    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 10-17-2013, 12:38 PM   #8446
Razathorn's Avatar
Originally Posted by Lonestar View Post
thanks... any idea what kind of grease this is? i dont want to give kyosho another $10 or sp for 3g of generic grease X or Y... lithium or plain jane mechanical grease should do the trick here, shouldnt have to buy specific K products... i m too old for this
thank you
Paul
I think that stuff is just plain old mollybendum engine assembly lube like the AE black grease.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-17-2013, 01:58 PM   #8447
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Why is everybody using gear diffs all of a sudden? Is it because the WC was won with a car that had it hehe? Saw on Tebos blog that seemed like he had a factory part during the WC which he did not have in his rt6 (that got chewed up in a race with mod motors).
So I think kyosho might release a better spec part soon enough if it works well for the champ! I really would not want to put metal gears in my stock buggy so sticking with ball diffs for now.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 10-17-2013, 02:54 PM   #8448
dmayhew25's Avatar
Trader Rating: 14 (89%+)
Originally Posted by dahomie View Post
Hi guys,
I am having issues with these hangers.
I get different toe readings from side to side whatever I do...
With stock plastic hangers I have 3 degree toe in each side.
With either both (in stock B-out configuration) or with only the front (705) or only the rear hanger (707 since I run it mm configured) I get strange readings... 2.5 degrees on one side, 2 on the other, or almost 3 on one side and 3.5 on the other.
HAs any one else seen this issue or even thought about checking? I even had the rear one replaced but also the new one gives the same side to side differences.
Has the C. that makes these for K. had a bad batch, this is not at all up to the Q standard I am getting use to from K...
BTW, my setup station is used for other brands and always shows correct, I have not had this issue ever before on any other car or brand.
To make sure I was not dreaming or doing something wrong I had a friend of mine check his car which only has the fron umw705 hanger on, same differences... Different toe readings for the left and right side there as well and for the record, he used his own setup station for measuring. So now I started to be really confused... Then I try to look at a picture of Tebos car from the WC, neo has a picture taken from above. And looking at this picture it really looks like he has two different toe's as well... might be angle of course but it sure looks like it...
If that was the case for him, the car is capable, in his hands to be World Champion even with different toe angles from side to side which is excellent of course nevertheless this issue is extremely annoying and as mentioned nothing I have experienced before...
Has anyone else experienced this with these part numbers?
I had the same problem you are having. I went back to the stock rear hanger and all is good now. My rear toe with the B out B out block was different from side to side. Measured the hanger and seems to be machined slightly off. Car drove considerable better after going back to stock hanger.
David Mayhew
Team Trinity, RevTech, KSG, BSR Tires, KCR Hobbies, ProtoForm
www.FinishLineSigns.net
www.FinishLineRaceway.com
dmayhew25 is offline   Reply With Quote
Old 10-17-2013, 04:08 PM   #8449
cnelson3's Avatar
Trader Rating: 65 (100%+)
thank you
Paul
I will vouche for the kyosho clear diff grease. I've has considerably better luck with that stuff than ae, losi, and the muchmore stuff i got. Muchmore was a close second but still $10.
cnelson3 is offline   Reply With Quote
Old 10-18-2013, 05:47 AM   #8450
Ostach24's Avatar
Trader Rating: 85 (100%+)
If anyone is interested have a Rb6 for sale here kyosho rb6
Gee buggy rear and mid, just in need of some cash so it's up for sale. Make offers on it.
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 10-18-2013, 05:55 AM   #8451
rpboggs1's Avatar
Trader Rating: 19 (100%+)
I'm pretty sure I'm having an issue with my gear diff too. It's seems fairly smooth and it doesn't leak (knock on wood) but when I punch it from a stop, the car pulls hard to the left. The axles are spin free when the dogbones aren't installed and I even replaced all the bearings in the axles and gearbox just to be sure... and it still pulls. Also weight balance seems to be fairly even... Esc in middle, receiver on right, and esc cap and power switch on left.
Any suggestions?
And by the way, its a midmotor setup with 5000 ae oil in diff.
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 10-18-2013, 02:49 PM   #8452
aloksatoor's Avatar
Any suggestions?
Did you check the rear suspension bind. Rear shock preload, shaft not busted or bent in one shock? The cars gotta squat symmetrically on full throttle otherwise it will be pulling. Front wheels are loose and free correct?
Old 10-18-2013, 04:36 PM   #8453
MikeXray's Avatar
Trader Rating: 73 (100%+)
Anyone come up with a clever way to add a fan in MM? Would like to keep my speedo in the back.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-18-2013, 05:23 PM   #8454
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.liverc.com/news/new_produ...he_Kyosho_RB6/
RCBuddha is offline   Reply With Quote
Old 10-18-2013, 07:11 PM   #8455
spdrac430's Avatar
Send a message via AIM to spdrac430 Send a message via Yahoo to spdrac430
sweet deal exotek on the axles
Tekno, Kyosho, SMC-racing.com, AKA, Avidrc.com, Futaba
Trick Graphics
Heart of a Hustler Racing Team
spdrac430 is offline   Reply With Quote
Old 10-18-2013, 07:19 PM   #8456
stiltskin's Avatar
Trader Rating: 102 (100%+)
My speedo is mounted in the back just forward of the motor. I flipped the battery strap around which opened up a nice hole for a Side Piece Racing fan to be installed.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-18-2013, 09:28 PM   #8457
rpboggs1's Avatar
Good call! Didn't check it out yet but I'll bet the shock mounts are too tight. Hinge pins were free and shocks freshly rebuilt... but I swapped out the retaining nuts on the upper mount and may have overtightened them. And yes the front wheels are smooth and balanced. Thanks for the quick reponse!
Old 10-18-2013, 11:07 PM   #8458
cnelson3's Avatar
has anyone tried mounting the battery all the way back and the speedo in front of the battery in MM? I tried tebo's worlds set up and the back end wasn't nearly as planted as the battery behind the speedo. for clarification, you can run a shorty pack so far back it slides under the motor guard and hits the motor, but i'm not talking that far back. Just the most rearward position using both battery cradles.
I tried it today along with a 1 mm shim below the rear toe block. I'm really surprised by the results. our track gets a little slick sometimes and the mm buggy handled it well.
Old 10-19-2013, 01:27 AM   #8459
That;s the way to go if you run MM on slippery track...you can always use a battery foam spacers between the shorty and the motor in order not to slide back.
If the traction comes up thought you may find the car pushing due to more traction...
nitroargi is offline   Reply With Quote
Old 10-19-2013, 08:00 AM   #8460
cnelson3's Avatar
I thought about that as well. I trimmed my battery strap so i couldn't mount my front battery cradle far enough back to get the battery strap to lock down on the motor guard. This may be something I revisit if the track gets looser but I worry about the pendulum effect it creates.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
