    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-30-2013, 04:27 PM   #8311
Trader Rating: 48 (100%+)
Is there any advantage of the new aluminum suspension holders over the old ones? I have the old ones?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 09-30-2013, 05:34 PM   #8312
skengines's Avatar
Trader Rating: 226 (100%+)
More adjustability.
With the new hangers you can run narrow and wide plus more.
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 09-30-2013, 05:56 PM   #8313
martindavis's Avatar
I am going to order one of these!!
What additional (upgrade) parts do I really need out of the box?
Thx
martindavis is offline   Reply With Quote
Old 09-30-2013, 06:29 PM   #8314
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Adjustability.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 09-30-2013, 07:11 PM   #8315
cnelson3's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Jochim_18 View Post
I have run my 22 mid motor since it came out and learned a lot how mid motor works... Pro squat is the key to get forward bite... 0 degree anti-squat and add 2mm shims on the RF hanger to get 2 degree of Pro-squat what it does is force the weight to be transferred on the rear to give you more forward bite, try using longest link on the rear, 2mm on inner/outer ball stud, believe or not transverse battery position will give a lot of forward bite but the car will be unpredictable to drive in corners and its not well balance mounting the battery that way...
I'm glad I read this. just switched to mid motor but i was worried about getting the weight to transition rearward quickly. 2 mm spacer? what are the negative effects?
cnelson3 is offline   Reply With Quote
Old 09-30-2013, 08:19 PM   #8316
Gayosaka's Avatar
Thx
Steering link, front bar... Check the first page for valuable infos
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is online now   Reply With Quote
Old 09-30-2013, 09:44 PM   #8317
Life_livin's Avatar
Trader Rating: 16 (100%+)
Looking to get the new RF rear hangers since I finally broke a plastic one, but cant seem to find them instock anywhere and ive been on the backorder list on Amain forever. Anyone know when they will be back instock or where I can get one?
Life_livin is offline   Reply With Quote
Old 09-30-2013, 09:57 PM   #8318
skengines's Avatar
Check speedtechrc
Old 09-30-2013, 10:01 PM   #8319
Life_livin's Avatar
Back ordered there too.
Old 09-30-2013, 10:03 PM   #8320
skengines's Avatar
http://www.ebay.com/itm/Kyosho-KYOUM...item2580e3ea40
Old 10-01-2013, 03:39 AM   #8321
Trader Rating: 19 (100%+)
Thx
Don't really need any but the weakest links would be the steering link and RF hanger I think.
Didnt the front brace get a running update?
Everything else is for a bit of extra adjust ability or just bling.
Shimmy is offline   Reply With Quote
Old 10-01-2013, 05:59 AM   #8322
I am currently running rm and was thinking about switching to mm. what advantages would i see by swithching over. also anyone running lunsford titanium ball studs? if so which size?
My Credit Card
Old 10-01-2013, 07:27 AM   #8323
stiltskin's Avatar
Trader Rating: 102 (100%+)
I think Exotek makes their own version. Not sure if it's the same or not.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 10-01-2013, 08:28 AM   #8324
Razathorn's Avatar
Did you just break the front one? If so, the other "RF2" hanger that comes on the tree has the same dimensions but just less material I believe. I measured it the other day.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 10-01-2013, 08:29 AM   #8325
powerslave's Avatar
The front brace is a running change.
It also looks like the chassis has a few more holes for battery placement.
I have been running the RB6 since its release, i go threw front bumpers front arm holder and front arms.
Upgrades i would recommend rear hubs , suspension hangers and steering link.
powerslave is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gayosaka
