    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 11-11-2013, 03:35 PM   #8596
KalEl63's Avatar
Originally Posted by Jochim_18 View Post
MM SETUP FOR LOW TO MEDIUM TRACTION WET TRACK
Here what's I have been running at my local track... You can't use setup on a track that have traction with MM buggy more than likely you are not gonna have forward bite when you run the same setup on a track that have low traction. I have been running MM since the losi 22 came out and learn a lot how to properly setup a MM buggy.. I got the base setup posted at petit rc for kyosho RB6..
I will have to give this a go myself but just wondering what you did with the shim between the bulkhead and hanger?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 11-11-2013, 07:50 PM   #8597
gelshocker's Avatar
I'm pretty sure 1mm = 1 degree... I shim the RR suspension hangers 2mm and made the hinge pin straight flat which give 0 anti-squat... RB6 has 2 degree stock anti-squat..
ok.. I recalled from the RB5, so maybe the RB6 is different. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-11-2013, 07:59 PM   #8598
gelshocker's Avatar
Thanks for sharing. On a technical question, how do you raise the entire transmission 1mm? Do you use 1mm shims under the transmission, and raise the tower with +1mm shim (between bulkhead and RR hanger)? Thanks,
Kyosho RT5 | RB6
Old 11-11-2013, 10:25 PM   #8599
Jochim_18's Avatar
Yes you put 1mm shims under the transmission and 1mm shims between the bulkhead and shock tower..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-11-2013, 10:30 PM   #8600
Jochim_18's Avatar
Originally Posted by Razathorn View Post
I just use jared's setup and I tend to win.
I always use tebo as a base setup and I just fine tune from their to suite my driving style..
Old 11-12-2013, 03:16 AM   #8601
jelly's Avatar
interesting setup. quick questions what direction do you have the steering rack and how does it go in mod?
jelly is offline   Reply With Quote
Old 11-12-2013, 07:44 AM   #8602
MikeXray's Avatar
Trader Rating: 73 (100%+)
Is Yaiba the only one making a Alum RB6 front hinge pin holder? I would like a heavier brass one, but so far I've only seen rb5 ones.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-12-2013, 11:40 AM   #8603
biggerT's Avatar
GHEA have what your looking for dude I use a rudebits shorty trey and hitec 7940 up front no other weight needed better than saddles or tranverse shorty
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 11-12-2013, 11:47 AM   #8604
the big rc's Avatar
Trader Rating: 39 (100%+)
Hey everyone. I just posted the winning set up from this weekends Pacific NW Showdown from team Kyosho/Orion driver Andy DiBrino. Team manager Joe Pillers and Andy worked all weekend on the set up and Andy totally dominated the best in the NW. It wasn't even close.
The track is packed clay indoor, and the mid motor was completely dialed
Here is a link to the set up http://www.thebigrc.com/?p=5070
I also have a video of A2 and you can see it wasn't even close. Here is the video http://www.thebigrc.com/?p=5069
8 of the 10 in the A were Kyosho mid motors!
I myself ended up bumping into the B, but the car was dialed unlike my head.
the big rc is offline   Reply With Quote
Old 11-12-2013, 12:18 PM   #8605
Trader Rating: 37 (100%+)
whats the advantage to running the flat arms opposed to the gull wing arms?
chrisjohns is offline   Reply With Quote
Old 11-12-2013, 12:33 PM   #8606
MikeXray's Avatar
I can't seem to find the brass one anywhere, its listed on their site "GHEA8008" but not for sale, I see the alum one, but it's $45, for that much I'd like brass, thanks.
Old 11-12-2013, 01:31 PM   #8607
David Home's Avatar
See here....
http://p-dubracing.co.uk/index.php?m...roducts_id=281
David Home is offline   Reply With Quote
Old 11-12-2013, 01:37 PM   #8608
Trader Rating: 24 (100%+)
What can I expect coming from Losi 22 RTR? I tossed in a Tekin RS and a Tekin Gen 2 7.5t motor as well as a Savox low pro servo. I plan to swap the electronics in the RB6 I'm getting. I found the 22 to be durable but I fight to drive it well. Part of it was probably setup, but something kept calling me to the RB6.
The package I got was too good to pass up. Anything I should do as soon as I get it? It's new built, never run.
jamesbernatchez is offline   Reply With Quote
Old 11-12-2013, 02:01 PM   #8609
Razathorn's Avatar
Flat arms basically change the progression of the rear--similar in fashion to standing the shocks up significantly more. The rear will be firmer and have less roll.
The basic idea when I tried them back to back with gull wing arms was that you could hammer out of corners better with the flat arms. I didn't notice any real loss in traction unless it was in a place that I didn't need traction anyway, such as giving me rotation that I didn't know I wanted
I also did sway bar testing with flat and gull arms and honestly, the flat arms were very similar to running gull wing arms with various sway bar options, but it felt more consistent through the corners with the flat arms.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 11-12-2013, 02:03 PM   #8610
MikeXray's Avatar
Originally Posted by David Home View Post
Would only order it from the US, cost way too much for shipping, tax, etc. Thanks though.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22977 11-13-2017 05:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
