    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-29-2012, 02:12 PM   #796
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
^^^do you have a part number for them????
Thanks.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 09-29-2012, 02:15 PM   #797
Moderator
Posvar's Avatar
Old 09-29-2012, 02:17 PM   #798
Trader Rating: 77 (100%+)
Originally Posted by goin2drt View Post
I will post a pic later but all my stuff fit awesome. Shorty lipo is the key. I went 1015 servo, then my airtronics receiver. Lipo and then the LRP SXX fit perfect with the cap hidden under the shock tower.nothing had to go on the sides. All balanced right down the middle.
Here is mine. Not completed. I am going to shrink tube the wires black. I was surprised at how nice everything fit.
goin2drt is offline   Reply With Quote
Old 09-29-2012, 02:17 PM   #799
steam's Avatar
Thanks.
Just cut the longer ones to the right length
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 09-29-2012, 02:26 PM   #800
steam's Avatar
Attachment 975742
Attachment 975744
Attachment 975743
Looks good, I have a Lo profile servo, but this is pretty much the set up I'm going with.
Old 09-29-2012, 03:22 PM   #801
azz28's Avatar
Trader Rating: 30 (100%+)
Originally Posted by jpcopeland1 View Post
During racing at OC/RC last night Tater and Chris stripped out ball studs from their front hub carriers. Only fix was to install the longer ball studs which I have on order. Has anyone else had this problem. They went 1-2 in modified, First Chris, then Tater.
funny u should mention this my mate had two ball studs strip straight out of the rear bulkhead the other night..... not from a shunt either weird .... so i have put longer ones in mine also with a nut on them !!
Kyosho RB6 & RB5 WC| Orion r10 pro- Vortex Vst 8.5t | KO Propo |
Kyosho MP9 TKI3 |OS Engines| Byron ProDriver Gen2| KO Propo |
azz28 is offline   Reply With Quote
Old 09-29-2012, 04:47 PM   #802
t8rtot's Avatar
Trader Rating: 14 (94%+)
Has anyone mounted saddles sideways with the car in rear motor? Pics?
Sfida
t8rtot is offline   Reply With Quote
Old 09-29-2012, 06:01 PM   #803
Trader Rating: 1069 (100%+)
I'm gonna try it, but won't have it built for a week or so... Will have RS Pro, 614ff, and BLS551 low pro servo.
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 09-29-2012, 07:05 PM   #804
mdowney's Avatar
Trader Rating: 21 (100%+)
If you're having trouble with ball studs stripping out you can also put grub screws in the empty holes. This also makes your bulkhead more sturdy. The manual actually tells you to do this in the rear but you can do it in the front too.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 09-29-2012, 07:40 PM   #805
savageboy69's Avatar
Trader Rating: 88 (100%+)
My saddles will be here Monday and ill post some pics
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 09-29-2012, 08:39 PM   #806
Trader Rating: 137 (100%+)
I've done that to mine. Hope it keeps from happening tomorrow.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 09-29-2012, 08:57 PM   #807
mdowney's Avatar
Also, don't over-tighten your ball studs when you screw them in. And if you're using a electric screw driver, go slow so the plastic doesn't over-heat and set your clutch low. I like to use a wrench for the last few turns so I don't strip the bulkhead.
Mike Downey
Old 09-29-2012, 09:10 PM   #808
mdowney's Avatar
Originally Posted by Derry View Post
If Kyosho made an front alum pivot block I would buy it!
I've never broken a front pivot block and you're a better driver than me. I think you're safe with the kit plastic.
Mike Downey
Old 09-29-2012, 09:16 PM   #809
mdowney's Avatar
(Yes, I know about multi-quote. Just reading back through old posts. Sorry...)
I mounted my Futaba Rx, which is bigger than the KO, right side up along the side of the battery. I just layered up about eight pieces of servo tape to build a flat spot for the Rx. Seems to work fine. We'll see if it holds up. Mounted the R10 capacitor opposite the Rx but in its side. Power switch mounts vertically on the side of the rear bulkhead behind the ESC on the right side.
I think this is what Jared did too.
Mike
Originally Posted by savageboy69 View Post
wondering how others mounted there reciever? heres a pic of mine i made a piece out of lexan that drops down 4mm for a little extra clearance for the ko reciever
Mike Downey
Old 09-29-2012, 10:10 PM   #810
Thanks.
KYOUM128
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
