    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 09-30-2012, 07:47 PM   #826
gelshocker's Avatar
What's the part number for the long ball stud? Thx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-30-2012, 08:00 PM   #827
Trader Rating: 77 (100%+)
Um128
goin2drt is offline   Reply With Quote
Old 09-30-2012, 08:14 PM   #828
BISBEE 248's Avatar
hows everyone mounting there elecs,i put my orion speedo under and reciver on top plate like pics but its horrible for routing wiring to battery plugs unless i re soldier new wires and put plugs towards front of car and reciver sits very high with wiring,rather keep lower center of gravity..??
O and im running full pack..
Brent Bisbee #248 AKA:Captain Red cup racing
Speedtechrc.com: The only way to shop
TLRacing.com / ProlineRacing.com / Airtronics.net / Miponline.com / Rcinsider.com / Bartolone Motors / Home of the "Bisbee no tell motel"-on wheels..
BISBEE 248 is offline   Reply With Quote
Old 09-30-2012, 08:40 PM   #829
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Re-soldering new wires is typically part of the build process. One wire setup/length for one car won't typically work for another.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-30-2012, 08:47 PM   #830
Matt Farris's Avatar
Trader Rating: 71 (100%+)
Have a question. What size big bores come with this kit? Like AE's new b44.2 comes with 12mm. All i can find is 38mm
Matt Farris-
Sponsors: era1FXcustoms.com -Proline Tires - Boca Bearings - Blaze RC
Matt Farris is offline   Reply With Quote
Old 09-30-2012, 08:54 PM   #831
savageboy69's Avatar
Trader Rating: 88 (100%+)
you could make a mount similiar to the one i made, but since you are running a full pack you would probably have to put some bends in the lexan so it mounted flat so your battery will fit under the reciever tray
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 09-30-2012, 09:33 PM   #832
silvalis's Avatar
Trader Rating: 29 (100%+)
12mm as well.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 09-30-2012, 11:45 PM   #833
Trader Rating: 137 (100%+)
Had to resolder 14 gauge wires on my speedo to get it to fit right. 12 gauge wires didn't really play all that nice.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-01-2012, 12:30 AM   #834
mdowney's Avatar
Trader Rating: 21 (100%+)
I just clipped off the rear battery stops so I could slide the ESC forward a few mm. I also mounted my Rx along the side if the battery in the traditional spot. Just had to stack up about eight layers of servo tape to build a flat spot. It takes patience but the layout looks great and balances out the capacitor on the other side. I'll post a pic when I get a chance.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 10-01-2012, 12:35 AM   #835
mdowney's Avatar
Originally Posted by jpcopeland1 View Post
What setup do you currently have on yours? Chris (local Kyosho Privateer) put the UM521-1 rear arms on his car and loves it now.
I have the UM521-1 arms on order. Will do a back to back run on them and see what the "feel" difference is between the two.
Chris is probably running Tebo's ROAR Nats setup, which uses UM521-1 and 0.5* hubs. He also used the short eyelets so there's almost no droop on the car. That's how he likes it but you'll get a lot of chassis slap off the big jumps. Depends on your track. It's worth trying. I think most of the team drivers are still playing around with setup because they all got their kits last week.
Mike Downey
Old 10-01-2012, 03:26 AM   #836
Anyone know the difference between the um521 and the um521-1 ?
Grippa23 is offline   Reply With Quote
Old 10-01-2012, 03:55 AM   #837
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
is the stock spur a 76?
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 10-01-2012, 04:03 AM   #838
eper's Avatar
Trader Rating: 14 (100%+)
the 521-1 has 1 hole in the middle of where the 2 holes are on the 521
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 10-01-2012, 05:15 AM   #839
At the track yesterday the team guys were running the longer rear eyelets on the shocks. FYI And yes they are running the upgraded aluminum rear .5* hubs.
Old 10-01-2012, 05:16 AM   #840
Yes
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
