    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-12-2013, 01:05 PM   #8611
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by jamesbernatchez View Post
What can I expect coming from Losi 22 RTR? I tossed in a Tekin RS and a Tekin Gen 2 7.5t motor as well as a Savox low pro servo. I plan to swap the electronics in the RB6 I'm getting. I found the 22 to be durable but I fight to drive it well. Part of it was probably setup, but something kept calling me to the RB6.
The package I got was too good to pass up. Anything I should do as soon as I get it? It's new built, never run.
I only drove a few 22's but they all lacked rotation, the RB6 felt a lot more nimble, while still being stable.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-12-2013, 01:54 PM   #8612
Originally Posted by MikeXray View Post
Is Yaiba the only one making a Alum RB6 front hinge pin holder? I would like a heavier brass one, but so far I've only seen rb5 ones.
I got a black alloy from ghea. Ordered from absolutehobbyz in nj. Pricey but nice. And not red. I also noticed amain has ghea brass piece for the rb6 too
***pardon, amain has ghea8002 which is for rb5, as mentioned. Sorry
glenng is offline   Reply With Quote
Old 11-12-2013, 02:01 PM   #8613
MikeXray's Avatar
can anyone confirm the Rb5 sp2 had the narrow front hinge brace like the Rb6? that is what I'm not sure on, I know the regular Rb5 one is wider.
Old 11-12-2013, 02:17 PM   #8614
aloksatoor's Avatar
Trader Rating: 42 (100%+)
No its a different part. Mid way between the rb5s widest one and the rb5 sp2 narrowest one. The part number is UMW7 something, the 7 implies RB6 only so it was never there for the RB5. Another happy camper with the ghea bulkhead, have had it since it launched about 4 -5 months ago. I dont need the bendy front hinge pin brace as well with a full aluminum piece, just sawed off the extra hinge pins sticking out.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 11-12-2013, 04:08 PM   #8615
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by Razathorn View Post
Flat arms basically change the progression of the rear--similar in fashion to standing the shocks up significantly more. The rear will be firmer and have less roll.
The basic idea when I tried them back to back with gull wing arms was that you could hammer out of corners better with the flat arms. I didn't notice any real loss in traction unless it was in a place that I didn't need traction anyway, such as giving me rotation that I didn't know I wanted
I also did sway bar testing with flat and gull arms and honestly, the flat arms were very similar to running gull wing arms with various sway bar options, but it felt more consistent through the corners with the flat arms.
Wayne
I always thought standing up rear shocks helped entry steering, but then would give up steering in the middle and up off it would feel squiggly. Always felt like it would apex then the angle wouldnt know what to do and transfer weight too fast side to side.
Seemed like vertical rears wear only good for exit, but it killed entry and center too much.
With flat arms I thought they enter pretty well, but would keep the rotation all the way through the corner and exit, almost causing a snap effect. The gull wings seem a lot tamer overall.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 11-12-2013, 05:00 PM   #8616
Razathorn's Avatar
Standing shocks up or going to a stiffer spring should add steering everywhere, unless of course you mean steering from the rear end washing out on power, which is not something I like my cars to do
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 11-12-2013, 05:54 PM   #8617
K_King's Avatar
Right, which is why Im curious why you said you can punch it coming out, to me the rear is a lot freer with the flat arms.
Old 11-12-2013, 06:24 PM   #8618
Razathorn's Avatar
Ahh, I can see the confusion. It's basically fixing the situation where you have too much chassis roll. If you have too much chassis roll when exiting the corner on power, the car can loop out out because it "over rolled" and the tire contact patch went away. Basically, with a higher roll center, stiffer rear springs, or these flat arms, you're giving up a little low speed grip for corner exit stability once the weight is transferred and you're hard on power. This may not always be the right decision, especially if you're seriously lacking grip.
Tebo is one of our locals and his comment on the arms to the local kyosho club racers was that the flat arms let him take corners harder. He mentioned to me when he saw I was testing the gull wing arms vs flat arms that I might want to step up in shock oil when using the gull wing arms. He also mentioned to another local that he didn't think everyone would like the flat arms. Most of the locals are running the flat arms at our track, but our track isn't every track. I personally feel that the loss in low speed grip is well worth the ability to drive the car much harder.
Wayne
Old 11-12-2013, 06:48 PM   #8619
K_King's Avatar
Did he think the gull's provided too much grip then and made him slide around?
Old 11-12-2013, 09:17 PM   #8620
Wayne
Hey Wayne,
Do you have any pics with the sway bars fitted on the flat arms? Did you use the RB6 optional sway set? I have one but I can't seem to figure out how to mount them to the flat arms...
nitroargi is offline   Reply With Quote
Old 11-12-2013, 10:02 PM   #8621
Razathorn's Avatar
I really have no idea. He just mentioned the shock oil thing to me--the cornering hard thing he said to a another guy. I wasn't there for that conversation.
Old 11-12-2013, 10:09 PM   #8622
Razathorn's Avatar
Originally Posted by nitroargi View Post
Hey Wayne,
http://www.rctech.net/forum/showthread.php?p=12571478
I don't run the sway bar now. Whatever it gave me in ability to over-drive the car, it wasn't worth the lack of low speed traction.
Old 11-12-2013, 10:50 PM   #8623
Trader Rating: 19 (100%+)
Does anyone else run the flat arms in rear motor?
I tried it for our inter club cup we have on our clay track (with a good dose of sugar and PVA), and as said by others noticed it was a nice improvement.
Rotated more freely, the rear tracked around with the front whereas I felt the gullwing arms didn't want to rotate.
Was different to drive and took a few minutes to get used to though, I found the strong points were the weak points of the gullwings and vice versa.
I did notice the rear seemed more plush/softer, I put on a Losi LF Pink spring and am about to up the shock oil as well.
Also the camber link rubs on the spring, so I shaved a side of the ball cup and using the rearward holes on the alu hubs.
I also found it hooked in some corners a little (just low speed ones), so I just removed the spacer under the ball stud on the rear and made it one hole longer, seemed to have solved it mostly.
I run most of the jap setup with just a couple of tweaks.
Ended up coming in 2nd in the B-Main I believe (I'm not that fast a driver, bout 3 seconds a lap off the leaders on average).
Waiting for the rear holders to come in stock to try out mid motor.
Shimmy is offline   Reply With Quote
Old 11-13-2013, 06:12 AM   #8624
MikeXray's Avatar
You make a good point about the front brace, since that is one reason I wouldn't have wanted an odd sized block, if I can't find new braces. (I somehow ended up with 3 different sized ones already), but if its not needed, that would be a plus.
Old 11-13-2013, 06:37 AM   #8625
kenny lutz's Avatar
Trader Rating: 36 (100%+)
I just switched to mm and I was I spaced the rear hinge pin holder 2mm up. So should I raise the tranny up 1mm or 2mm? Thanks for the help
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
