    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 11-06-2013, 04:54 PM   #8551
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jochim_18 View Post
I hardly use close cell foam insert for me the buggy gets really too aggressive. Sometime I use it on the front if I want my buggy to have a little more steering but I never use close cell in rear... All our outdoor track is sugar or glued and I still use open cell running slicks tires which you can't do when using close cell foam insert...
For the outdoor tracks like what you mentioned, I've been open cell as well. Figured, if the tires weren't going to last, why spend the extra coin for the closed cells. LOL. They seem to work just fine for me, so I'm good with it.
For indoors, it's a little bit different. The break in for new tires and new closed cell foams (Red AKA) seem to take forever to get them right where they need to be. Was playing with used closed cells, in various stages of wear, and it helped, but could be a little hit or miss for me. Switched up to the open cells and the brake in time, to me, seemed a bit shorter. Not sure how long the open cells will last, but so far they seem to be doing ok. Have been running them on the wheeler more than the 2wd, but do have a few pairs just for the 2wd. I mainly run them for the track conditions when needed. More so just as an option, when I might need that little bit extra grip.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 11-06-2013, 05:23 PM   #8552
I'm running Tebo crcrc setup with Rb6 rear arms and ae tapered 4 hole pistons. The Rb6 is my sons car, I normally run b4.2 in mod class, but was bored and ran stock also. Anybody notice how little droop the rb6 has compared to b4.
msandman is offline   Reply With Quote
Old 11-06-2013, 10:26 PM   #8553
gelshocker's Avatar
Hey guys, what's the difference between various MIP kits? There's 'Kyosho', 'RB6' and 'Pucks'. In various diffs and CVD kits. Thanks,
http://www.amainhobbies.com/product_...fferential-Kit
http://www.amainhobbies.com/product_...emale-Outdrive
http://www.amainhobbies.com/product_...VD-Kit-RB5-RB6
http://www.amainhobbies.com/product_...-RB6-C-CVD-Kit
http://www.amainhobbies.com/product_...6-C-CVD-Bone-1
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-06-2013, 10:29 PM   #8554
Jochim_18's Avatar
The pack version is designed and to be use mainly in stock 17.5 class...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 11-06-2013, 10:48 PM   #8555
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
Does anyone have starting gearing for a 17.5 ? I am running the high torque killshot with 12.5mm rotor
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Old 11-06-2013, 10:49 PM   #8556
skengines's Avatar
Trader Rating: 226 (100%+)
I ran 69/32-33
If you are running 17.5, I would get the Avid Slipper. Provides a lot more gearing options.
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 11-06-2013, 10:50 PM   #8557
bigemike's Avatar
what motor where you running?
I do have the triad already, white,red,white on the pads
Old 11-07-2013, 06:48 AM   #8558
skengines's Avatar
SchuurSpeed 17.5.
Old 11-07-2013, 03:22 PM   #8559
E73
E73's Avatar
69/31 with Fantom Racing Apex 17.5 with 12.5mm high torque. I also have the Triad Slipper.
E73 is offline   Reply With Quote
Old 11-07-2013, 10:19 PM   #8560
Jochim_18's Avatar
I tried closed cell for me the buggy don't have enough traction... With open cell the tire wear is a little higher compared to closed cell inserts... But I'll sacrifice tire wear anytime to gain performance... the only advantage of closed cell is the contour of the tires remains the same throughout the entire run so less wear... Coming from racing open mod in touring car I like traction
Old 11-08-2013, 08:36 AM   #8561
Gary NJ's Avatar
What spacer thickness do I need to run under the RR block to get to 0 degree anti squat? This is on a MM RB6 using the 705 and 707 rear blocks. If I want to try the .5 degree prosquat setting what is the spacer thickness? TIA
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 11-08-2013, 10:56 AM   #8562
I can confirm taht running two black idle gears when in MM configuration will "eat" away the avid shaft and probably the Kyosho one also...is there a fix to this?
I think Kyosho will bring out a metal idle especially for mid but will this be the solution?
nitroargi is offline   Reply With Quote
Old 11-08-2013, 12:01 PM   #8563
After a year running on high grip astro tracks I have seen no wear in the kyosho slipper shaft. I have had two of the idler gears fail shortly after fitting the gear diff, they were a year old and so have had a lot of abuse.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 11-08-2013, 04:34 PM   #8564
I hear ya,
With new tires and new closed cells (AKA), it's hard to get the feel right, until they're broke in/scrubbed in. They are a bit more consistent once you get them to where they need to be, but for me, it always seems to come right about where the tires are almost done, but the foams are perfect. Unless you over sauce them. LOL.
Love all the traction I can get and then some, though, I think on the MM setup, rear traction gains are not as easy to come by when you need it. To the point that the need use of stock foams may be the needed route to go with that setup more often than not. Lots to play with/try, and for sure plenty of things to learn. LOL. Fun either way for me. If being fast was easy, we'd all be the fast racers. LOL.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 11-08-2013, 07:54 PM   #8565
Jochim_18's Avatar
1mm = 1 degree
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22944 Today 12:18 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
