    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 10-24-2013, 10:54 PM   #8491
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Derry View Post
How does one reverse ackerman like I am seeing on tebos mid motor setup sheets?
Have the arrow point to the rear of the car while putting together the steering rack.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 10-25-2013, 09:15 AM   #8492
Derry's Avatar
Trader Rating: 27 (100%+)
That's what I figured... Thanks!
Associated B64D
Associated B6D
Derry is offline   Reply With Quote
Old 10-27-2013, 05:27 PM   #8493
Ran car for first time yesterday. Car did really well except turning. It is so slow and sluggish around corners. I wanna be able to whip around the turns like the other buggies. Once I can get that figured out ill br good to go
Jeremy0203 is offline   Reply With Quote
Old 10-27-2013, 07:31 PM   #8494
SAMCRO's Avatar
This car can steer. Sounds like you have the wrong tires...
SAMCRO is offline   Reply With Quote
Old 10-27-2013, 07:56 PM   #8495
tried brand new barcode gold and barcode greens(or blue cant remember).
Old 10-27-2013, 08:35 PM   #8496
Miller2's Avatar
New tires always suck at first. Sand them down to save some break in time. Also sauce them up with some buggy grip. That will help soften the new rubber.
Miller2 is offline   Reply With Quote
Old 10-27-2013, 09:24 PM   #8497
gelshocker's Avatar
Can you share the weight of your car?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 10-27-2013, 10:10 PM   #8498
When will there be a WC version of this car?
zzztech is offline   Reply With Quote
Old 10-27-2013, 10:29 PM   #8499
Holmberg418's Avatar
What shims should you use when you use the losi pistons?
Kyosho America, Hobbywing, Jconcepts, Lunsford, JTP
Full Throttle R/C Raceway www.ftrcr.com
Holmberg418 is offline   Reply With Quote
Old 10-28-2013, 12:41 AM   #8500
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Anyone run a VST 2 8.5? If so are you having issues with lack of initial punch and if so do you run any boost/timing/turbo on it?
Im taking my 7.5 out to put in an 8.5 so I can toss the 7.5 in my truck, but I'm a little concerned that my car may not make a particular jump at our track.
Theres a guy who runs a Centro and a Reedy 8.5 and his car launches over it compared to mine. Its not a weight issue as much as it is a smooth motor issue.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-28-2013, 01:12 AM   #8501
I ran vst1 8.5 for a bit. Geared 23/76 ran upto the second timing line on the motor. I run nosram/lrp esc so the boost was around 20* starting at 7000rpm adding 1* per 1000rpm. Motor timing makes the biggest difference to punch. I do remember the 8.5 felt flat but still jumped fine. I think it's just a really smooth motor.
Since then I have moved to the vst2 7.5 run running no timing and 5* boost 0.4* per 1000rpm. 21-22/76. I find the small part throttle jumping is better with less boost/timing and more motor.
Tom87 is offline   Reply With Quote
Old 10-28-2013, 09:40 AM   #8502
K_King's Avatar
Thanks. Haven't messed with motor timing. Just turbo.
Old 10-28-2013, 10:13 AM   #8503
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Couldn't agree more. I used to run the VST (version 1) stuff, and noticed that I lacked oomph on short run ups. I cheated and switched to Reedy motors, and love them. I might even try an LRP X20 in my 4WD.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-28-2013, 10:37 AM   #8504
aloksatoor's Avatar
I had a couple of the VST versoin 2s. They lack punch compared to the tekin gen2s and the killshots I run now. The killshot 17.5 is almost like cheating with the 57 degree timing set. Runs cool and punchy.
Old 10-28-2013, 11:52 AM   #8505
Lrp x20 motors run hot. No matter what you gear them at always expect the temps to be high.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
05PSD
