'll be ordering all 3 once they are available.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 11-15-2013, 02:16 PM   #8648
E73
E73's Avatar
Default 521-1 arms
If I change to 521-1 arms, what other parts do I need? Short shock bottoms? Longer hinge pin? Type-B or B-2 rear hub?
E73 is offline   Reply With Quote
Old 11-15-2013, 02:17 PM   #8649
i dont think you need anything else. i think you just have to readjust shock height and maybe change oil weight?
Jeremy0203 is offline   Reply With Quote
Old 11-15-2013, 02:26 PM   #8650
You can use the RB6 hinge pins, but will need to ream out one end of the arm and use a 2mm spacer on the outside at either end.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 11-15-2013, 05:38 PM   #8651
Also change to the short shock bottoms.
kes7u is offline   Reply With Quote
Old 11-15-2013, 05:59 PM   #8652
Default Spur gear
Who make a 66 tooth spur gear for the RB6?
Sorry if this was mentioned before, I could not find it,
bleubyu is offline   Reply With Quote
Old 11-15-2013, 06:33 PM   #8653
E73
E73's Avatar
Avid
http://www.amainhobbies.com/product_...-Spur-Gear-66T
Old 11-15-2013, 06:47 PM   #8654
skengines's Avatar
Trader Rating: 226 (100%+)
You will need to Triad Slipper though.
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 11-15-2013, 06:49 PM   #8655
Default spur gear
Does that gear require the Avid pads as well? any other things needed? to use this gear? Slipper plates? Slipper pads?
Thanks for your help
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
