    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-28-2013, 12:15 PM   #8506
Got a question for you guys. I'm making the switch from b4.2 to a rb6 and I got about a 1000 dollars worth of good tires and I was wondering if I could just switch to the rb6 hexes and put associated hexes?
Madman1 is offline   Reply With Quote
Old 10-28-2013, 12:22 PM   #8507
Miller2's Avatar
If your already running hexes and have the hex wheel you are good to go with your current wheels.
Miller2 is offline   Reply With Quote
Old 10-28-2013, 12:55 PM   #8508
Holmberg418's Avatar
The rear rims work perfectly. Just run locking wheel nuts not nylon. With the front rims you will need to shim them as the ae rims have a deeper hex comparied to the kyosho rims.
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 10-28-2013, 02:00 PM   #8509
Miller2's Avatar
Oh yea I forgot about that part where the wheels would rub. I Actually just moved the spacer from the inside to the outside and problem was solved.
Old 10-28-2013, 04:13 PM   #8510
I use AKA wheels and the AVID longer rear axle conversion.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 10-28-2013, 06:14 PM   #8511
Miller2's Avatar
Haven't seen any new videos from you lately ?
Old 10-28-2013, 07:54 PM   #8512
What shims should you use when you use the losi pistons?
I used the shims from the loss scte diff. They are a perfect fit. The scte guys throw away when they go to the 2.0 diff housings.
AlwaysLOSI is offline   Reply With Quote
Old 10-30-2013, 01:08 AM   #8513
Trader Rating: 82 (100%+)
The b4 and rb6 wheel offsets are not the same. Run the avid long axles so that you can run b4 rear wheels. The rb5 front axles work better than stock rb6 for b4 wheels (wheels would be skinnier though).
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 10-30-2013, 09:01 AM   #8514
So RB6's out of stock at most of the main online retailers...does that spell an SP coming very shortly or just an increased interest after Tebos world championship. I am looking for a 2nd but in no rush and likely would grab an SP just cause'. I love my RB6 but new and shiny is new and shiny LOL
www.rcottawa.com
www.mx101.ca
Tyler101 is offline   Reply With Quote
Old 10-30-2013, 09:16 AM   #8515
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
RT6 production was focused on since the release.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-30-2013, 09:18 AM   #8516
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
im guessing SP as well.
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 10-30-2013, 09:39 AM   #8517
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
If an SP does come out I'm set as my car has all of that on it already.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-30-2013, 01:19 PM   #8518
K_King's Avatar
For 25+4 caster how much shim do I need on the steering?
Old 10-30-2013, 07:35 PM   #8519
MikeXray's Avatar
Trader Rating: 73 (100%+)
I feel like its 1mm for going from 25-30, I don't think there is a shim small enough for 1dg
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-30-2013, 08:53 PM   #8520
cnelson3's Avatar
Trader Rating: 65 (100%+)
are you referring to bump steer? 2 mm and i can't visually see any bump steer as the tire goes up and down as the arm swings. I don't feel any awkward steering either.
cnelson3 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
