    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-16-2013, 09:16 AM   #8431
Johnn27's Avatar
Trader Rating: 69 (100%+)
Originally Posted by K_King View Post
Anyone tried messing with the toe inserts? Mainly running C in C in to narrow up the rear? If so what did you find it did to the car?
I am testing with that set up. It seems to provide less slide as the car rolls through the center of the corner and more exit traction coming out of a corner. but the car was less stable overall.
Johnn27 is offline   Reply With Quote
Old 10-16-2013, 09:32 AM   #8432
Razathorn's Avatar
Sounds pretty expected as it will increase overall roll, much like a very significant lowering in roll center.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-16-2013, 10:23 AM   #8433
MikeXray's Avatar
Trader Rating: 73 (100%+)
How do you figure its increasing overall roll?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-16-2013, 01:33 PM   #8434
Razathorn's Avatar
Well, it ACTS like more roll, and it should roll a BIT more, but the real change is the change in force against the track at the tire due to leverage change from decreased lever arm distance from the roll center (or just centerline of the car) and the tire contact patch. It will roll more because bringing in the tire brings in the tire contact patch, which if you draw all the "roll center lines" and connections, that lowers the roll center. Also, if you just think about it in terms of the shorter lever arm, much like having a long vs short kick stand on a bike, the short one is easier to tip over than the long one.
Wayne
Old 10-16-2013, 01:34 PM   #8435
Razathorn's Avatar
Originally Posted by SAMCRO View Post
Has anyone tried the rear stabilizer set? I am thinking of ordering one and wanted to get some input. Our indoor track is by no means high bite and can dusty/bumpy so I am not sure if it is worth trying or not...
I tried it, multiple ways with kit and flat arms with multiple bars. It is kinda cool in that it lets you really over drive the car, but it doesn't make it faster and takes away precious low speed traction.
Wayne
Old 10-16-2013, 05:38 PM   #8436
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Peak Racing vantage 7.5 motor - BRAND NEW
Anyone looking for a great motor for cheap?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 10-17-2013, 07:19 AM   #8437
Lonestar's Avatar
Hi All
what's the secret to a smooth RB6 gear diff? I've just built one and it's "grainy", you can basically feel the teeth working against each other... I've built my share of 8th scale gear diffs, but I have to say I'm not an expert in dinky plastic ones. I've used a bit of lithium grease at strategic locations (outdrive, ring, gears) everywhere where there's friction and/or a risk of leaking, I've considerably greased/oil the plastic seal, I haven't overfilled it, blah blah blah, the works, then AE's 3K oil.
And still the thing feels like crap (and it leaks)... Do these things need to break-in or what? I 8th you break them in for a couple of hours to loosen them up, but here it's worst, it really feels wrong...
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-17-2013, 08:00 AM   #8438
offroad dude's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Lonestar View Post
Hi All
Paul
I second this quote. My gear diff leaked all over the place and felt like crap in the car. I just pulled it out an tossed it in the pit bag.....
offroad dude is offline   Reply With Quote
Old 10-17-2013, 08:35 AM   #8439
MikeXray's Avatar
Originally Posted by offroad dude View Post
I second this quote. I gear diff leaked all over the place and felt like crap in the car. I just pulled it out an tossed it in the pit bag.....
One of our locals tried it and said it was good for half a run until it leaked out.
Old 10-17-2013, 08:48 AM   #8440
MikeXray's Avatar
Wayne
To me this description doesn't make sense, but it sounds like you are describing the effects correctly. The leverage points doesn't move with a bar, you are adding a second spring, if you will, which yes, it attached at a different point, but unless you go with a softer spring, the net results is stiffer roll resistance.
Old 10-17-2013, 10:29 AM   #8441
Gayosaka's Avatar
He is not speaking about the antiroll bar but about narrowing the rear end using toe inserts.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 10-17-2013, 10:41 AM   #8442
Razathorn's Avatar
Yeah, I was not talking about the sway bar. Dunno how we got wires crossed there. I was talking about narrowing the rear end.
Old 10-17-2013, 10:49 AM   #8443
Use the Kyosho gear and seal grease KYOXGS151...I put it in the o-rings as well as on the paper seal and I have minimum to no oil in my case
nitroargi is offline   Reply With Quote
Old 10-17-2013, 11:03 AM   #8444
MikeXray's Avatar
My bad.
Old 10-17-2013, 12:20 PM   #8445
Lonestar's Avatar
thanks... any idea what kind of grease this is? i dont want to give kyosho another $10 or sp for 3g of generic grease X or Y... lithium or plain jane mechanical grease should do the trick here, shouldnt have to buy specific K products... i m too old for this
thank you
Paul
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
