    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-29-2013, 05:42 PM   #8296
DJGray17's Avatar
Ok I am making the switch from B4.2 to the ultima rb6. Has anyone made this switch? Also what parts should I stock on for the rb6?
DJGray17 is offline   Reply With Quote
Old 09-29-2013, 05:45 PM   #8297
Teambcw's Avatar
Trader Rating: 28 (100%+)
I have and love it. read the front page of this thread it gives you all the basics.
OCRC / C$ race setups ...... And my Wife
Teambcw is offline   Reply With Quote
Old 09-29-2013, 07:22 PM   #8298
Razathorn's Avatar
Originally Posted by t8rtot View Post
Or try tuning for the conditions. Play with camber links and roll centers. Add toe. Take out some sideguard screws and get some flex in there for more traction.
I did a lot of changes. I tried front and rear roll center changes, camber link lengths, shock oils, custom rear roll center changes (shimmed rear arms up with gull wing kit arms), rear sway bar with lower roll center on both kit and 521-1 arms, higher rear roll center via hubs, different hub and camber plate holes, different ride heights, basically chased it for 2 weeks. Tebo's setup was pretty much the best the car got in mid motor with just shock oil and camber specifically tuned for the track, and it was amazing if the track was stuck, but if the track got slippery, the rear motors had a definite advantage.
I went back today and did some track testing with different tires and the story was pretty much the same. It's not horrible, but it's not competitive with other people previously my speed when we both ran rear motor.
I can definitely feel the awesomeness of mid-motor, where it would be faster, and it IS better when the track is stuck, incredible even, but I have to go with what works overall for our track, which is medium traction on average, and often, especially the mains, packed and dry loose.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 09-29-2013, 08:13 PM   #8299
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Did you by chance happen to try hanging some weight in the back of the car...say about 15 grams or whatever Tebo had on the back of his? Just curious.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-29-2013, 08:15 PM   #8300
I've had pretty much the same results. I may try Ty's set up with the saddles turned sideways all the way back.....just to try.....but my home track is smiliar........medium bite...but gets dry and dusty pretty fast.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 09-29-2013, 09:27 PM   #8301
gelshocker's Avatar
Hey guys, for the Exotek alum diff nut, what's the purpose of the enclosed black shim piece? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-29-2013, 10:28 PM   #8302
Jochim_18's Avatar
I have run my 22 mid motor since it came out and learned a lot how mid motor works... Pro squat is the key to get forward bite... 0 degree anti-squat and add 2mm shims on the RF hanger to get 2 degree of Pro-squat what it does is force the weight to be transferred on the rear to give you more forward bite, try using longest link on the rear, 2mm on inner/outer ball stud, believe or not transverse battery position will give a lot of forward bite but the car will be unpredictable to drive in corners and its not well balance mounting the battery that way...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-29-2013, 10:58 PM   #8303
Life_livin's Avatar
Trader Rating: 16 (100%+)
Anyone have a part numbers for aluminum balls that work with the Kyosho shock ends?
Life_livin is offline   Reply With Quote
Old 09-29-2013, 11:00 PM   #8304
Use the Losi 22 ones on the kyosho lower shock ends work great.
LT FAB is offline   Reply With Quote
Old 09-29-2013, 11:14 PM   #8305
Life_livin's Avatar
Awesome, thanks!
Old 09-30-2013, 08:24 AM   #8306
Razathorn's Avatar
No. My view on the subject is if I move to mid motor, run saddles, grind the rear plate down to move the battery all the way back, have a 1600+ gram car, then need more weight in the rear, then that is an indication that I've picked the wrong chassis layout for my track. Now, on the other hand, if I was well below weight, or at weight, running a shorty pack, then sure, I would have tried it, but my little front heavy piggy isn't putt'n on lead pants
Old 09-30-2013, 08:29 AM   #8307
skengines's Avatar
Trader Rating: 226 (100%+)
What weight did Tebo use?
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 09-30-2013, 03:03 PM   #8308
Gayosaka's Avatar
Default Tebo @ Worlds
Regarding pistons, the Worlds winning setup sheet says 3x1.2 and 2x1.6 (possibly AE items) but are those tapered or flat ones?
Thx.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 09-30-2013, 03:08 PM   #8309
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Thx.
They are probably the Kyosho blank pistons that he custom drilled.
KYOW5303-08
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 09-30-2013, 03:08 PM   #8310
Rfury's Avatar
He said on his blog today that he removed the weight during his practice runs and did not put it back on.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Arctic RC
