    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-14-2013, 01:26 PM   #8416
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Rumor has it that there's an "SP" coming out. You can still find them around, my LHS has a few on the wall. Great car, and the best shocks in the industry by far.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 10-14-2013, 01:36 PM   #8417
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by glenng View Post
thats a lotta toe in! i might rm on first outing, if i dont have time to switch to mm in the meantime. when i ran my durango in beginning of year, i got the panther super softs dialed really nicely. nevertheless i'll slick some m4's this week. thanks for all the help mike!
If you stay RM and have 521 arms, this setup was really good.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-14-2013, 02:48 PM   #8418
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Anyone tried messing with the toe inserts? Mainly running C in C in to narrow up the rear? If so what did you find it did to the car?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-14-2013, 02:52 PM   #8419
K_King's Avatar
Your set shows 1.0 in the Front Holder, but that is like 2 full degrees of anti squat, so you would be at 4 not 2 correct?
Old 10-14-2013, 03:14 PM   #8420
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
That's right. It would be 4 degrees the way he has it set. The car has 2 with no shims present.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 10-14-2013, 04:08 PM   #8421
MikeXray's Avatar
I did add 1mm under the front holder, the rear should have been whatever was stock, .5mm I believe, I forgot to check that, and I wasn't sure what the dg would calculate too. I didn't try it back to back without it, but that setup as a whole was good, so I didn't feel the need.
Old 10-14-2013, 05:39 PM   #8422
Rfury's Avatar
In that case you have -3 degrees. To get the same effect you could just put a 0.5 under the front block and remove the 0.5 from the rear block.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 10-14-2013, 06:20 PM   #8423
K_King's Avatar
Do you mind if I ask you some questions about your setup? I've been looking at it, and it's just very odd to me.
For example, the rear end seems weird. You have increased forward bite by adding more squat to 3 degrees, but then you add toe, have a .5 spacer on the bulkhead, and a 2mm on the outside to then stiffen up the rear end up again. Plus you are running 5wt thicker oil up front, and that could be because of the pistons, but then you run the rear end up 2mm higher than normal.
I just am trying to figure out how you got to that point, because it seems awfully unbalanced in terms of adjustments that do something, but then you are doing other things to counter act those things. lol
Anyway if you could fill me in Id love to hear it.
Old 10-14-2013, 07:15 PM   #8424
you are a king! thank you! hopefully i meet ya on friday!
glenng is offline   Reply With Quote
Old 10-15-2013, 05:26 AM   #8425
Trader Rating: 48 (100%+)
Any advantage in using the carbon composite parts?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 10-15-2013, 06:31 AM   #8426
Super Moderator
Trader Rating: 17 (100%+)
he runs at Area 51 LOL.
One of the local AE Factory guys who runs at his track was telling me this weekend that they are down to 17mm ride height, almost no droop, and a set of slicks every weekend. They do stuff to their cars there that just isn't done anywhere else in the world... hence Area 51.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-15-2013, 06:47 AM   #8427
Brollywood's Avatar
Bobs right. Long island it the land of setups that shouldn't work. Pay no attention to the man behind the curtain. If it works there........may mike reedy have mercy on your soul
A-main Bodies $ Fastraxx Hobbies $ The Ohio R/C Factory $ Team Chase Lemuiex $ Skipgear.com $ The Bearded Wonder
Eli Ezrow is my Father
"Josh Cyrul can't walk on f%cking water" - Nancy Filo
Brollywood is offline   Reply With Quote
Old 10-15-2013, 06:48 AM   #8428
MikeXray's Avatar
The shocks are easy, I only could get one set of blanks, and I really am not fond of the stock 5H pistons, the holes are too large imo, so thicker oil and higher ride height was for handling a bad landing we had on an old layout. (our current layout has one jump as well where you can land in the wrong spot and a bad bounce will put you on your lid). I much prefer the GHEA 4x1.3 tapered.
0 dg rear toe would have been better in 17.5 with this setup, as it had plenty of bite, but remember we run on full slicks and often traction roll, its kind of a balance choosing how much steering you can run. I also don't claim it to be a perfect setup, but it worked for me.
The rear camber link has not been touched beside moving from the 2 and 3 hole spots, I have not played with inside/outside link height, the height was from another fast driver, and I left it. The antisquat was not tested back to back, as I switched to MM for a while, and added it back in when I went to RM for an outdoor race.
This is very possible, I can't get down to the track every week and really test every change, plus the track gets better throughout the night and you don't always know if the change helped, or if the track did.
Sure, see above. I general, this car has just been good, even with the kit setup it was in the ballpark, and all the small changes, just give it different character, opposed to be B4 which would go "out to lunch" if you tried something weird.
Old 10-15-2013, 06:52 AM   #8429
MikeXray's Avatar
Honestly, I don't think its any different than setups made for carpet, but I did also run the exact same setup at vineland, just needed the right tires, and unfortunately chose the wrong tires at the wrong times for the track The car did have moments of being really good though.
Old 10-16-2013, 08:40 AM   #8430
SAMCRO's Avatar
Has anyone tried the rear stabilizer set? I am thinking of ordering one and wanted to get some input. Our indoor track is by no means high bite and can dusty/bumpy so I am not sure if it is worth trying or not...
SAMCRO is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
