    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 09-19-2013, 04:54 PM   #8191
Life_livin's Avatar
Trader Rating: 16 (100%+)
I didn't have a single problem with any of my screws and after many tear downs and swaps between mid and rear motor I still haven't stripped a single one.
Life_livin is offline   Reply With Quote
Old 09-19-2013, 09:39 PM   #8192
Originally Posted by 1armed1 View Post
Clay compounds work best when there is moisture in the clay.
If it's dry soft or super soft will work better.
Dayton
at irh i noticed that panther ss slicks worked in all conditions even when clay didnt work for others (most likely when it was dry). i also sauced w epic green dot.
glenng is offline   Reply With Quote
Old 09-19-2013, 11:05 PM   #8193
Default IRH Setup
Hi,
i am just finishing my rear motor build to race at island hobbies this fall and winter. i figured id start rear motor and go from there. i got the new alloy hangars for the rear and wanted to know if anyone raced rear motor what was a good setup please? should i do the narrow inserts or wide setup? and with stock rear a-arms or um521-1 arms and with which respective insert for the new version hangars? also a general setup would be appreciated if possible. was concerned about battery placement as well. if any one could help with particular track i would greatly appreciate the help. thanks in advance.
glenn
Old 09-20-2013, 12:34 AM   #8194
Hey Everyone,
I thought I would provide a quick MM update.
First of all here is the current layout that I've been running for about two weeks.......
Car has been good but I think it could be better.....
I started out with the stock pistons and 30/25 oil just as Hara used at WCRC......car was bouncy.....went to a white AE spring in rear....car had more rear bite on power......but not as much as I had hoped for....I then went to a higher rear roll center and things got better........
Next week I went to 4 hole #55 pistons and UM521-1 rear arms.....and .5 degree hubs...... oil was 35/32.5 and now 35/30. Car has been pretty damn good.....although I'm now disassembling it to go Saddles.....I'm convinced the extra weight is the answer to getting this car dialed on lower bite surfaces.
A few guys at my local track also run very soft suspension packages on their rear motor cars......something in the neighborhood of 4 hole #55 pistons with 25/25 or 27.5/25 and they have had good results......may end up giving that a whirl......
Oh yeah....after talking to Carson Wernimont I decided to add more droop.......MAN WHAT A DIFFERENCE! Made the car fun to drive as opposed to punishing when you land flat bottom.......which CAN be faster in certain portions of certain tracks...........not all jumps are faster when downsided
Oh well....thats it...I should have a video out soon on this car.....so far I'm pretty impressed.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 09-20-2013, 01:14 AM   #8195
My current setup for mid motor, waiting on a rudebits lipo tray and will move the receiver to the back of the car so I can shift the weight around a bit more.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 09-20-2013, 06:52 AM   #8196
wild gopher's Avatar
Trader Rating: 39 (100%+)
What battery strap is that?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 09-20-2013, 06:56 AM   #8197
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Latest post on Tebo's blog is quite interesting...
http://jtprc.com/2013/09/20/car-chec...-ifmar-worlds/
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 09-20-2013, 07:52 AM   #8198
t8rtot's Avatar
Trader Rating: 14 (94%+)
What's interesting is he isn't using the KIY radio
Sfida
t8rtot is offline   Reply With Quote
Old 09-20-2013, 08:36 AM   #8199
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
That an the fact that he's only running an 8.5. I wonder if he uses boost, or is trying to limit wheelspin. I guess it does help things from getting out of hand too fast, but the Orions don't have insane bottom end to begin with.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 09-20-2013, 09:13 AM   #8200
Rfury's Avatar
Tebo has been running a 7.5 for quite awhile.
I was more interested in why he chose to go with a shorty instead of the saddles he has been running.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 09-20-2013, 09:18 AM   #8201
joho's Avatar
I think the interesting part of Tebo's latest mm setting was actually the shorty Lipo. Previously on all his set up he is using saddle, and the fact that the shorty is placed like what you did on a RM is also something we can all think about.
So for MM, shorty or saddle? Hara's method or Tebo's? This is gonna be a very interesting worlds :-D
joho is offline   Reply With Quote
Old 09-20-2013, 11:17 AM   #8202
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Maybe I am reading to much into this or just not able to comprehend what is being said. With that said, perhaps IFMAR doesn't have the same or similar battery rules as ROAR as to how they are mounted into the car? Thus his decision on the choice of battery to use has changed.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-20-2013, 01:13 PM   #8203
Trader Rating: 26 (88%+)
What gearing is a good starting point for a 8.5 turn motor
jgonz is offline   Reply With Quote
Old 09-20-2013, 01:15 PM   #8204
Rfury's Avatar
I am running 22/78 right now.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Old 09-21-2013, 08:12 AM   #8205
Does anyone run drag brake....I've only ever ran Stock with no drag brake. I am now starting to run Mod and was wondering what most prefer drag or no drag
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Today 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
