    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 10-02-2013, 06:25 AM   #8341
Hay whats a good starting point on setup for mm motor setup l
Brought to you by the number 4 and the letter X
Running a Kyo MP9 TKI3 and An STRR EVO truck
rcmad2700 is offline   Reply With Quote
Old 10-02-2013, 07:14 AM   #8342
Life_livin's Avatar
Trader Rating: 16 (100%+)
If you're running on sugar check out Tebos cactus and his worlds setups they are both great.
Life_livin is offline   Reply With Quote
Old 10-02-2013, 08:28 AM   #8343
carbons2k's Avatar
Trader Rating: 21 (92%+)
Honestly... take your rear motor set up and just switch it to mid motor. That's all I did and the car is mint. If you feel that steering is lacking raise your caster and use the 4 inserts in the caster as well.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 10-02-2013, 08:40 AM   #8344
CanyonCarverR1's Avatar
Originally Posted by Rcnutguy View Post
With over 500 pages, it's really hard to find my question that I have that may have already been asked.
I'm running a RB6 and weighs in at 1586grams
I have Titanium screws installed
and a Yaiba rear bulk head installed as the plastic one didn't last long.
What other things can I get to shave some weigh off please?
Looking at maybe 30 grams to loose if possible.
"shorty" battery
short servo
Lunsford titanium ball studs
Lunsford titanium motor screws
titanium turnbuckles
14g wire(if running 17.5)-also keep wire to minimum length
Light coats of paint
CanyonCarverR1 is offline   Reply With Quote
Old 10-02-2013, 08:59 AM   #8345
Trader Rating: 48 (100%+)
Originally Posted by CanyonCarverR1 View Post
"shorty" battery
short servo
what size ball studs did you use? I am looking at making this my next upgrade.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 10-02-2013, 05:54 PM   #8346
http://www.amainhobbies.com/product_...ll-Stud-Kit-14
http://www.amainhobbies.com/product_...m-Ball-Studs-2
Old 10-02-2013, 07:34 PM   #8347
Hi CanyonCarver,
Do I need to buy all of them or just the first link which is the set? Since the first link is the complete set. Thanks.
ednamode is offline   Reply With Quote
Old 10-03-2013, 01:07 AM   #8348
Trader Rating: 65 (100%+)
Has anyone tried the mip puck for 17.5? $100.00 ouch. Worth it?
nrm1977 is offline   Reply With Quote
Old 10-03-2013, 09:09 AM   #8349
Originally Posted by ednamode View Post
Hi CanyonCarver,
The kit will get you started. I bought a few extra pieces to have on hand. Sometimes I needed a long ball end when I only had a short one. I like to have the maximum amount of threads screwed into the plastic parts.
Lunsford also makes a titanium hinge pin set, though I don't recommend using the inner pins on the sus arms, they bend easy. But the king pins and outer sus arm pins work just fine.
http://www.amainhobbies.com/product_...nge-Pin-Kit-10
Old 10-03-2013, 09:21 AM   #8350
whats the purpose of the shim between top of rear bulkhead and tower? in mid motor
Will Martin
Jam-Air is offline   Reply With Quote
Old 10-03-2013, 10:40 AM   #8351
joecool's Avatar
Trader Rating: 19 (100%+)
This shim must be changed to match the anti squat shim you are running. If you run the stock thin anti squat shim use the thin spacer between the block and tower. If you run no anti squat shim you then need the thick spacer between the block and the tower. It just keeps the shock tower height the same with the setup you choose.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 10-03-2013, 10:52 AM   #8352
Razathorn's Avatar
That is so obvious now that I think about it.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-04-2013, 02:47 AM   #8353
Whats the average lifespan of a chassis, just built my rb6 and considering waiting 3 weeks and ordering a chassis protector or just going rc'ing this weekend, not sure which to do.
skhadka17 is offline   Reply With Quote
Old 10-04-2013, 03:28 AM   #8354
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Hi, i would suggest to not wait, go and racing.
Lifespan of a chassis i very long, unless you crash really really bad but then the chassis protector would not help you in any case.
For scratches, you can race for a very long time.
Ciao,
Lorenzo
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 10-04-2013, 05:13 AM   #8355
t8rtot's Avatar
Trader Rating: 14 (94%+)
I'm going on a year and if I polish it, it looks new. Indoor racing
Sfida
t8rtot is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
