    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 10-09-2013, 06:28 AM   #8386
Originally Posted by function>form View Post
What is the advantage of the 521 rear arms?
Gives a slightly looser feel to rotate and squares up faster than stock arms.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 10-09-2013, 07:21 AM   #8387
Razathorn's Avatar
The kit arms are "gull winged", which puts the shock lower than the 521 flat arms. The effect is that the progression of damping and spring is different between the two arms. The gull winged kit arms take longer to "stiffen up" during compression, where as the flat arms do not. The effect is that damping and spring is far softer initially on the kit arms, which is similar to running your shocks way further in, or a much lower rear roll center.
Tebo told me that with the kit arms you really need to run a thicker oil in the rear compared to the flat arms. He didn't tell me any of the stuff I wrote above -- that is MY take on what is happening.
The bottom line is the 521 arms roll less, and the classic outcome of that is the car squares up better out of corners and rotates a little more. It's like raising the rear roll center significantly more than you can with ball stud washers. It puts the rear end in an entirely different roll profile. On most surfaces, even loose ones, it is better IMHO.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-09-2013, 08:03 AM   #8388
Trader Rating: 50 (100%+)
when your talking about the 521 arms, u mean 521-1 not reg 521 right?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 10-09-2013, 08:11 AM   #8389
MikeXray's Avatar
Trader Rating: 73 (100%+)
The only difference between them is the shock hole, the 521 has inside/outside, and the 521-1 is the middle of those two.
My car was really good in 17.5 with the rb6 arms/MM but could be a bit more free, going to swap arms this week and see if I can feel or see it in the lap times.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-09-2013, 08:46 AM   #8390
hobdog's Avatar
Trader Rating: 19 (100%+)
So just to clarify, When putting a .5 shim under the rear toe block on mid motor configuration like Tebo did on the worlds set up, I would also have to add a .5 shim under the tower to make it correct.
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 10-09-2013, 09:33 AM   #8391
function>form's Avatar
Trader Rating: 43 (100%+)
Thanks for the explanation.
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 10-09-2013, 12:38 PM   #8392
carbons2k's Avatar
Trader Rating: 21 (92%+)
Mike, try 0 degree hubs
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 10-09-2013, 03:57 PM   #8393
This is true, as far as I understand it. I believe if you eliminate this shim, you instead use the 1.0 shim under the tower.
kes7u is offline   Reply With Quote
Old 10-09-2013, 04:10 PM   #8394
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Jonny5 View Post
Well now I'm glad I posted pics. I looked at pics of Tebo's car from CRCRC and really couldn't see it clearly. Guess I should have checked his Reedy Race setup as it clearly showed the arms the opposite of how I mounted them. First Kyosho build. Looks like I have a little more to do tomorrow.
By the way, your buggy looked really good on Friday. I was shocked to see how well the MM cars are running up there. We'll see you up there soon!
Thanks for the attempted bail out buddy.
Thanks. I recently went back to rear motor for testing purposes. the Mid motor is still easier to drive but i wanted to see how consistency came into play. I haven't completely made up my mind yet. The RB6 is a strong car in either configuration.
cnelson3 is offline   Reply With Quote
Old 10-09-2013, 05:57 PM   #8395
I have yet to try rear motor with mine. I wonder how rear would feel with my 17.5. Chris- I'm curious to know more about your "findings". I'll chat with ya at trackside. (this is Nick M.)
nrm1977 is offline   Reply With Quote
Old 10-09-2013, 06:04 PM   #8396
MikeXray's Avatar
Already did, moved the wheelbase 1mm shorter than middle as well. 521 arms and moving my battery back to inline from sideways are 2 bigger things I need to test, then I'm gonna go pluck that chicken
Old 10-11-2013, 09:38 PM   #8397
MikeXray's Avatar
Tried a few of the changes, didn't get to the 521 arms, but moved the battery. Fwd inline def feels different, it steers differently and I kinda preferred it, I could feel less sidebite in the rear, and in 17.5 I needed that. I played with springs, went stiffer all around, seemed to change feel, but not a huge impact on lap times. I was able to win the club race, qual 3rd.
Old 10-13-2013, 11:42 AM   #8398
Tried a few of the changes, didn't get to the 521 arms, but moved the battery. Fwd inline def feels different, it steers differently and I kinda preferred it, I could feel less sidebite in the rear, and in 17.5 I needed that. I played with springs, went stiffer all around, seemed to change feel, but a huge impact on lap times. I was able to win the club race, qual 3rd.
hey mike can you please post a pic of your setup, im getting my kyosho ready for island hobbies and was thinking of swapping to mid motor. thanks.
glenng is offline   Reply With Quote
Old 10-13-2013, 04:52 PM   #8399
MikeXray's Avatar
Here you go, I'm using 0 dg hubs now, even though the sheet has .5, if I run a faster motor, I use the .5
Old 10-13-2013, 06:30 PM   #8400
dmayhew25's Avatar
Trader Rating: 14 (89%+)
Been running the RB6 for about a month now and the car is very nice. Lots of good info in this thread. Thanks for all the good info everyone!
David Mayhew
Team Trinity, RevTech, KSG, BSR Tires, KCR Hobbies, ProtoForm
www.FinishLineSigns.net
www.FinishLineRaceway.com
dmayhew25 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
