    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 09-16-2013, 03:49 PM   #8176
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by MikeXray View Post
Finished putting the car back to midship, trying the stock rear arms this time, I like that I can fine tune the wheelbase more with them for one, also trying a few other geometry changes that aren't often used. When I ran mid last time at our track I ended up with the shorty forward, but inline, so I think sideways and forward a bit will still work. I would like to fit a battery strap and not rely on tape, but I have to make something.
I ran this setup on friday, started off with a 10.5 motor and running with the mod guys, would still wheelie everywhere, lol. The balance felt good though, the mid setup does struggle on tight 180s, as others have noticed, but the was consistent.
I wanted to try in 17.5 as well, so I switched out the motor/spur and left the setup, and the car still felt really good. I'm going to try some small changes, and also run the batt inline and forward just to see how it feels. (that was the config I ran last time I ran MM). I am running the exotek mid narrow hanger setup, so far I prefer this over the wide blocks.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-17-2013, 12:11 AM   #8177
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by 1armed1 View Post
I set my car up with the narrowest possible setting and used .5 hubs and shorty pack sideways at the back. This is with the stock rear arms.
I did this for the most possible grip as this is my first mid motor car.
The car was fantastic, easy to drive and was still very stable when driven aggressively.
I let a few people drive it after the event and 2 of the guys now have my setup on their cars and a 3rd is working on getting a Rb6.
Dayton
Did you have to change the shock mounts at all? I run C in right now but was thinking about the narrow one as well. I would assume it stands the shock up more as well.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 09-17-2013, 04:42 AM   #8178
Johnn27's Avatar
Trader Rating: 71 (100%+)
Questions?? rear mtoe
So to go narrower and maintain 3 degrees of toe would be D in / D in ?
Johnn27 is offline   Reply With Quote
Old 09-17-2013, 04:46 AM   #8179
jkirkwood's Avatar
Correct. That is the narrowest setting with 3 deg toe-in.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 09-17-2013, 07:51 AM   #8180
Razathorn's Avatar
During the initial parts of my build last night, I do have two complaints to make against this kit.
The first one is relatively easily solved with a screw kit, but is pretty disappointing in a kit that is so pricey, which is that the screw heads are softer than I would expect. I haven't stripped any out and use good hardened wrenches, but some of the longer screws that took more time to screw in (such as attaching the front end to the chassis) definitely looked like, if I had to take them in and out a lot, they would round out and need to be slotted and backed out based on the wear the head had just from installing them.
The second complaint is the diff t-nut plastic is pretty thin—I had a little excess hanging out of the outdrives and I went to trim it level with the outdrive with a sharp xacto knife and it broke off one of the pegs. I'm hoping the t-nut works well enough with one peg in one slot of the outdrive until I can get a replacement.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 09-17-2013, 09:42 AM   #8181
hobdog's Avatar
Trader Rating: 19 (100%+)
Wayne
I would have to agree with you. Great kit but terrible screws
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 09-17-2013, 10:51 AM   #8182
MikeXray's Avatar
I feel its more that the plastic is just hard, if you sacrifice a few other screws and pre thread the holes, from then on, they thread very nice.
Old 09-18-2013, 11:27 AM   #8183
skengines's Avatar
Trader Rating: 226 (100%+)
I dislike the diff assembly on the RB6. The plastic t nut is like you said very thin. After building AE diffs for a while, they are so easy and hold up well.
I broke my plastic nut so I upgraded to a Extoek piece.
Wayne
Mugen MBX7 Eco/Mugen MBX7T Eco
skengines is offline   Reply With Quote
Old 09-18-2013, 02:03 PM   #8184
Razathorn's Avatar
I ran an rb5 for quite a while in the past and the rb6 tnut is the same part and I never had an issue with it. It's mainly a problem for those of us who have AE diff building down to a speedy process and just went on auto pilot and tried to trim the K tnut like it was an AE tnut, which is far tougher.
Having said that, the K design does offer a benefit—when the locknut finally starts backing off, you can just throw another nut in there that you can source from a lot of different places.
Old 09-18-2013, 05:20 PM   #8185
Razathorn's Avatar
Default My custom saddle setup
Took a hint from tebo and team to run the saddles all the way back by grinding down the motor guard and went one step further and chopped up the front holder and mounted them with some longer screws back a bit more on the chassis. This frees up some room up front for electronics compared to running the front holder just turned around. It also allows you to use the plastic stock strap as it now reaches the motor guard well. The strap flexes to account for the posts being closer thanks to being plastic.
Old 09-18-2013, 05:37 PM   #8186
Razathorn's Avatar
Has anyone ran into the issue of the o-rings for the shocks being absolutely huge compared to what they're supposed to fit in? I'm not talking about the o-rings for the shafts, I'm talking about the o-rings for the shock cap, cartridge, and body. It's like they're for the 1/8 scale. Is this the norm? Do you just have to squeeze these guys in?
EDIT: Nevermind. I had misplaced the smallest ones and was mistaking everything for one size smaller than it was. For example, I was thinking the ones that go in the collars were the cap ones, and of course, those were huge.
Old 09-19-2013, 01:40 PM   #8187
MikeXray's Avatar
Do any of you race on a track where m3/4 and clay all work? When is clay the right compound to use?
Old 09-19-2013, 02:16 PM   #8188
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Clay compounds work best when there is moisture in the clay.
If it's dry soft or super soft will work better.
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 09-19-2013, 02:35 PM   #8189
stiltskin's Avatar
Trader Rating: 102 (100%+)
Dayton
We get the same results locally. Clay tires only work when the track is damp. We don't water the track on race day, so clay tires have never worked for me.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 09-19-2013, 04:50 PM   #8190
1armed1's Avatar
I ran the same shock mount locations as I did with rear motor and standard narrow blocks.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
