    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-30-2013, 09:50 PM   #8521
gelshocker's Avatar
Originally Posted by Tyler101 View Post
So RB6's out of stock at most of the main online retailers...does that spell an SP coming very shortly or just an increased interest after Tebos world championship. I am looking for a 2nd but in no rush and likely would grab an SP just cause'. I love my RB6 but new and shiny is new and shiny LOL
The RT6 chassis has 2 extra holes for a mid motor battery block piece, which would likely appear on a new RB6 SP chassis. The new ESC mount piece would be included I suspect too. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 11-02-2013, 03:32 PM   #8522
E73
E73's Avatar
Converting to MM. While mounting the gearbox, the rear tab that mounts to the Yaiba rear bulkhead is 1mm too high. When I screw the gearbox tab to the bulkhead the whole drivetrain begins to bind and will not spin freely. Adding the 0.5mm spacers to the RR suspension holder eliminates the problem as it raises the bulkhead to the gearbox. However, I don't want to change the handling dynamics (adding spacers) just to make the system spin as smoothly as it should without spacers. Happens when I use the stock bulkhead too. Any thoughts?
E73 is offline   Reply With Quote
Old 11-02-2013, 04:15 PM   #8523
biggerT's Avatar
You should have a 1mm shim splitting the rr sus mount and the bulkhead if no shim beneath the rr
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 11-02-2013, 07:54 PM   #8524
E73
E73's Avatar
That's a good answer. Thank, buddy!
Old 11-02-2013, 09:21 PM   #8525
DJGray17's Avatar
will the aluminum 0 degree hubs work with the "Type B" Middle Suspension Arm, or do I have to buy the KYOUM519-2 "Type B" rear hubs?
// Xray // Reds // Proline Racing // Boca Bearings //Ogio // BDB Designs// ByronFuel// Futaba //
DJGray17 is offline   Reply With Quote
Old 11-03-2013, 03:43 AM   #8526
KalEl63's Avatar
Just wondering if anyone has tried the car with the 6 chassis screws out, on what type of track and the thoughts of it?
or for that just a combo of screws in/out?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 11-03-2013, 05:15 AM   #8527
Trader Rating: 48 (100%+)
Has anyone tried mm on a low traction surface? Our season is about to start nd need to make decision if I should switch?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 11-03-2013, 05:38 AM   #8528
SAMCRO's Avatar
Yes, mine is dialed. Mine steeped out a bit coming out of turns and I put 2.5mm of shims under the rear inner ball stud and that helped a lot. Also, I run a shorty sideways with some weight behind it
SAMCRO is offline   Reply With Quote
Old 11-03-2013, 07:44 AM   #8529
t8rtot's Avatar
Trader Rating: 14 (94%+)
I understand your reasoning for the question but the whole benefit if running the RB6 is that she's interchange. With your track conditions unknown, tires etc. it only takes 15mins to switch if you build up the other gearbox.
Sfida
t8rtot is offline   Reply With Quote
Old 11-03-2013, 08:27 AM   #8530
biggerT's Avatar
They do on mine dude
Old 11-03-2013, 02:32 PM   #8531
Care to share ur setup?
My Credit Card
Old 11-03-2013, 04:12 PM   #8532
trickedyfz450's Avatar
Hey guys I recently switched from an Associated B4.2 and I have a ton of tires on Jconcepts wheels. I have been running them and they seem to work fine but my question is that the hex depth on the front Jconcepts wheels are deeper then the Kyosho wheels. Am I required to space the axle different to get the same width as running the Kyosho wheels and what handling difference will I feel? I looked thru a few hundred pages and couldn't find any info. Thanks for anyone that helps!
Bumps And Jumps Rc
trickedyfz450 is offline   Reply With Quote
Old 11-03-2013, 05:26 PM   #8533
gelshocker's Avatar
IIRC this was mentioned in this thread and it worked out approx. 0.7mm each side, total 1.4mm? Others please chime in. Cheers,
Kyosho RT5 | RB6
Old 11-03-2013, 06:34 PM   #8534
looking to join the team darn amain is out back order... anyone know a good place to pick one up? not in a rush... i know sales are coming soon.. turkey day.. anyone know a place to order one?
sucks because i have discount at amain
iMarky is offline   Reply With Quote
Old 11-03-2013, 06:55 PM   #8535
there is someone in the for sale forum selling one new in box
Jeremy0203 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
