    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 10-04-2013, 05:48 AM   #8356
Hey guys,
I have a question in case of springs.
Which springs would you suggest for racing on outdoor astroturf (europe)?
I canīt tell because I couldn`t test it so far, but i have been told by a few persons, that the standart kit springs are the worst choice for Turf.
comments? which Colors would you suggest? thanks for any Information
Ice22 is offline   Reply With Quote
Old 10-04-2013, 06:17 AM   #8357
Life_livin's Avatar
Trader Rating: 16 (100%+)
I agree, I've been running mine since April on a abrasive sugar track with no chassis protector.
Life_livin is offline   Reply With Quote
Old 10-04-2013, 09:55 AM   #8358
joecool's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Ice22 View Post
Hey guys,
I ran my buggy all summer on an out door carpet track. It was fairly high grip and everyone stiffened up their cars. I ran yellow fronts with red rear springs. You have to go up in oil weight as well or the car gets really bouncy. I ran 3hole 1.3 all around with 37.5wt front and 32.5wt rear. It was a good setup when it was hot outside.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 10-05-2013, 07:26 AM   #8359
Hey guys,
Orange Front and Red rear for high grip (Silverstone, Stotfold, Torch, Cov, Herts)
4x1.3 pistons front and back, with 40wt front and 30wt rear.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 10-05-2013, 01:31 PM   #8360
Don't be afraid to run soft springs in the front.
Normally it makes the inner rear to lift on high traction tracks. I drove on carpet indoor today with pink (the softest) on the front and gold back. It worked very good.
I looked at Tebos setup from the Worlds, was skeptical, but turned out to be fine.
http://www.kyoshoamerica.com/assets/...ldChampion.pdf
HansÖ is offline   Reply With Quote
Old 10-05-2013, 04:41 PM   #8361
biggerT's Avatar
Hey guys,
I run losi pink or yellow rear /losi green or xgear gold front 25/27.5r 30/32.5 f 4Ũ1.3 ghea pistons fs rear arms with third inner hole
Jesus saves Moses divides and Satan drives a stick
Kyosho rb6 kyosho rudebits db2 kyosho rudebits db4
biggerT is offline   Reply With Quote
Old 10-05-2013, 08:24 PM   #8362
Jochim_18's Avatar
Originally Posted by cnelson3 View Post
I'm glad I read this. just switched to mid motor but i was worried about getting the weight to transition rearward quickly. 2 mm spacer? what are the negative effects?
Gives you more rear traction... But I would suggest don't go more than 2mm shims. With RB6 I would start with 0.5 shims under the RF hangers. Adding pro-squat gives you more forward bite on low to medium bite track... But if your track is really high bite I would not suggest using pro-squat...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-06-2013, 02:16 AM   #8363
Managed to break an axle today, just downsided a jump and snap.
Also looking for UMW705 for my RT5 but seems everywhere is out of stock.
Anyone know anywhere I could get one?
Or when they are due to be back in stock?
Shimmy is offline   Reply With Quote
Old 10-06-2013, 05:19 AM   #8364
Same here, Iīve been running pink front gold rear all year no matter what Surface, I had White in front on carpet Indoor last season.
Hans did you run schumi tyres Indoor or vbc ?
/Patrik
RB-6.6
zx-6
RT-6
Heda is offline   Reply With Quote
Old 10-06-2013, 06:06 AM   #8365
SAMCRO's Avatar
Does anybody know when the RT6 will be available for purchase??
SAMCRO is offline   Reply With Quote
Old 10-06-2013, 07:30 AM   #8366
asc6000's Avatar
Trader Rating: 15 (100%+)
Late October
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 10-06-2013, 09:16 AM   #8367
Trader Rating: 20 (100%+)
Hey guys,
Hoping to get some help in deciding on a 1/10 scale. I have an mp9e and an electric st-rr that I drive mostly. I want a 1/10 scale for indoor ONLY. Right now I have a b44, but I want to switch over to K car in 1/10.
So my question is, should I get a rb6 or zx5? I'm not concerned with which class is more competitive or anything. Basically, would I be able to get comfortable with 2wd since I'm mostly a 4wd driver? What would you recommend?
Kyosho
MP9 TKI4 & MP9E TKI4
BoomRC.net, AKA, ACE Servos, Ko Propo, JTPrc.com, Allebasi
jonasm48 is offline   Reply With Quote
Old 10-06-2013, 10:26 AM   #8368
Trader Rating: 48 (100%+)
Originally Posted by jonasm48 View Post
Hey guys,
Well the zx5 is a 4wx so ur better off with the rb6
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 10-06-2013, 11:30 AM   #8369
silveraider14's Avatar
This is the dialed setup! His car was untouchable!
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 10-07-2013, 12:12 AM   #8370
Ran them this weekend at ierc / ca track they worked great better acceration and and won sc class and gave mod trucks fits all day.
CHUCKDOG is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
toast.
