    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0į/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-07-2013, 12:19 AM   #8371
Default MIP Puck's
Sorry, should have mentioned that i was talking about MIP's alum puck kits with alumium outdrives complete kit for kyosho SC and can work on RT5. Great kit everything is included.
CHUCKDOG is offline   Reply With Quote
Old 10-08-2013, 12:06 AM   #8372
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by joecool View Post
This shim must be changed to match the anti squat shim you are running. If you run the stock thin anti squat shim use the thin spacer between the block and tower. If you run no anti squat shim you then need the thick spacer between the block and the tower. It just keeps the shock tower height the same with the setup you choose.
What if you never put the shim in between the tower lol
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 10-08-2013, 08:36 PM   #8373
Trader Rating: 6 (88%+)
Hey guy I just picked up an rb6 and I was wondering if you guys had any tips.
Rcdudes3475 is offline   Reply With Quote
Old 10-08-2013, 08:49 PM   #8374
Razathorn's Avatar
Get the flat arms (um521-1) and the short shock ends in the rear. Best thing you can do to the car in mid or rear motor, period. Screws are "mid grade" at best, and the plastic is kinda "sticky", so take care and use good tools as it is very easy to strip those 2mm heads.
I really like the 4x#55 pistons -- you can get losis or drill your own by hand.
I would then start with either a rear or mid motor applicable Tebo setup from http://www.petitrc.com/setup/kyosho/...UltimaRB6.html .
Adjust tires, camber, and shock oils for your track and you should be golden. If you're on reliable good trip that doesn't get slick, mid motor is a good option. Start with -1 camber all around unless it's super stuck, then consider -2. If you're on a track that gets slick, rear motor is my preference. Same suggestions on initial camber. Adjust shock oil to temp, taking care to use losi oils and maintaining the front to rear difference that Tebo ran initially, and then tuning as you see fit.
For example, I run his nats setup with #55s, pink/gold springs, 35 losi front, 27.5 rear, -1 camber all around. It's hooked on medium/low grip indoor top soil.
Jared's setups are always a great starting point and are always really close with perhaps shock oil or camber needing change, and of course, correct tires for the track.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-08-2013, 09:17 PM   #8375
Trader Rating: 19 (100%+)
Here's a link to some pics of the pair of full option Yaiba cars I mentioned a few days back. Tomorrow I get to deliver them to my buddy and help him break them in on the track. Nice build overall and thanks to you guys for the various tips I read in these pages. Yaiba Racing Forum
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-08-2013, 09:33 PM   #8376
My checkbook just gave birth to a 1k RB6
Father is doing well, in fact he cut three seconds of his best lap...
Mother is headed to her attorney for a divorce. But by fact the best car I have ever driven
Medicman202 is offline   Reply With Quote
Old 10-08-2013, 09:39 PM   #8377
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Would you please measure the width of the flat sides of the pucks? Or the gap in the pucks outdrives? I am planning to put touring car blades on my MIP diff and so I would just need the pucks outdrives if the width is correct!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 10-08-2013, 09:57 PM   #8378
cnelson3's Avatar
Trader Rating: 65 (100%+)
interesting way of running the 521-1 arms in rear motor. arms look backwards. how does this work?
cnelson3 is offline   Reply With Quote
Old 10-08-2013, 10:13 PM   #8379
they basically sweep the axle forward to create a different weight distribution.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 10-08-2013, 10:23 PM   #8380
Well now I'm glad I posted pics. I looked at pics of Tebo's car from CRCRC and really couldn't see it clearly. Guess I should have checked his Reedy Race setup as it clearly showed the arms the opposite of how I mounted them. First Kyosho build. Looks like I have a little more to do tomorrow.
By the way, your buggy looked really good on Friday. I was shocked to see how well the MM cars are running up there. We'll see you up there soon!
Thanks for the attempted bail out buddy.
Old 10-08-2013, 10:46 PM   #8381
Originally Posted by SAMCRO View Post
Does anybody know when the RT6 will be available for purchase??
one week from today Im supposed to get mine.
AlwaysLOSI is offline   Reply With Quote
Old 10-09-2013, 02:07 AM   #8382
Anyone try this battery from Reedy? Reedy WolfPack 2S Hard Case Li-Poly Shorty Battery Pack 25C. Sorry I can't post URL.
The closes to Team Orion shorty which is impossible to find now.
ednamode is offline   Reply With Quote
Old 10-09-2013, 04:46 AM   #8383
KalEl63's Avatar
I run the GHEA 4x1.3mm pistons in my rear mount and really like them and the way the car felt is so much better.
I have to get some more for my mid mount carpet RB6 but was thinking of trying AVID pistons but was wondering if they need shimming at all as I read that the #55ís Losi ones do?
Mind you the money between AVID and GHEA isnít much
Looks like I will be starting again with trying kit arm V flat arms as I never thought of running the shorter shock ends until tonight.
This will now allow me the adjustment I needed to get my ride height down for the place I race on carpet
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 10-09-2013, 06:24 AM   #8384
function>form's Avatar
Trader Rating: 43 (100%+)
What is the advantage of the 521 rear arms?
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 10-09-2013, 06:28 AM   #8385
They run them that way in Europe in some places.
Better in slicker/low grip.
Shimmy is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
